HLE-109-02-L-DV-K-TR 数据手册
F-215
HLE–130–02–F–DV
HLE–110–02–L–DV
HLE–116–02–L–DV–K
(2,54 mm) .100"
HLE SERIES
COST-EFFECTIVE RELIABLE SOCKET
Mates With:
TSW, MTSW, DW,
EW, ZW, TLW, TSM,
MTLW, HW
HLE
NO. PINS
1 PER
ROW
PLATING
OPTION
02
TAIL
OPTION
DV
OTHER
OPTION
SPECIFICATIONS
–BE
For complete specifications
and recommended PCB layouts
see www.samtec.com?HLE
= Bottom Entry
(N/A with –TE)
–F
= Gold flash on contact,
Matte Tin on tail
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
BeCu
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Current Rating (HLE/TSM):
4.1 A per pin
(1 pin powered per row)
Voltage Rating:
400 VAC
Operating Temp Range:
-55°C to +125°C
Insertion Depth:
(1,78 mm) .070" to
(3,43 mm) .135", pass-through,
or (2,59 mm) .102" min
plus board thickness for
bottom entry
Insertion Force:
(Single contact only)
2 oz (0,56 N) avg.
Withdrawal Force:
1.6 oz (0,44 N) avg.
RoHS Compliant:
Yes
Leave blank for
Surface Mount
–L
= 10µ" (0,25 µm) Gold on contact,
Matte Tin on tail
–A
= Alignment Pin
(4 positions min.)
Metal or plastic at
Samtec discretion
(N/A with -TE,
-PE & -LC)
(3,66)
.144
(6,60)
.260
(1,27)
.050
(Requires –BE for Bottom Entry)
(1,60)
.063
DIA
02 thru 50
–LC
–TE
= Through-Hole
Top Entry
= Locking Clip
(2 positions min.)
(N/A with -A)
(Manual placement
required)
(1,27)
.050
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (02-20)
(0,15 mm) .006" max (21-50)
(3,05)
.120
(2,54)
.100
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
–K
(2,54)
.100
No. of Positions x (2,54) .100
02
(5,08)
.200
(2,54)
.100
–PE
= Through-hole
Pass-Through Entry
01
FILE NO: 090871_0_000
(1,42)
.056
= (6,50 mm) .256"
DIA Polyimide
Film Pick &
Place Pad
(3 positions min.)
Not available
with –TE or
–PE tail option
–P
ALSO AVAILABLE
(3,51)
.138
(MOQ Required)
• Other platings
Contact Samtec.
= Metal Pick &
Place Pad
(3 positions min.)
(0,51)
.020
(2,30)
.090
–PE
–TE
(7,11) .280
x
(5,71) .225
(7,62)
.300
(3,86)
.152
–TR
= Tape & Reel
Packaging
(29 positions max.)
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
HLE-109-02-L-DV-K-TR 价格&库存
很抱歉,暂时无法提供与“HLE-109-02-L-DV-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 825+17.95136825+2.31737
