HPMC-102-01-T-D-02
HPMC-102-01-T-D-02
    SAMTEC(申泰)
HPMC-102-01-T-D-02 数据手册
F-215 SUPPLEMENT HPMC–124–04–L–D–04 HPFC–114–02–L–D–02 (2,54 mm) .100" HPFC, HPMC SERIES SIGNAL POWER COMBO SYSTEM SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?HPFC or www.samtec.com?HPMC Insulator Material: Black Liquid Crystal Polymer Signal Contact (HPFC): Phosphor Bronze Power Contact (HPFC): BeCu Terminal (HPMC): Phosphor Bronze (Signal & Power) Plating: Sn or Au over 50µ" (1,27 µm) Ni on signal pins; Sn over 50µ" (1,27 µm) Ni on power pins Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold Contact Resistance: 10 mΩ Insertion Depth: (3,68 mm) .145" to (8,26 mm) .325" Wiping Distance: (0,381 mm) .015" Insertion Force: (Single contact only) 5 oz (1,39 N) avg. (signal pins) 56 oz (15,57 N) avg. (power pins) Withdrawal Force: (Single contact only) 3 oz (0,83 N) avg. (signal pins) 52 oz (14,46 N) avg. (power pins) Voltage Rating: 850 VAC/1201 VDC RoHS Compliant: Yes HPFC 1 SIGNAL PIN PER ROW LEAD STYLE Mates with: HPMC SIGNAL PIN PLATING POWER PINS D –01 = Through -Hole 02 thru 24 –L –02 RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –T No. Signal positions x (2,54) .100 + (No. Power positions x (5,08) .200 + (2,54) .100) (5,08) .200 (1,12) .044 (1,27) .050 (3,12) .123 (7,11) .280 (2,26) .089 (0,51) (0,25) .020 x .010 = (6,50 mm) .256" DIA Polyimide film Pick & Place Pad (5 positions minimum) Style –02 (Signal End) (8,89) .350 (4,14) .163 (1,42) .056 (5,08) .200 (2,54) .100 –K (9,02) .355 (5,08) .200 (1,14) (0,46) .045 x .018 (9,02) .355 (6,86) .270 (2,46) .097 Style –01 (Power End) Style –01 (Signal End) Style –02 (Power End) • Locking clip option HPMC LEAD STYLE SIGNAL PIN PER ROW 1 Mates with: HPFC SIGNAL PIN PLATING Specify LEAD STYLE from chart 02 thru 24 (1,27) .050 –L (2,54) .100 (0,64) .025 SQ 02 thru 04 –T = Matte Tin (5,08) .200 (5,08) .200 (2,54) .100 POWER PINS D = 10µ" (0,25 µm) Gold on contact area, Matte Tin on tail (Power Pins = All Matte Tin) No. Signal positions x (2,54) .100 + (No. of Power positions x (5,08) .200 + (1,27) .050) (Add (0,76) .030 for –04 Power Pins) FILE NO: 090871_0_000 (5,08) .200 (1,14) .045 SQ (3,81) .150 Style –02 & –04 A Note: Some lengths, styles and options are non-standard, non-returnable. = Locking Clip (Manual placement required) (Not available with –01 lead style) = Matte Tin Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,15 mm) .006" max (02-20) (0,20 mm) .008" max (21-24) –LC 02 thru 04 = 10µ" (0,25 µm) Gold on contact area, Matte Tin on tail (Power Pins = All Matte Tin) = Surface Mount OPTION (2,54) .100 (2,54) .100 LEAD STYLE –01, –02 –03, –04 Style –01 & –03 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. A (5,84) .230 (8,13) .320
HPMC-102-01-T-D-02 价格&库存
很抱歉,暂时无法提供与“HPMC-102-01-T-D-02”相匹配的价格&库存,您可以联系我们找货
HPMC-102-01-T-D-02
  • 33+36.1689733+4.69817
