FFSD-13-S-10.00-01-N-RW
    SAMTEC(申泰)
    .050 X .050 C.L. FEMALE IDC ASSE
FFSD-13-S-10.00-01-N-RW 数据手册
REVISION AO DO NOT SCALE FROM THIS PRINT NOTES: 1. HIDDEN LINES ARE USED TO SHOW POLARIZATION FFSD-XX-X-XX.XX-01-X-X-XXX WHEN USING -N OPTION. C 2. REPRESENTS A CRITICAL DIMENSION. 3. FFSD CABLE ASSEMBLIES ARE LEAD FREE. 4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED FOR SHORTS AND OPENS. C 5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 630V. No OF POSITIONS 6. STRAIN RELIEF TO WITHSTAND 5LB[22N] STRAIGHT PULL. -02 THRU -25 7. NOTE DELETED. (PER ROW) 8. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND END ASSEMBLY PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF CABLE THICKNESS -S: SINGLE END ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR. -D: DOUBLE END 9. REFERENCE FFSD-XX-XX-X-N-XXX FOR CONNECTOR ASSEMBLY DIMENSIONS AND ITS REQUIREMENTS. ASSEMBLY LENGTH 10. COLORED WIRE MUST MATCH FIRST POSITION INDICATOR -D"XX", -R, -M & -O OPTION: 2.00[50.8] MINIMUM ON THE FIRST CONNECTOR FOR ALL OPTIONS WITH THE ALL OTHER OPTION: 1.00[25.4] MINIMUM EXCEPTION OF -RW. 11. FOR LENGTHS LESS THAN 12.5", TOLERANCE SHALL BE +/-.125, LEAD STYLE ALL OTHER LENGTHS SHALL BE +/-1%. PLATING OPTIONS - LEAVE BLANK FOR STANDARD, USE C-67-L -S: USE C-67-S -F: USE C-67-F C XX.XX[XX.X x 25.4]±1% (SEE NOTE 8 & 11) OPTION -RW: REVERSE WIRING (NOT AVAILABLE WITH -RN1 OR -RN2) -D"XX": DAISY CHAIN (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) -R: REVERSED (NOT AVAILABLE WITH -M OR -O) (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) -RN1: REVERSE POLARIZATION NOTCH (NOT AVAILABLE WITH -RW OR -RN2) -RN2: REVERSE POLARIZATION NOTCH (NOT AVAILABLE WITH -RW OR -RN1) -M: MIDDLE REVERSE (NOT AVAILABLE WITH -R OR -O) (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) -O: OUTSIDE REVERSE (NOT AVAILABLE WITH -R OR -M) (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) -SR: STRAIN RELIEF (NOT AVAILABLE WITH -O, -M, -R, OR -DXX) (SOLD AS ASSEMBLIES ONLY) STANDARD POLARIZATION NOTCH -N: POLARIZATION NOTCH (NOT AVAILABLE IN -02 THRU -04) (LEAVE BLANK FOR -02, -03, -04) .075 1.91 REF C .120 3.05 REF C (No OF POS x .050[1.27]) + .165[4.19] REF .006 0.15 MAX +.006 .010 0.25 MAX CABLE OVERHANG (SEE NOTE 8) 2 RED WIRE TO SIDE OF FIRST POS INDICATOR -N OPTION +0.15 C .200 - .003 5.08 - 0.08 -RN1 OPTION XX.XX[XX.X x 25.4]±1% (SEE NOTE 8 & 11) -N OPTION 1 .040 1.02 REF FIG 2 (FFSD-10-S-XX.XX-01-X-N SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) NOTCH DENOTES FIRST POSITION -RN2 OPTION FIG 1 (FFSD-10-D-XX.XX-01-X-N SHOWN) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: RED WIRE TO OPPOSITE SIDE OF FIRST POS. INDICATOR DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: FIG 11 (FFSD-10-X-XX.XX-01-X-N-RW SHOWN) F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATORS: PBT UL94V-0, COLOR: BLACK CONTACT: BeCu WIRE: 30 AWG, 7/38, TINNED, STRANDED WITH GRAY PVC INSULATOR PLATING: .000010 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 1 OF 4 REVISION AO FIG 3 (FFSD-10-D-XX.XX-01-X-N-RN1 SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) FIRST POSITION INDICATOR FIRST CONNECTOR FIRST POSITION INDICATOR FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") MIDDLE CONNECTOR REVERSED WHEN DAISY CHAINED OUTSIDE CONNECTOR REVERSED WHEN DAISY CHAINED FIG 5 FIG 4 FIRST POSITION INDICATOR SECOND CONNECTOR (FFSD-10-D-XX.XX-01-X-N-DXX-M SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) (FFSD-10-D-XX.XX-01-X-N-DXX-O SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) (FFSD-10-D-XX.XX-01-X-N-RN2 SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) FIRST CONNECTOR FIRST POSITION INDICATOR FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIRST POSITION INDICATOR FIG 7 (FFSD-10-D-XX.XX-01-X-N-DXX SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) SECOND CONECTOR NOTE: -RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY ( NOT AVAILABLE WITH -R OPTION) -RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY (NOT AVAILABLE WITH -R OPTION) (REVERSE NOTCH NOT AVAILABLE WITH -RW OR ANY DAISY CHAIN OPTIONS) BOTH CONNECTORS REVERSED WHEN DAISY CHAINED * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, FIG 6 (FFSD-10-D-XX.XX-01-X-N-DXX-R SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (NOT AVAILABLE WITH -RN1 OR -RN2 OPTION) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 2 OF 4 REVISION AO IN-PROCESS 1 (2-15 POS -SR ONLY FOR DOUBLE END) (No OF POS x .050[1.27]) C + .315[8.00] REF XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18] 4 IN-PROCESS 2 .039 0.99 (2-15 POS -SR ONLY FOR DOUBLE END) .335±.010 8.51±0.25 3 C (XX.XX[XX.XX x 25.4] .13[3.2] FIG 9 (XX.XX[XX.XX x 25.4] ± .13[3.2]) STRAIN RELIEF OPTION (POS 2-15 ONLY) (FFSD-10-D-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) C IN-PROCESS 1 (16-25 POS -SR ONLY FOR DOUBLE END) XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18] IN-PROCESS 2 (16-25 POS -SR ONLY FOR DOUBLE END) XX.XX[XX.XX x 25.4] +0.05 .0228+-.002 .000 0.58 0.00 .13[3.2] C DETAIL 'A' SCALE 8 : 1 IN-PROCESS 3 (16-25 POS -SR ONLY FOR DOUBLE END) 6 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, 'A' MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS 5 WRITTEN CONSENT OF SAMTEC, INC. FIG 10 STRAIN RELIEF OPTION (POS 16-25 ONLY) (FFSD-25-D-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 9, DIFFERENT AS SHOWN) SCALE 1 : 1 DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 3 OF 4 REVISION AO IN-PROCESS 1 IN-PROCESS 1 (FFSD-XX-S-XX.XX-01-X-N-RW ONLY) (16-25 POS -SR ONLY FOR SINGLE END) (XX.XX[XX.XX x 25.4] ± .125[3.18]) XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18] IN-PROCESS 2 (16-25 POS -SR ONLY FOR SINGLE END) IN-PROCESS 1 (2-15 POS -SR ONLY FOR SINGLE END) XX.XX[XX.XX x 25.4] .125[3.18] C XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18] IN-PROCESS 3 (16-25 POS -SR ONLY FOR SINGLE END) IN-PROCESS 2 (2-15 POS -SR ONLY FOR SINGLE END) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, (XX.XX[XX.XX x 25.4] ± .125[3.18]) MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, C INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 4 OF 4
1. 物料型号:文档中提到了多种型号,例如FFSD-XX-01-X-N-XX、CB-XX-30-7/38-025-GR等,但具体的型号需要根据上下文确定。
2. 器件简介:文档没有直接提供器件的简介,但提到了器件的一些特性,如FFSD电缆组件是无铅的,所有组装件需要进行100%的电气测试以检查短路和断路,以及100%的高压测试。
3. 引脚分配:文档中没有明确指出具体的引脚分配,但提到了一些与引脚相关的选项,如-RW(反向布线)、-RN1和-RN2(反向极性缺口)等。
4. 参数特性:文档提供了一些参数特性,例如电缆的最小长度、颜色编码的电线必须与第一个连接器上的第一个位置指示器匹配等。
5. 功能详解:文档中没有直接的功能详解,但通过各种选项和注释可以推断出一些功能特性,例如极性缺口的存在、电缆的拉伸缓解等。
6. 应用信息:文档中没有直接的应用信息,但提到了连接器组装的尺寸和要求,以及一些特定的组装选项。
7. 封装信息:文档提供了一些封装信息,如绝缘体材料为PBT UL94V-0,颜色为黑色,接触材料为BeCu,电线规格为30 AWG,7/38,镀锡,带有灰色PVC绝缘体等。
FFSD-13-S-10.00-01-N-RW 价格&库存
很抱歉,暂时无法提供与“FFSD-13-S-10.00-01-N-RW”相匹配的价格&库存,您可以联系我们找货
