HCSD-12-D-04.00-01-N-G
    SAMTEC(申泰)
    SAMTEC - HCSD-12-D-04.00-01-N-G - Ribbon Cable, IDC Receptacle to IDC Receptacle, 24 Ways, 4 ", 102 ...
HCSD-12-D-04.00-01-N-G 数据手册
F-215 (Rev 07DCE15) HCMD–10–S–03.00–01 (2.54 mm) .100" IDC SOCKET & TERMINAL CABLE Mates with: TSW, MTSW, TST, EW, BST, ZST, MTLW, TSM, EJH-02 (HCSD only) TYPE STRIP SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?HCSD or www.samtec.com?HCSS NO. PINS PER ROW S –05, –08, –10, –12, –13, –15, –17, –20, –25, –36 = Single D HCSD, HCSS Insulator Material: Black Liquid Crystal Polymer Flammability Rating: UL 94V-O Insulation Resistance: 5000 MΩ Temperature Range: -20°C to +105°C (Rainbow Cable) -40°C to +105°C (Gray Cable) Withstanding Voltage: 1000 VRMS @ 60 Hz Contact: Phosphor Bronze Plating: 10µ" (0.25 µm) Au on contact area, 150µ" (3.81 µm) Sn on balance over 50µ" (1.27 µm) Ni. Contact Resistance: 10 mΩ Lead Size Range: .024" (0.61 mm) SQ to .026" (0.66 mm) SQ Lead Insertion Depth: .185" (4.70 mm) to .250" (6.35 mm) Insertion Force: 6 oz (1.67 N) average with .025" (0.64 mm) SQ probe Withdrawal Force: 3 oz (0.83 N) average with .025" (0.64 mm) SQ probe Wire: 28 AWG 7/36 stranded Tinned Copper RoHS Compliant: Yes ROW OPTION = Double (Color coded cable N/A for 36 pins/row. See –G option.) –“XX.XX” Assembled Length in INCHES (±1/8") 2 inches minimum HCM –S = Single End (3.30) .130 No. of Positions x .100 (2.54) + .180 (4.57) (5.08) .200 (7.87) .310 REF (0.51) .020 (0.64) .025 SQ TYP (2.54) .100 LEAD STYLE –01 –02 SPECIFICATIONS Socket or Male Plug on one end A Single (HCMS) –D = Double End (2.54) .100 Double (HCMD) A (3.05) .120 (5.84) .230 HCS = Socket Strip HCMD, HCMS Note: IDC assemblies are non-standard, non-returnable. ASSEMBLED LENGTH = Assembled Length = Male Strip For complete specifications and recommended PCB layouts see www.samtec.com?HCMD or www.samtec.com?HCMS Insulator Material: Black Liquid Crystal Polymer Flammability Rating: UL 94V-O Insulation Resistance: 5000 MΩ Temperature Range: -20°C to +105°C (Rainbow Cable) -40°C to +105°C (Gray Cable) Withstanding Voltage: 1000 VRMS @ 60 Hz Terminal: Phosphor Bronze Plating: Sn over 50µ" (1.27 µm) Ni Wire: 28 AWG 7/36 stranded Tinned Copper RoHS Compliant: Yes END ASSEMBLY Socket or Male Plug on each end No. of Positions x .100 (2.54) + .180 (4.57) (3.30) .130 (5.08) .200 –T = Transfer End (9.53) .375 REF (2.54) .100 (0.76) .030 SQ. TYP. Single (HCSS) (2.54) .100 Double (HCSD) Male Plug on one end with socket on other. Begin part number with HCM. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. HCSS–15–S–03.00–01–G HCSD–10–S–03.00–01–T–G HCMD, HCMS, HCSD, HCSS SERIES LEAD STYLE PLATING OPTION OTHER OPTIONS NOTCH POLARIZATION –N = Notch Polarization –01 = HCSS/HCSD or (3.05 mm) .120" tail for HCMS/HCMD = 10µ" (0.25 µm) Gold on contact area or tail, Tin on balance (Standard on HCSS & HCSD. Leave blank) –02 –T = (5.84 mm) .230" tail HCMS/HCMD only 01 (3.81) .150 Required for HCSS and HCSD. (Not available on HCMS or HCMD, unless Transfer, then only the socket is polarized.) = Tin (Standard on HCMS & HCMD. Leave blank) – P “XX” –S “XX” – ST “X” = Position Polarization 02 01 03 02 04 –R = Daisy Chain Single = Stripped & Tinned (50.80) 2.00 min. Specify Suffix from table. All dimensions are ± 1/16" (1,59 mm). Not available in 28 positions and higher. 04 02 (1.27) .050 –S = Reversed “XX” ± 1 /8" (3.18) Single Row Connectors 01 Outer Most (End of Assembly) 03 (101.60) 4.00 minimum 7 Single –ST8 –ST4 –ST2 –ST3 Double Specify “XX” as position. For Double the same position will be polarized on both ends. (Not available on HCM, unless Transfer, then only the socket is polarized) When mating double row connector with two single row connectors, the outer most single will be connected to Conductor #1 and the inside single to Conductor #2. 6 1 /8" (3.18) 1 /4" (6.35) 1 /2" (12.70) 3 /8" (9.53) 3 –M = Middle Reversed – D “XX” = Daisy Chain, Double – B “XX” = Breakout (50.80) 2.00 min. Specify “XX” as number of conductors to be broken out. “XX” ± 1 /8" (3.18) Requires –SXX, –WXX or –DXX Double Row Strips 7 1 –G “XX” Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side. = Gray Cable (101.60) 4.00 minimum (127.00) 5.00 max. (50.80) 2.00 min. 6 = Wiring Reversed Daisy Chain, Single = Reversed Wiring Same as –S “XX” except outer strip connected to conductor #2 and inside strip connected to conductor #1. #1 wire opposite position #1 2 –O = Outside Reversed –W “XX” 4 –RW Standard cable is color coded. Specify –G for Gray cable with one red edge. Outer Most (End of Assembly) 5 6 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. Requires –SXX, –WXX or –DXX 7
HCSD-12-D-04.00-01-N-G 价格&库存
很抱歉,暂时无法提供与“HCSD-12-D-04.00-01-N-G”相匹配的价格&库存,您可以联系我们找货
  • 1+108.254471+13.89028
  • 10+99.0568010+12.71011
  • 25+88.8854625+11.40501
  • 50+77.4762850+9.94109
  • 100+71.64004100+9.19223
  • 500+66.01412500+8.47036
库存:2
