FJ-15-R-12.00-4 .
FJ-15-R-12.00-4 .
    SAMTEC(申泰)
    SAMTEC - FJ-15-R-12.00-4 . - FFC / FPC Cable, 15 Core, 1 mm, Opposite Sided Contacts, 12 ", 305 mm
FJ-15-R-12.00-4 . 数据手册
F-218 (Rev 12FEB18) FJ–20–D–06.50–4 FJ–05–D–04.80–4 (1.00 mm) .0394" FJ SERIES FLAT FLEXIBLE CABLE (FFC) JUMPER Mates with: FC1, ZF1 SPECIFICATIONS Double or reversed ended For complete specifications see www.samtec.com?FJ Conductor: Tin Plated Copper Conductor Resistance: 300 W/km max Insulation Resistance: 10 MW/km min (conductor-to-conductor) Dielectric Test: 400 VAC during 1 minute (conductor-to-conductor) Temperature Rating: -30 °C to +80 °C Voltage Rating: 300 VAC RoHS Compliant: Yes 4.00 mm .157" Variety of pin counts FJ NO. OF POSITIONS –05, –10, –15, –20, –25, –30 STYLE LENGTH –D Length in inches = Double End –03.00 –R = Reversed End = (76.2 mm) 3.00" –06.00 = (152.4 mm) 6.00" (0.70) .028 LENGTH –12.00 = (304.8 mm) 12.00" –24.00 = (609.6 mm) 24.00" (No. of positions x (1.00) .03937) + (1.00) .03937 ALSO AVAILABLE (MOQ Required) • Other Lengths Contact Samtec. (Standard Lengths) (1.00) .03937 (4.00) .157 (0.33) .013 (0.52) .021 –D Style (5.26) .207 (0.30) (0.10) .012 .004 Notes: Stiffener color will be blue or black at Samtec’s discretion. Some sizes, styles and options are non-standard, non-returnable. –R Style Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. STRIP LENGTH –4 = (4.00 mm) .157" (Required for mating with FC1 & ZF1)
FJ-15-R-12.00-4 . 价格&库存
很抱歉,暂时无法提供与“FJ-15-R-12.00-4 .”相匹配的价格&库存,您可以联系我们找货
