FSI-110-03-G-D-E-AD-SD 数据手册
LOW PROFILE AND
ELEVATED ONE-PIECE
(1.00 mm) .0394" PITCH • FSI SERIES
SPECIFICATIONS
Insulator Material:
Liquid Crystal Polymer
Contact Material:
BeCu
Current Rating:
2.8 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Plating:
Au over 50 µ" (1.27 µm) Ni
FSI
-1
BODY
HEIGHT
10, 20,
30, 50
–03
–06
5VVMWVZP[PVUZ_
ROW
OPTION
INSERT
OPTION
–S
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
(Not
available
with
–03 body
height)
–E
Leave blank
for no
Alignment Pin
–AD
= Alignment Pin
Top & Bottom
–D
= Double
Row
–WT
= Weld Tab
(Available
with –S row
option & –06
& –10 body
height only)
–K
–M
= 2.00 mm
x 0.40 mm
screw thread
–P
= Plastic Pick
& Place Pad
(5.08 mm)
.200" x
(12.45 mm)
.490"
(50 not
available
with –E)
(Not available
with –S
row option
or –03 body
height)
5VVMWVZP[PVUZ_
—06 & —10
Contact Detail
OTHER
OPTION
= Polyimide
Film Pick &
Place Pad
(50 position
with threaded
insert option
only)
Insert Option (10, 20 & 30 pins/row)
–TR
= Tape &
Reel
.050"
(1.27 mm)
Pitch
–FR
—03—AD
Shown
Short Version
See www.samtec.com?SIBF
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact
Samtec for
quantity
breaks)
Insert Option (50 pins/row)
Double Row Version —03, —06, —10
(71.20) 2.803
ALSO AVAILABLE
MOQ Required
BODY
HEIGHT
No alignment pin
Top side alignment pin
Bottom side alignment pin
Other platings
(No. of positions x
(1.00) .03937) +
(5.00).197
(4.60)
.181
F-224
= #2-56 x
1/16" screw
thread
See www.samtec.com?SEI
Some lengths, styles and
options are non-standard,
non-returnable.
ALIGNMENT
OPTION
Low
Profile
Notes:
Applications requiring 40-50
positions without threaded
inserts, please contact
Samtec Interconnect
Processing Group.
Leave blank
for Short
Version
(No screw
down
inserts or
holes)
= Single
Row
(Available
with 5, 10
& 20 pins
with –AD
alignment
pin)
–L
–10
= 10 mm
(Short
Version)
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (05-30)
(0.15 mm) .006" max (50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
Compression Board:
Gold Pads required
= 10 µ"
(0.25 µm)
Gold
(–03 only)
= 6 mm
05,
10, 20,
30, 50
PLATING
OPTION
–G
= 3 mm
(Insert/Screw
Option)
PROCESSING
OTHER
SOLUTIONS
PINS
PER ROW
A
B
(8.76) .345
–03
(3.00) .118
–06
(6.00) .236 (9.02) .355
–10
(10.00) .394 (9.02) .355
(5.30)
.209
—03, —06 & —10
Contact Detail
A
A
Short Version
—03—AD Shown
Single Row Version —03, —06, —10
–WT Option
(—06 & —10 Body only)
(No. of positions x (1.00) .03937)
+ (14.70) .579
samtec.com?FSI
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FSI-110-03-G-D-E-AD-SD 价格&库存
很抱歉,暂时无法提供与“FSI-110-03-G-D-E-AD-SD”相匹配的价格&库存,您可以联系我们找货
