ET60T-000-0-00-D03-L-R1-S 数据手册
ET60T–D04–5–03–A04–L–R1–S
F-217 (Rev 13FEB17)
ET60T–D04–3–08–A04–S–R1–S
(5.50 mm) .217"(PWR) (2.54 mm) .100"(SIG)
ET60T SERIES
RIGHT-ANGLE POWER/SIGNAL HEADER
Mates with:
ET60S
POWER
POSITIONS (LEFT)
ET60T
ROWS
SIGNAL POSITIONS
–0
–02, –04, –06,
–08, –10, –12
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?ET60T
–AXX*
= No Signal
= AC Power Positions
(–02, –03, –04, –05, –06)
Insulator Material:
Black LCP
Terminal Material:
Signal: Phosphor Bronze
Power: Copper Alloy
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Power: 60 A max per blade
(2 pins powered @ 95 °C;
30 °C temperature rise)
Signal: 2.8 A max
(6 pins powered @ 95 °C;
Operating Temp Range:
-40 °C to +105 °C
Voltage Rating:
250 V max
RoHS Compliant:
Yes
= 3 Rows
–3
–DXX
–5*
= DC Power Positions
(–02, –03, –04, –05, –06, 07, 08, 09, 10)
= 5 Rows
= 5 Rows
–00
–SXX*
= No Signal
= Split Power
–000
Note:
–AXX*, –SXX*, –5* & –T* are Preliminary
= No Power
B
(2.54) .100
A
C
(10.00)
.394
PROCESSING
A + B + C + (26.98) 1.062
(2.84)
.112
Lead-Free Solderable:
Yes
For complete scope of
recognitions see
www.samtec.com/quality
(0.64) .025 SQ
A + B + C + (33.98) 1.338
(7.50)
.295
(1.27)
.050
(5.50)
.217
RECOGNITIONS
(10.00)
.394
(2.50)
.098
(29.25)
1.152
(9.40)
.370
FILE NO. E111594
(5.00)
.197
ALSO AVAILABLE
(5.17)
.204
(3.00)
.118
(MOQ Required)
• Increased creepage
and clearance with the
removal of contacts
• Hot swapable
Contact Samtec.
–01, –02, –03, –04,
–05, –06, –07, –08
= 3 Rows
(4.81)
.189
(3.00) .118
ET60T–D03–3–08–A03–X–R1–S
(2.00)
.079
A
(5.50)
.217
(24.90
.980
(3.33)
.1131
DIA
D
C
(10.00)
.394
A + D + C + (27.21) 1.071
(0.64) .025 SQ
A + D + C + (34.21 ) 1.347
(5.50)
.217
(1.27) .050
Notes:
Some lengths, styles and
options are non-standard,
non-returnable.
EXTreme Ten60Power™
is a trademark of Molex
Incorporated and is dual
sourced by Molex®
(24.45)
.963
(5.50) .217
(5.64) .222
(4.57) .180
ET60T–D04–5–03–A04–X–R1–S
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ET60T–D04–3–08–A04–L–R1–T
F-217 (Rev 13FEB17)
ET60T SERIES
ET60T–D04–3–08–A00–T–R1–S
POWER
POSITIONS (RIGHT)
–AXX*
–DXX
–SXX*
PLATING
GUIDE
POST
TAIL
–R1
–L
= Right-angle
Through-hole
(Use with
(1.60 mm) .062"
thick card)
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
(Not available for 5 rows)
–S
= 30 µ" (0.76 µm) Gold on contact,
Matte Tin on tail
OPTION
–S
–H
= Side
Guide Post
= Hot Swap
(Leave blank for
no Hot Swap
–T*
= Top
Guide Post
= Split Power
–000
Note:
= No Power
A
POWER
POWER
POSITIONS POSITIONS
DC
(LEFT)
(RIGHT) POWER
–02
–02
–03
–03
–04
–04
–05
–05
–06
–06
–07
–07
–08
–08
–09
–09
–10
–10
C
AC
POWER
A + D + C + (11.47) .452
(5.50) **(7.50)
.217
.295
(11.00) **(15.00)
.433
.591
(16.50) **(22.50)
.650
.886
**(22.00) **(30.00)
.866
1.181
**(27.50) **(37.50)
1.083
1.476
**(33.00) N/A
1.299
**(38.50) N/A
1.516
**(44.00) N/A
1.732
(49.50)
N/A
1.949
(2.00)
.079
D
(14.98)
.590
A
C
A + D + C + (19.71) .776
(0.64) .025 SQ
ET60T–D04–5–03–A04–X–R1–T
C
A
**Not Released
SIGNAL
POSITIONS
PER ROW
(3 Row)
B
*–02
(2.54)
.100
*–04
(7.62)
.300
*–06
(12.70)
.500
(17.78)
.700
(22.86)
.900
(27.94)
1.100
–08
*–10
*–12
*Not Tooled
**Not Released
SIGNAL
POSITIONS
PER ROW
(5 Row)
D
**–01
N/A
**–02
(2.00)
.079
(4.00)
.157
(6.00)
.236
(8.00)
.315
(10.00)
.394
(12.00)
.472
(14.00)
.551
**–03
*–04
**–05
**–06
**–07
**–08
A + C + (21.50) .846
A + C + (28.50) 1.122
(1.27)
.050
(5.50)
.217
(3.33)
.1131
DIA
(5.50)
.217
(4.50) .177
(5.50)
.217
ET60T–D04–0–00–A04–X–R1–S
WWW.SAMTEC.COM
(29.25)
1.152
