F-211
CLH–115–F–D–DE
CLH–112–F–D–PE
CLH–117–F–D–TE
(2,54mm) .100"
CLH SERIES
THROUGH-HOLE LOW PROFILE SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLH
Insulator Material:
Black Liquid
Crystal Polymer
Contact Material:
Phosphor Bronze
Operating Temp Range:
-65°C to +125°C with Gold
-65°C to +105°C with Tin
Plating:
Au or Sn over
50µ" (1,27µm) Ni
Contact Resistance:
10 mΩ max
Insertion Depth:
(2,67mm) .105" to
(3,43mm) .135"
plug from top, (3,18mm) .125"
min plus board thickness plug
from bottom
Insertion Force:
4.0oz (1,11N) average
Normal Force:
50 grams (0,48N)
Withdrawal Force:
1.1oz (0,31N) average
Max Cycles:
100 with 10µ" (0,25µm) Au
RoHS Compliant:
Yes
CLH
1
PLATING
OPTION
NO. PINS
PER ROW
D
Mates with:
TSW, MTSW, DW, EW,
ZW, TLW, TSM, MTLW
ENTRY
OPTION
–TE
= Top Entry
–F
= Pre-plated Gold flash on contact,
75µ" (1,91µm) Matte Tin on tail
–L
= Pre-plated 10µ" (0,25µm)
Gold on contact,
Note: Other Gold plating
options available.
Contact Samtec.
(3,05)
.120
(2,54)
.100
–DE
= Dual Entry
(Top or Bottom Entry)
Cannot be used with
plated through-holes
for bottom entry.
(3,05)
.120
Processing:
(3,81)
.150
02 thru 50
Lead–Free Solderable:
Yes
–PE
= Pass-Through
(Top or Bottom
Entry)
(2,30)
.090
No. of Positions x (2,54) .100
(7,62)
.300
(2,54)
.100
02
(2,54)
.100
(5,08)
.200
03
(3,56)
.140
(0,51)
.020
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
01
很抱歉,暂时无法提供与“CLH-109-F-D-PE”相匹配的价格&库存,您可以联系我们找货
