FTS-118-03-L-D-P
FTS-118-03-L-D-P
    SAMTEC(申泰)
    .050 X .050 C.L. LOW PROFILE TER
FTS-118-03-L-D-P 数据手册
F-215 (Rev 30SEP15) FTS–110–02–F–DV FTS–111–02–L–DV–SA FTS–122–01–F–DV FTS–116–02–L–D (1.27 mm) .050" FTS SERIES MICRO LOW PROFILE TERMINAL STRIPS SPECIFICATIONS Mates with socket strips or IDC cable Mates with: FFSD, CLP, FLE Low profile (1.27 mm) .050" For complete specifications and recommended PCB layouts see www.samtec.com?FTS OPTIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Operating Temp Range: -55°C to +125°C Plating: Sn or Au over 50µ" (1.27 µm) Ni Current Rating: 3.3 A per pin (1 pin powered per row) RoHS Compliant: Yes Lead–Free Solderable: Yes SMT Lead Coplanarity: .004" (0.10 mm) max –S OPTION –SA OPTION Surface mount or through-hole –P OPTION Shrouded and alignment pin options available Micro pitch .050" x .050" (1.27 mm x 1.27 mm) –TR OPTION Impedance matched for high speed applications RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FTS 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION ROW OPTION OTHER OPTION (–D & –DV only) ALSO AVAILABLE –01 –F –D (MOQ Required) = .120" (3.05 mm) Post (Mates with FFSD) = Gold flash on post, Matte Tin on tail = Double Through-hole –02 –L = Double Vertical SMT = 10µ" (0.25 µm) Gold on post, Matte Tin on tail = Single Through-hole 02 thru 50 • Alignment pin Contact Samtec. (except –S & –SA option = 05 thru 46) (5.84) .230 No. of positions x .050 (1.27) 02 50 (1.27) .050 (3.42) .135 49 01 (2.16) .085 50 01 No of positions x .050 (1.27) + .325 (8.25) = –SA No of positions x .050 (1.27) + .200 (5.08) = – S 02 46 (4.70) .185 (0.86) .034 Note: Some lengths, styles and options are non-standard, non-returnable. (3.48) .137 01 –DV –S –S = End Shroud (05 thru 46 positions. Style -02 & -03 only) –SV = Single Vertical SMT –03 (1.27) .050 (4.57) .180 = .075" (1.91 mm) Post (Mates with FLE) –SA = End Shroud with Alignment Pin (05 thru 46 positions. Style -02 & -03 only) = .065" (1.65 mm) Post (Mates with CLP) –P = Pick & Place Pad (04 positions minimum) (3.56) .140 (1.40) .055 –SA OPTION LEAD A STYLE – 01 (3.05) .120 – 02 (1.91) .075 – 03 (1.65) .065 (1.59) .0625 (1.27) .050 DIA (3.30) .130 X (5.08) .200 (4.06) .160 –P OPTION –TR = Tape & Reel (-DV only) (Required callout for positions 2 thru 4) 45 (0.41) .016 SQ (2.29) .090 (Shrouded options removed for clarity) –S (1.27) .050 A –SV (3.56) .140 A –DV –D WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –S OPTION
FTS-118-03-L-D-P
- 物料型号:FTS–110–02–F–DV, FTS–111–02–L–DV–SA, FTS–116–02–L–D, FTS–122–01–F–DV - 器件简介:这些端子排是微型低压端子排,具有低轮廓设计,适用于高速应用,兼容RoHS标准。 - 引脚分配:端子排的引脚分配根据型号不同而有所变化,但文档中未提供具体的引脚分配图。 - 参数特性:包括绝缘材料为黑色液晶聚合物,端子材料为磷青铜,工作温度范围为-55°C至+125°C,镀层为锡或金,电流额定值为每针3.3A(每行1针供电)。 - 功能详解:端子排适用于表面贴装或通孔安装,有带状和对齐销选项。 - 应用信息:端子排适用于与FFSD、CLP、FLE插座条或IDC电缆配合使用。 - 封装信息:提供了不同长度、样式和选项的端子排,包括端部护罩和对齐销选项。
FTS-118-03-L-D-P 价格&库存
很抱歉,暂时无法提供与“FTS-118-03-L-D-P”相匹配的价格&库存,您可以联系我们找货
