FTMH-134-02-L-DV
FTMH-134-02-L-DV
    SAMTEC(申泰)
    CONN HEADER SMD 68POS 1MM
FTMH-134-02-L-DV 数据手册
F-215 FTM–125–02–L–DV FTMH–116–02–L–DV–P FTMH–111–02–F–DV–ES–A (1,00 mm) .0394" SMT MICRO TERMINAL STRIPS SPECIFICATIONS Mates with: CLM, MLE Optional Pick & Place pads For complete specifications and recommended PCB layouts see www.samtec.com?FTMH or www.samtec.com?FTM Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Current Rating (FTMH/CLM): 2.8 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C Plating: Sn or Au over 50µ" (1,27 µm) Ni RoHS Compliant: Yes Processing: Surface Mount Lead-Free Solderable: Yes -DV Lead Coplanarity: (0,10 mm) .004" max -DH Lead Coplanarity: (0,10 mm) .004" max (05-25) (0,15 mm) .006" max (26-50) TYPE STRIP RECOGNITIONS FTMH = 05 thru 50 FTMH = SMT Micro ALSO AVAILABLE = Micro Low Profile (MOQ Required) 02 No. of positions x (1,00) .03937 100 OPTION B – ES (1,57) .062 (4,06) .160 (5,49) .216 – EC – EP FTMH –F = Gold flash on post, Matte Tin on tail –L –03 = (1,65 mm) .065" Post (Mates with CLM) = 10µ" (0,25 µm) Gold on post, Matte Tin on tail FTMH (3,17) .125 01 –02 = (1,91 mm) .075" Post (Mates with MLE) FTM = 02 thru 50 (unshrouded) = 05 thru 46 (shrouded) FTM PLATING OPTION LEAD STYLE NO. PINS PER ROW 1 For complete scope of recognitions see www.samtec.com/quality • End shrouds with board locks • Molded end shrouds for 05 through 08 positions • Other platings Contact Samtec. Low profile (1,79 mm) .071" (1,91) .075 DIA (3,10) .122 (4,32) .170 (3,84) .151 99 (1,22) .048 FTMH No. of positions x (1,00) .03937 + B LEAD STYLE – 02 – 03 A (1,00) .03937 (0,30) .012 SQ TYP –ES OPTION – EP OPTION –EC OPTION (1,91) .075 (1,65) .065 A (3,18) .125 X (5,08) .200 (5,00) .197 A (1,80) .071 (1,49) .059 Shrouded option removed for clarity (5,21) .205 –DV OPTION (0,69) .027 (2,59) .102 –DH OPTION (0,64) .025 DIA –A OPTION Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (3,18) .125 –P OPTION FTMH–128–03–L–DV–EP FTMH–122–02–F–DV–EC FTMH–135–02–F–DH FTMH–120–02–L–DV FTM–125–02–L–DV FTMH, FTM SERIES Low Profile (1,27 mm) .050" Surface mount Shrouded and alignment pin options available Flex Shroud options available ROW OPTION (FTMH-DV only with 9 pins/row minimum) –DV = Dual Vertical –ES –DH –EC = End Shroud with Locking Clip (Manual placement required) 02 49 –P = Plastic Pick & Place Pad (–DV only) (6 positions minimum FTMH) (7 positions minimum FTM) FTM FTM No. of positions x (1,00) .03937 + C 46 OPTION C –S (7,00) .276 (4,00) .157 – SA (3,23) (4,44) .127 .175 –TR FTM LEAD STYLE – 02 – 03 (0,97) .038 –K = (2,50 mm) .098" DIA Polyimide Film Pick & Place Pad (FTMH–DH only) = End Shroud with Alignment Pins (05 through 46 positions) .125 01 –S –SA = End Shroud with Guide Post (3,18) (Use only when mating with CLM) 01 –A = Alignment Pin (3 positions minimum) Metal or plastic at Samtec discretion (FTMH–DV only) –EP 50 (5,21) .205 (FTM only) = End Shroud (05 positions minimum). Molded or press fit shroud at Samtec’s discretion (See assembly print at www.samtec.com?FTM for dimensions) = End Shroud = Dual Horizontal (FTMH only) 02 OTHER OPTIONS FLEX SHROUD OPTIONS = Tape & Reel D (1,91) .075 (1,65) .065 (2,54) .100 x (5,08) .200 45 (0,30) .012 SQ TYP D No of positions x (1,00) .03937 Shrouded options removed for clarity (1,27) .050 –DV OPTION (1,40) (3,56) .055 .140 (1,00) .039 DIA (3,56) .140 (3,18) .125 –S OPTION (1,50) .059 –SA OPTION WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –P OPTION
FTMH-134-02-L-DV 价格&库存
很抱歉,暂时无法提供与“FTMH-134-02-L-DV”相匹配的价格&库存,您可以联系我们找货
FTMH-134-02-L-DV
  • 17+88.7830317+11.52548
