ERM8-070-02.0-S-DV-TR
    SAMTEC(申泰)
    CONN HDR 140POS SMD GOLD
ERM8-070-02.0-S-DV-TR 数据手册
RUGGED HIGH-SPEED STRIPS FEATURES & BENEFITS Edge Rate® rugged high-speed connector strips are designed for high-speed, high cycle applications, and enabled by Samtec's signal integrity-optimized Edge Rate® contact system. • Up to 1.5 mm contact wipe for a reliable connection • 20 to 200 positions • Choice of 0.50 mm, 0.635 mm or 0.80 mm pitch • 0.50 mm pitch system offers up to 40% PCB space savings vs. 0.80 mm pitch • 0.635 mm pitch system with extremely slim 2.5 mm body width • Rugged latching, extended guide posts and 360° shielding Signal integrity-optimized Edge Rate® contact system reduces broadside coupling • Severe Environment Testing qualified (ERM8/ERF8); aligns with MIL-DTL-55302. Visit samtec.com/set EDGE RATE® STACK HEIGHT FLEXIBILITY (shown in mm) 5 7 8 ERM6/ ERF6 10 9 12 11 ERM5/ERF5 13 14 15 16 18 17 ERM8/ERF8 Rugged 360º shielding reduces EMI KEY SPECIFICATIONS SERIES PITCH ERM5 / ERF5 0.50 mm ERM6 / ERF6 0.635 mm ERM8 / ERF8 0.80 mm F-224 INSULATOR MATERIAL TERMINAL MATERIAL Phosphor Bronze or BeCu (ERM5), BeCu (ERF5) Black LCP Copper Alloy Phosphor Bronze or BeCu (ERM8), BeCu (ERF8) PLATING Au or Sn over 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE -55 °C to +125 °C CURRENT RATING VOLTAGE RATING 1.5 A 190 VAC 1.4 A 155 VAC 1.4 A 225 VAC LEAD-FREE SOLDERABLE Yes samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • SHIELDED HIGH-SPEED HEADERS & SOCKETS TYPE ERM8 = Shielded Terminal ERF8 = Shielded Socket - POSITIONS PER ROW –010, –020, –025, –030 - - LEAD STYLE –02.0 = 2 mm (ERM8 with –S only) –05.0 = 5 mm (ERF8 with –S & ERM8 with –EGPS & –DSS only) –07.0 = 7 mm (ERF8 with –EGPS only) –09.0 - - PLATING OPTION DV –L - OPTIONS "X"R –S = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –TR = Shield (Lead Styles: ERM8 –02.0 only; ERF8 –05.0 only) = Tape & Reel –FR –EGPS = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) = Extended Guide Post Shield (Lead Styles: ERM8 –05.0 & -09.0 only; ERF8 –07.0 only) –S –DSS = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail = Differential Pair with Extended Guide Post Shield (ERM8 only, with –05.0 & -09.0 Lead Styles, –10 & –025 Positions only) –K = 9 mm (ERM8 with –EGPS & –DSS only) = Polyimide Film Pick & Place Pad (–02.0 Lead Style N/A) –P = Pick & Place Pad (ERM8 –02.0 & -05.0 Lead Styles only) ERM8-S Board Mates: See "Mated Height" Chart 01 LEAD STYLE No. of Positions x (0.80) .0315 + (6.00) .236 A B –05.0 (9.87) .389 (10.81) .425 -09.0 (13.87) .546 (14.81) .583 (7.20) .283 (Note: ERF8-S does not mate with ERM8-EGPS) 02 (7.18) .283 A B (5.97) .235 –S OPTION –EGPS OR –DSS OPTION View complete specifications at: samtec.com?ERM8 MATED HEIGHTS 7 mm ERF8-S ERM8-02.0-S to ERF8-05.0-S Board Mates: See "Mated Height" Chart (Note: ERM8-EGPS does not mate with ERF8-S) 9 mm 12 mm 16 mm ERM8-05.0-EGPS ERM8-09.0-EGPS ERM8-02.0-S to to to ERF8-07.0-EGPS ERF8-07.0-EGPS ERF8-07.0-EGPS A 01 (6.80) .268 02 LEAD STYLE –05.0 Notes: Severe Environment Testing qualified; aligns with MIL-DTL-55302. Visit samtec.com/set Some lengths, styles and options are non-standard, non-returnable. –07.0 B B (-S) (-EGPS) (5.90) .232 N/A N/A (7.42) .292 (7.20) .283 B POSITIONS PER ROW A –010 (18.00) .71 –020 (26.00) 1.02 –025 (30.00) 1.18 –030 (34.00) 1.34 –S OPTION View complete specifications at: samtec.com?ERF8 samtec.com/EdgeRate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
物料型号:F-224
器件简介:Edge Rate®高速连接器条适用于高速、高周期应用,采用Samtec的信号完整性优化的Edge Rate®接触系统。
引脚分配:提供20至200个位置,有0.50mm、0.635mm或0.80mm的间距选择。
参数特性: - 0.50mm间距系统比0.80mm间距节省高达40%的PCB空间。 - 0.635mm间距系统具有极薄的2.5mm体宽。 - 坚固的锁定机制、延长的导向柱和360°屏蔽。 - 通过严酷环境测试(ERM8/ERF8),符合MIL-DTL-55302标准。
功能详解: - 信号完整性优化的Edge Rate®接触系统减少侧面耦合。 - 提供15mm的堆叠高度灵活性。 - 360°屏蔽减少电磁干扰(EMI)。
应用信息:适用于需要高速数据传输和高可靠性连接的应用。
封装信息: - 系列:ERMS/ERFS、ERM6/ERF6、ERM8/ERF8 - 间距:0.50mm、0.635mm、0.80mm - 绝缘体材料:黑色LCP - 端子材料:磷青铜或铍铜 - 镀层:金或锡覆盖50微米镍 - 工作温度范围:-55°C至+125°C - 电流额定值:1.5A(ERMS/ERFS系列)、1.4A(ERM6/ERF6和ERM8/ERF8系列) - 电压额定值:190VAC(ERMS/ERFS系列)、155VAC(ERM6/ERF6系列)、225VAC(ERM8/ERF8系列) - 无铅可焊性:是
ERM8-070-02.0-S-DV-TR 价格&库存
很抱歉,暂时无法提供与“ERM8-070-02.0-S-DV-TR”相匹配的价格&库存,您可以联系我们找货
  • 375+59.08242375+7.58748
