HCSS-13-D-12.00-01-G 数据手册
F-215 (Rev 07DCE15)
HCMD–10–S–03.00–01
(2.54 mm) .100"
IDC SOCKET & TERMINAL CABLE
Mates with:
TSW, MTSW, TST, EW,
BST, ZST, MTLW, TSM,
EJH-02 (HCSD only)
TYPE
STRIP
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?HCSD
or www.samtec.com?HCSS
NO. PINS
PER ROW
S
–05, –08,
–10, –12,
–13, –15,
–17, –20,
–25, –36
= Single
D
HCSD, HCSS
Insulator Material:
Black Liquid Crystal Polymer
Flammability Rating:
UL 94V-O
Insulation Resistance:
5000 MΩ
Temperature Range:
-20°C to +105°C
(Rainbow Cable)
-40°C to +105°C (Gray Cable)
Withstanding Voltage:
1000 VRMS @ 60 Hz
Contact: Phosphor Bronze
Plating: 10µ" (0.25 µm) Au on
contact area, 150µ" (3.81 µm)
Sn on balance over
50µ" (1.27 µm) Ni.
Contact Resistance:
10 mΩ
Lead Size Range:
.024" (0.61 mm) SQ to
.026" (0.66 mm) SQ
Lead Insertion Depth:
.185" (4.70 mm) to
.250" (6.35 mm)
Insertion Force:
6 oz (1.67 N) average with
.025" (0.64 mm) SQ probe
Withdrawal Force:
3 oz (0.83 N) average with
Wire: 28 AWG 7/36 stranded
Tinned Copper
RoHS Compliant: Yes
ROW
OPTION
= Double
(Color coded cable N/A
for 36 pins/row.
See –G option.)
–“XX.XX”
Assembled Length in
INCHES (±1/8")
2 inches minimum
HCM
–S = Single End
(3.30)
.130
No. of Positions x .100 (2.54)
+ .180 (4.57)
(5.08)
.200
(7.87)
.310
REF
(0.51)
.020
(0.64)
.025
SQ
TYP
(2.54)
.100
LEAD
STYLE
–01
–02
SPECIFICATIONS
Socket or Male Plug on one end
A
Single
(HCMS)
–D = Double End
(2.54)
.100
Double
(HCMD)
A
(3.05) .120
(5.84) .230
HCS
= Socket Strip
HCMD, HCMS
Note:
IDC assemblies are
non-standard, non-returnable.
ASSEMBLED
LENGTH
= Assembled Length
= Male Strip
see www.samtec.com?HCMD
or www.samtec.com?HCMS
Insulator Material:
UL 94V-O
5000 MΩ
Temperature Range:
-20°C to +105°C
(Rainbow Cable)
1000 VRMS @ 60 Hz
Terminal: Phosphor Bronze
Plating:
Sn over 50µ" (1.27 µm) Ni
Tinned Copper
RoHS Compliant: Yes
END
ASSEMBLY
Socket or Male Plug on each end
+ .180 (4.57)
(3.30)
.130
(5.08)
.200
–T = Transfer End
(9.53)
.375
REF
(2.54)
.100
(0.76)
.030
SQ.
TYP.
Single
(HCSS)
(2.54)
.100
Double
(HCSD)
Male Plug on one end with socket on other.
Begin part number with HCM.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
HCSS–15–S–03.00–01–G
HCSD–10–S–03.00–01–T–G
HCMD, HCMS, HCSD, HCSS SERIES
LEAD
STYLE
PLATING
OPTION
OTHER
OPTIONS
NOTCH
POLARIZATION
–N = Notch Polarization
–01
= HCSS/HCSD or
(3.05 mm) .120" tail for
HCMS/HCMD
= 10µ" (0.25 µm) Gold on contact area or tail,
Tin on balance
(Standard on HCSS & HCSD. Leave blank)
–02
–T
= (5.84 mm) .230" tail
HCMS/HCMD only
01
(3.81) .150
Required for HCSS and HCSD.
(Not available on HCMS or HCMD,
unless Transfer, then only the
socket is polarized.)
= Tin
(Standard on HCMS & HCMD. Leave blank)
– P “XX”
–S “XX”
– ST “X”
= Position Polarization
02
01
03
02
04
–R
= Daisy Chain Single
= Stripped & Tinned
(50.80)
2.00
min.
Specify Suffix from table. All
dimensions are ± 1/16" (1,59 mm). Not
available in 28 positions and higher.
04
02
(1.27)
.050
–S
= Reversed
“XX” ±
1
/8" (3.18)
Single Row
Connectors
01
Outer Most
(End of
Assembly)
03
(101.60)
4.00 minimum
7
Single
–ST8
–ST4
–ST2
–ST3
Double
Specify “XX” as position. For Double
the same position will be polarized
on both ends. (Not available on
HCM, unless Transfer, then only the
socket is polarized)
When mating double row connector
with two single row connectors, the
outer most single will be connected
to Conductor #1 and the inside single
to Conductor #2.
6
1
/8" (3.18)
1
/4" (6.35)
1
/2" (12.70)
3
/8" (9.53)
3
–M
= Middle Reversed
– D “XX”
= Daisy Chain, Double
– B “XX”
= Breakout
(50.80)
2.00
min.
Specify “XX” as number of
conductors to be broken out.
“XX” ±
1
/8" (3.18)
Requires –SXX, –WXX or –DXX
Double Row
Strips
7
1
–G
“XX”
Breakout starts with Number 1
lead indicated by brown wire or
red stripe. Shown on top side.
= Gray Cable
(101.60)
4.00 minimum
(127.00)
5.00 max.
(50.80)
2.00 min.
6
= Wiring Reversed
Daisy Chain, Single
= Reversed Wiring
Same as –S “XX” except outer strip
connected to conductor #2 and inside
strip connected to conductor #1.
#1 wire opposite position #1
2
–O
= Outside Reversed
–W “XX”
4
–RW
Standard cable is color coded. Specify
–G for Gray cable with one red edge.
Outer Most
(End of
Assembly)
5
6
WWW.SAMTEC.COM
7
HCSS-13-D-12.00-01-G 价格&库存
很抱歉,暂时无法提供与“HCSS-13-D-12.00-01-G”相匹配的价格&库存,您可以联系我们找货
