FMPS-08-01-L-S-RA-LC
    SAMTEC(申泰)
    8 位置 插座,母型刀片插口 连接器 焊接 0.197"(5.00mm) 通孔,直角
FMPS-08-01-L-S-RA-LC 数据手册
F-224 WEB FMPT–06–01–L–S–V FMPS–06–01–L–S–RA–SD (5.00 mm) .1969" FMPS, FMPT SERIES “HINGING” 30 A POWER HEADER & SOCKET SPECIFICATIONS For complete specifications see www.samtec.com?FMPS or www.samtec.com?FMPT Insulator Material: Black LCP Terminal Material: Copper Alloy Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 525 VAC/742 VDC Standard Creepage: FMPS: (3.67 mm) .144" FMPT: (6.53 mm) .257" Standard Clearance: (2.71 mm) .106" RoHS Compliant: Yes Lead–Free Solderable: Yes PLATING OPTION 01 02, 04, 06, 08 RA S = Screw Down (Not Available with –LC) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –LC –T NUMBER OF POSITIONS –02 (14.17) .558 –04 –06 –08 (5.00) .1969 TYP (9.27) .365 (1.87) .074 A (22.63) .891 (32.63) 1.285 (42.63) 1.678 (52.63) 2.072 B (16.28) .641 (26.28) 1.035 (36.28) 1.428 (46.28) 1.822 C (15.63) .615 (25.63) 1.009 (35.63) 1.403 (45.63) 1.796 CREEPAGE AND CLEARANCE (2.72) .107 (2.54) .100 (0.41) .016 –SD OPTION (6 POSITIONS SHOWN) For complete scope of recognitions see www.samtec.com/quality = Locking Clip (Manual placement required) (Not Available with –SD) = Matte Tin A B ALSO AVAILABLE C –LC OPTION (2 POSITIONS SHOWN) (MOQ Required) • Other sizes NO. OF POSITIONS FMPT 01 02, 04, 06, 08 PLATING OPTION Note: Some sizes, styles and options are non-standard, non-returnable. (1.00) .039 DIA NUMBER OF POSITIONS (2.54) .100 (0.41) .016 –LC –T (5.00) .1969 TYP –02 (6.30) .248 (0.79) .031 B OPTION = Locking Clip (Manual placement required) = Matte Tin (9.40) .370 (1.87) .074 V = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail A Ideal for blind mating applications. S –L (Standard sizes) (4.24) .167 Selectively loading contacts achieves customer specific creepage and clearance requirements. Contact asp@samtec.com FILE NO. E111594 APPLICATION OPTION –SD –L (Standard sizes) FMPT/FMPS CURRENT RATING PINS (PER CONTACT) 1 26.7 A 2 22.9 A 3 19.1 A 4 17.6 A 8 15.8 A –L PLATING RECOGNITIONS NO. OF POSITIONS FMPS (2.72) .107 (2.54) .100 –04 (1.42) .056 –06 (1.42) .056 –LC –08 A B (22.63) (16.53) .891 .651 (32.63) (26.53) 1.285 1.044 (42.63) (36.53) 1.678 1.438 (52.63) (46.53) 2.072 1.832 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
物料型号:FMPT-06-01-L-S-V 和 FMPS-06-01-L-S-RA-SD
器件简介:这些是“HINGING” 30A电源插座和连接器,具有高电流承载能力。
引脚分配:文档提供了不同引脚数量的尺寸和电流额定值,例如1引脚26.7A,2引脚22.9A等。
参数特性:绝缘体材料为黑色LCP,端子材料为铜合金。镀层选项包括锡或金,覆盖50微米(1.27微米)镍。工作温度范围为-55°C至+105°C(锡),或-55°C至+125°C(金)。电压等级为525 VAC/742 VDC。
功能详解:文档详细描述了不同引脚配置的电流承载能力,以及如何通过选择性加载接触点来满足特定的爬电和间隙要求。
应用信息:这些产品适用于需要高电流承载能力的电源连接,如服务器、存储设备等。
封装信息:提供了不同引脚数量的详细尺寸,包括B(宽度)、C(高度)等。
FMPS-08-01-L-S-RA-LC 价格&库存
很抱歉,暂时无法提供与“FMPS-08-01-L-S-RA-LC”相匹配的价格&库存,您可以联系我们找货
