FW-03-03-L-D-305-065-A 数据手册
MICRO BOARD
STACKER
4
G b p s
(1.27 mm) .050" PITCH • FW SERIES
FW
FW
Board Mates:
CLP, FLE
Cable Mates:
FFSD
NO. OF PINS
PER ROW
02 thru 50
Specify
LEAD
STYLE
from
chart
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-30)
(0.15 mm) .006" max (31-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
LEAD
STYLE
LEAD
STYLE
STACKER
HEIGHT
STACKER
+ POST
–03
(5.46) to (8.51)
.215
.335
(7.11) to (10.16)
.280
.400
–05
(8.64) to (15.49)
.340
.610
(10.29) to (17.15)
.405
.675
PLATING
OPTION
-D-
STACKER
HEIGHT
POST
HEIGHT
–F
–“XXX”
–“XXX”
–L
Example:
–250
= (6.35 mm)
.250"
(1.65 mm)
.065"
minimum
= Gold flash
on post,
Matte Tin
on tail
= Stacker
Height
(in inches)
= 10 µ"
(0.25 µm)
Gold
on post,
Matte Tin
on tail
= Post
Height
(in inches)
Example:
–065
= (1.65 mm)
.065"
–G
= 10 µ"
(0.25 µm)
Gold
on post,
Gold flash
on tail
No. of positions x (1.27) .050
SURFACE MOUNT
—P
—ES
POST
HEIGHT
(1.65)
.065 MIN
–P
–TR
STACKER
HEIGHT
9.91 mm)
.390"
(2.51)
.099
*Processing conditions will affect mated height.
—EP
—A
(3.42)
.135
ALSO AVAILABLE
Notes:
For added mechanical stability,
Samtec recommends
mechanical board spacers
be used in applications
with gold or selective gold
plated connectors. Contact
ipg@samtec.com for more
information.
POST
HEIGHT
(1.65)
.065 MIN
THROUGH-HOLE
(2.51)
.099
(20.32)
.800
MAX
OVERALL
LENGTH
STACKER
HEIGHT
(5.08)
.200
MIN
B
This Series is non-standard,
non-returnable.
= Tape & Reel
(Max overall height
= Post+Stacker
Height+Pad+
Alignment Pin =
(17.78) .700")
(SMT only)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(SMT only)
Smaller stack heights
(MOQ Required)
–EP
= End Shroud
with Guide Post
(–075 post
height only.
Mate only
with CLP.)
(5.46 mm) .215"
to (15.49 mm) .610"
stacker height only
9 pins/row min.
= Pick & Place Pad
(5 positions min.)
(SMT only)
CLP
LEAD MATED
STYLE HEIGHT*
8.13 mm)
FW-XX-03-X-X-233-065
.329"
FW-XX-03-X-X-303-065
–ES
= End Shroud
(–075 post
height only.
Mate only
with CLP)
(5.46 mm) .215"
to (15.49 mm) .610"
stacker height only
9 pins/row min.
= Alignment Pin
(3 positions min.)
(5.46 mm) .215" to
(15.75 mm) .620"
stacker height only
(SMT only)
FW
LEAD STYLE
–02
OPTION
–A
(3.42)
.135
MATED HEIGHT
—EP
—ES
LEAD
STYLE
TAIL
(B)
–01
(1.14) .045
–02
(1.91) .075
–04
(2.29) .090
samtec.com?FW-SM or samtec.com?FW-TH
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
FW-03-03-L-D-305-065-A 价格&库存
很抱歉,暂时无法提供与“FW-03-03-L-D-305-065-A”相匹配的价格&库存,您可以联系我们找货
