AW-30-03-G-D-122-122-P-TR
    SAMTEC(申泰)
    排针
AW-30-03-G-D-122-122-P-TR 数据手册
SMT MICRO BOARD STACKER (0.80 mm) .0315" PITCH • AW SERIES AW AW Mates: CLE SPECIFICATIONS Insulator Material: Top: Black LCP Bottom: Natural LCP Terminal Material: Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C - NO. PINS PER ROW 05 thru 90 - 03 - PLATING OPTION -D- –G STACKER HEIGHT –“XXX” = 10 µ" (0.25 µm) Gold = Stacker Height (in inches) (3.09 mm) .122" to (5.84 mm) .230" Example: –175 = (4.45 mm) .175" PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (05-40) (0.15 mm) .006" max (41-90)* *(.004" stencil solution may be available; contact ipg@samtec.com) - POST HEIGHT - –“XXX” = Post Height (in inches) (1.91 mm) .075" minimum Example: –075 = (1.91 mm) .075" OTHER OPTION –ES = End Shroud 11 pins/row min. (–075 Post Height only) –EP = End Shroud with Guide Post (–075 Post Height only) 11 pins/row min. –A = Alignment Pin (4 positions min.) (Available for board stacks between (4.06 mm) .160" to (5.84 mm) .230") (Metal or plastic at Samtec discretion.) No. of positions x (0.80) .0315 (3.05) .120 –P = Pick & Place Pad (8 positions min.) –TR = Tape & Reel (84 positions max.) OPTIONS –EP OPTION –P OPTION POST HEIGHT (7.75) .305 MAX OVERALL LENGTH STACKER HEIGHT (3.09) .122 to (5.84) .230 (1.91) .075 MIN (1.40) .055 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (84 positions max.) (1.70) .067 (4.57) .180 –ES OPTION (4.17) .164 (3.56) .140 Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. Some lengths, styles and options are non-standard, non-returnable. –EP OPTION –ES OPTION –P OPTION samtec.com?AW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
1. 物料型号:AW系列,具体型号示例包括-075和-175。 2. 器件简介:FLEX STACK SMT MICRO BOARD STACKER,具有0.80mm(0.0315")的间距。 3. 引脚分配:每排至少11个引脚,适用于-075 Post Height。 4. 参数特性: - 端子材料:磷青铜,表面镀金,厚度为10微英寸(0.25微米)。 - 绝缘体材料:顶部为黑色LCP,底部为天然色LCP。 - 操作温度范围:-55°C至+125°C。 - 焊盘可焊性:符合无铅标准。 5. 功能详解:提供了不同高度的堆叠器选项,包括05至90的堆叠高度,以及不同的后高度选项。 6. 应用信息:推荐在有金或选择性金镀连接器的应用中使用机械板间隔器以增加机械稳定性。 7. 封装信息:提供了不同选项,如对齐销、拾取放置垫、胶带和卷轴(Tape & Reel)以及全卷轴胶带和卷轴(Full Reel Tape & Reel)。
AW-30-03-G-D-122-122-P-TR 价格&库存
很抱歉,暂时无法提供与“AW-30-03-G-D-122-122-P-TR”相匹配的价格&库存,您可以联系我们找货
