ESQT-150-03-F-Q-310
ESQT-150-03-F-Q-310
    SAMTEC(申泰)
    ELEVATED 2MM SOCKETS
ESQT-150-03-F-Q-310 数据手册
ESQT–125–02–L–Q–465 F-218 (Rev 10OCT17) ESQT–115–02–GF–D–600 ESQT–125–03–M–Q–310 (2.00 mm) .0787" ESQT SERIES FLEXIBLE ELEVATED SOCKET STRIPS SPECIFICATIONS For complete specifications see www.samtec.com?ESQT Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (ESQT/TMMH): 4.5 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (2.62 mm) .103" to (5.03 mm) .198" with (0.38 mm) .015" wipe Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes Lead–Free Solderable: Yes, for -S, -D & -Q (Wave only for -T, -5 & -6) RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality High-retention contacts Board Mates: TMMH, TMM, MTMM, MMT, TW, LTMM, ZLTMM, ESQT, PTT, TSH, TMMS Cable Mates: TCMD APPLICATION SPECIFIC OPTION: NOTEBOOK 2.5" DISK DRIVE INTERFACE (2.00 mm) .0787" pitch Call for part number. ESQT 1 NO. PINS PER ROW LEAD STYLE Specify LEAD STYLE from chart FILE NO. E111594 02 thru 50 Note: This Series is non-standard, non-returnable. Surface Mount 300 No. of positions x (2.00) .0787 + (0.30) .012 OTHER OPTION –F = Single Row –S –“XXX” –“XXX” –L = Double Row = Gold flash on contact, Matte Tin on tail (2.00) No. of .0787 rows TYP x (2.00) .0787 295 –D –T = Triple Row –Q = 20 µ" (0.51 µm) Gold on contact, Matte Tin on tail 06 See CLT Series. 01 See SMM Series. = Quad Row –GF See SQW Series. (1.52) .060 PC/104-PlusTM Sockets (0.50) .020 SQ A BODY HEIGHT = Body Height (in inches) (7.87 mm) .310" minimum for –S, –D, –Q (9.53 mm) .375" minimum for –T, –5, –6 = Five Row –6 = Six Row TAIL (1.27) .050 MIN (2.00) .0787 Paste In Hole (PIH) processing. Contact Samtec ASP Group. (Not recommended for stack through applications) MAX MAX BODY TAIL HEIGHT (13.72) (20.32) – 02 (21.59) .850 .540 .800 (11.63) (3.76) (10.36) –03 .458 .148 .408 LEAD STYLE A Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM = Polarized Position (Indicate position number) OTHER SOLUTIONS –5 = 15 µ" (0.38 µm) Gold on contact, Gold flash on tail (Recommended for self-nesting) (–02 lead style only) (6.35) .250 RightAngle See ESQT-368 and PTHF Series. BODY HEIGHT –M Low Profile High Reliability ROW OPTION = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail Other Solutions See SQW and TLE Series. PLATING OPTION All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ESQT-150-03-F-Q-310
1. 物料型号:文档列出了几种型号,例如ESQT-125-02-L-Q-465和ESQT-115-02-GF-D-600。 2. 器件简介:ESQT系列是柔性提升插座条,具有0.0787英寸(2.00毫米)的间距。 3. 引脚分配:文档提到了不同型号的引脚分配,但没有提供具体的引脚图。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 接触材料:磷青铜 - 镀层:锡或金,覆盖50微英寸(1.27微米)的镍 - 电流额定值:每针4.5安培(2针供电) - 工作温度范围:-55°C至+125°C - 插入深度:2.62毫米至5.03毫米,带0.38毫米的擦拭 - 最大周期:100次,10微英寸(0.25微米)的金 - 符合RoHS标准:是 - 无铅可焊性:高保留接触 5. 功能详解:文档提到了不同的应用选项,如笔记本电脑2.5英寸硬盘驱动器接口。 6. 应用信息:文档提供了一些应用选项,如笔记本电脑硬盘驱动器接口,但未提供详细的应用场景。 7. 封装信息:文档提供了不同型号的封装尺寸和引脚样式的详细信息。
ESQT-150-03-F-Q-310 价格&库存
很抱歉,暂时无法提供与“ESQT-150-03-F-Q-310”相匹配的价格&库存,您可以联系我们找货
