CLE-134-01-G-DV-A
CLE-134-01-G-DV-A
    SAMTEC(申泰)
    .8MM MICRO SOCKET STRIPS
CLE-134-01-G-DV-A 数据手册
SMT MICRO HEADER & SOCKET (0.80 mm) .0315" PITCH • FTE/CLE SERIES FTE FTE Mates: CLE -1 CLE NO. PINS PER ROW - 05 thru 90 Mates: FTE, AW - TAIL OPTION - –DV = 10 µ" (0.25 µm) Gold on post, Gold flash on balance - FLEX SHROUD OPTIONS = Dual Vertical Style –01 –DV only (11 pins/row minimum) –DH = End Shroud –A –EC = End Shroud with Locking Clips (Manual placement required) (3.05) .120 –K = (2.50 mm) .098" DIA Polyimide Film Pick & Place Pad (–DH only) –EP = End Shroud with Guide Posts No. of positions x (0.80) .0315 + Z OPTION Z LEAD STYLE A –ES (1.57) .062 –01 (1.90) .075 –EC (4.11) .162 –02 (4.45) .175 –EP (5.51) .217 –03 (3.05) .120 –P = Plastic Pick & Place Pad (8 positions minimum) –DV only –TR –P OPTION A A (1.38) .055 (1.70) .067 (Shrouded options removed for clarity) CLE -1 NO. PINS PER ROW (4.57) .180 –DH OPTION - 01 - 04 thru 90 PLATING OPTION - –ES OPTION DV –G OTHER OPTION = Alignment Pin (5 positions minimum) Metal or plastic at Samtec discretion (–DV only) –ES = Dual Horizontal (50 positions maximum) No. of positions x (0.80) .0315 PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity (FTE): -DV: (0.10 mm) .004" max -DH: (0.10 mm) .004" max (05-25) (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) SMT Lead Coplanarity (CLE): (0.10 mm) .004" max (04-65) (0.15 mm) .006" max (66-90)* *(.004" stencil solution may be available; contact ipg@samtec.com) PLATING OPTION –G Specify LEAD STYLE from chart SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Current Rating (FTE/CLE): 2.7 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth (CLE): Top Entry = (1.73 mm) .068" to (3.18 mm) .125" with (0.38 mm) .015" wipe, or pass-through Bottom Entry = (3.23 mm) .127" minimum plus board thickness Max Cycles (CLE): 100 with 10 µ" (0.25 µm) Au - LEAD STYLE - = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) OPTIONS –A = 10 µ" (0.25 µm) Gold = Alignment Pin (4 positions minimum) Metal or plastic at Samtec discretion. No. of positions x (0.80) .0315 + (0.38) .015 –K = (3.50 mm) .138" DIA Polyimide film Pick & Place Pad (8 positions minimum) (3.18) .125 –P = Metal Pick & Place Pad (8 positions minimum) (3.12) .123 Note: Some lengths, styles and options are non-standard, non-returnable. F-224 –TR (3.30) .130 = Tape & Reel (4.83) .190 –P OPTION –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) samtec.com?FTE or samtec.com?CLE Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
CLE-134-01-G-DV-A 价格&库存
很抱歉,暂时无法提供与“CLE-134-01-G-DV-A”相匹配的价格&库存,您可以联系我们找货
