CLP-120-02-S-D-BE-A-P 数据手册
REVISION CW
1. C REPRESENTS A CRITICAL DIMENSION
2. MINIMUM PUSHOUT FORCE: .5LB (8 OZ)
3. ONE POSITON WILL BE LOST FOR EVERY CUT MADE ON A
SOCKET STRIP
4. TUBE PACKAGE POSITIONS 5-50 ONLY. POSITIONS 2-4 ARE
TO BE PLACED IN ANTISTATIC BUBBLE BAGS P/N ASBBLT4X5.5.
5. SHEAR TAILS TO DIMENSIONS SHOWN
6. PARTS TO BE SYMMETRICAL ABOUT CL WITHIN ±.0015[0.038].
7. ENDWALL AFTER CUTTING: .0185[0.470]±.0025[0.064]
8. VOID CORES MAY NOT BE PRESENT.
9. HAND FILL USE C-106-01-XX.
AUTOMATION USE C-106-22-XX. C-106-02-XX CAN BE
DO NOT
SCALE FROM
THIS PRINT
CLP-1XX-XX-XXX-D-XX
No OF POSITIONS PER ROW
-02 THRU -50
OPTION
-P: PICK & PLACE PAD (USE LMP-01)
(AVAILABLE ON POSITON -05 THRU -50 ONLY)
(NOT AVAILABLE WITH -PA OR -K OPTIONS)
(SEE FIG 3, SHT 2)
-A: ALIGNMENT PIN (USE CLP-XX-D-XX)
(NOT AVAILABLE WITH -PA OPTION)
(SEE FIG 2, SHT 2)
-TR: TAPE AND REEL
-BE: BOTTOM ENTRY ONLY (USE CLP-XX-DBE-XX)
-PA: PICK & PLACE PAD WITH ALIGNMENT PINS
(NOT AVAILABLE WITH -P, -A, OR -K OPTIONS)
(SEE SHT 2, TABLE 3)(SEE NOTE 12)
-K: POLYIMIDE FILM PAD (AVAILABLE ON -05 THRU -50
POSITIONS. USE K-DOT-.157-.250-.005, (SEE FIG 5, SHT 2)
(NOT AVAILABLE WITH -P OR -PA OPTIONS)
LEAD STYLE SPEC
-02: SURFACE MOUNT
(USE C-106-X2-XXX)
(SEE NOTE 9)
SUBBED FOR C-106-22-XX.
C
C 10.
MAX CUT FLASH: .010[0.27] WITH NO FLASH ALLOWED IN
HOLES OR EXTENDING BELOW LEADS.
.005 0.12
C 11. MAX BURR: .005[.13].
12. ALL -PA OPTION PARTS SHIP IN EIA-960 TRAYS.
(SEE NOTE 13)
13. DOES NOT APPLY TO -BE END OPTION.
C
.0100 0.254
BODY SPEC
-D: DOUBLE ROW
(USE CLP-XX-D)
DETAIL 'D'
SCALE 16 : 1
PLATING SPEC
-F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
-G: 10µ" GOLD IN CONTACT AREA
3µ ON TAIL
-H: 30µ" HEAVY GOLD IN CONTACT AREA
3µ" ON TAIL
-LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
-FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA
MATTE TIN ON TAIL
-LTL: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA
TIN/LEAD (90/10+/-5%) TAIL
No OF POS x .0500[1.270]) - .0500[1.270]
(TOLERANCE ACCUM ±.0020[0.051])
C
.034 0.85
REF
'D'
(No OF POS X .0500[1.270]) + .017[0.43]±.008[0.20]
(SEE NOTE 3 AND 7)
02
.120 3.05
REF
01
-D
CLP-XX-D-XX
-D-BE
CLP-XX-DBE-XX
C
+.003
"A"
"B"
"A"
"B"
.050 1.27 REF
+0.08
.090 - .001 2.29 - 0.03
(MEASURE AT BEND)
4
.084 2.12 REF
.004[[0.10] POS. 02-35
-D
-D-BE
.170±.010 4.31±0.25
.016 0.41 x .005[0.13] REF
C-106-22-XXX
C
88°
REF
90°
3
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
-D-BE
FIG 1
SECTION "B"-"B"
(-D-BE BODY: CLP-XX-DBE-XX)
(DIFFERENT AS SHOWN,
OTHERWISE SAME AS -D BODY)
(-D BODY: CLP-XX-D-XX)
DECIMALS
-D
IN-PROCESS
SCALE 8:1
POS. 36-50
SECTION "A"-"A"
2.5 MAX SWAY
(TYP)
.010 0.25
.012 0.30
.006[0.15]
CL CL
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 3:1
DESCRIPTION:
LOW PROFILE .050 x .050 DOUBLE ROW ASM
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: PHOS BRONZE
F:\DWG\MISC\MKTG\CLP-1XX-XX-XXX-D-XX-MKT.SLDDRW
DWG. NO.
BY:
CLP-1XX-XX-XXX-D-XX
PURVIS
01/31/1994
SHEET 1 OF 3
AVAILABLE ON POSITIONS 05 THRU 50 ONLY
NOTE: "N" = USED MEASURED DIMENSION (REF)
"Q" = [("N" - .250[6.35])/2] ±.020[0.51]
REVISION CW
C
"N" (SEE NOTE)
C
"Q" 3.45
(SEE NOTE)
.100 2.54
.005 X 45° REF (TYP 4 SIDES)
.019 0.47
(No OF POS x .0500[1.270]) - .100[2.54] 22.86
LMP-01
.0070 0.178
.250 6.35 REF
FIG 2
REF (TYP)
.0100 0.254 REF (TYP)
.0050 0.127 REF (TYP)
FIG 3
-P: PICK AND PLACE PAD
(AVAILABLE ON POSITION 05 THRU 50 ONLY)
-A: ALIGNMENT PIN
(3 POSITION MINIMUM)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
.025 0.64 REF (TYP)
C
.121 3.07
"A"
.051 1.30
C
"R"
(SEE NOTE)
.019±.020 0.48±0.51
.035 0.89 REF
.325 8.26
REF
C
"T"
PPP-38-X-X-XX
.275 6.99
.095 2.41
C "S"
(SEE NOTE)
.1575±.0050 4.000±0.127
FIG 5
FIG 4
(NOT AVAILABLE WITH -P, -A OR -K OPTIONS)
NOTE: "R" = USED MEASURED DIMENSION (REF)
"S" = {("R" - .1575[4.000])/2} ±.020[0.51]
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 4:1
DESCRIPTION:
DWG. NO.
BY:
CLP-1XX-XX-XXX-D-XX
PURVIS
01/31/1994
SHEET 2 OF 3
REVISION CW
PACKAGING
(SEE NOTE 4, SHEET 1)
PT-CLX-002-D
PT-CLX-001-D
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 4:1
DESCRIPTION:
DWG. NO.
BY:
CLP-1XX-XX-XXX-D-XX
PURVIS
01/31/1994
SHEET 3 OF 3
CLP-120-02-S-D-BE-A-P 价格&库存
很抱歉,暂时无法提供与“CLP-120-02-S-D-BE-A-P”相匹配的价格&库存,您可以联系我们找货
