CLT-127-01-F-D
CLT-127-01-F-D
    SAMTEC(申泰)
    2MM SOCKET STRIPS
CLT-127-01-F-D 数据手册
REVISION AB CLT-1XX-XX-XX-D No OF POSITIONS -02 THRU -50 (PER ROW) DO NOT SCALE FROM THIS PRINT BODY SPECIFICATION -D: DOUBLE ROW LEAD STYLE -01: THROUGH HOLE (USE C-114-02-XX) (SEE NOTE 7) -03: THROUGH HOLE (USED C-114-03-XX) (NO OF POS x .0787 [2.00]) .005 [.13] (CUT TO POSITION) SEE NOTES 3 & 6) PLATING SPECIFICATION (VALUES GIVEN ARE IN MICRO-INCHES) -G: GOLD, 10 Au / 50 Ni MIN ON CONTACT, 3 Au / 50 Ni MIN ON TAIL. -S: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL. -F: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL. -SM: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL. -FM: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL. -L: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL. -LM: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL. (NO OF POS x .07874 [2.000]) -.07874 [2.000] REF .024 0.61 SQ REF "A" 02 CL 'C' "A" SEE NOTE 6 .07874 2.000 REF .1575 4.001 REF 01 'B' CL .0835 2.121 REF C "A" 2 MAX SWAY (EITHER DIRECTION) .002 [.051] MIN .119 3.02 REF .0200 0.508 X .0050[0.127] REF SECTION "A"-"A" SCALE 4 : 1 DETAIL 'B' SCALE 8 : 1 .0130±.0015 0.330±0.038 C CL C-114-XX-XX CLT-XX-D DETAIL 'C' SCALE 16 : 1 LEAD STYLE -01 CLT-111-XX-XX-D SHOWN NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: .5 LB. 3. PARTS TO BE SYMMETRICAL ABOUT CL . 4. WILL LOSE A POSITION FOR EVERY CUT MADE ON A SOCKET STRIP. 5. PACKAGE POSITIONS -04 THRU -50 IN TUBES, LAYER PACKAGE POSITION -02 THRU -03. 6. ENDWALL AFTER CUTTING: .0215 MIN. 7. C-114-22-XX CAN BE USED FOR C-114-02-XX. C-114-22-XX IS FOR AUTOMATED ASSEMBLY PROCESSES ONLY. 8. VOID CORES TO BE USED AS NEEDED TO CONTROL WARP, LOCATION TO BE AT VENDOR DISCRETION PT-1-24-01-62 TP-12 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 10 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: * PROPRIETARY NOTE DO NOT SCALE DRAWING F:\DWG\MISC\MKTG\CLT-1XX-XX-XX-D-MKT.SLDDRW SHEET SCALE: 4:1 PT-1-24-01-37 TP-24 PACKAGING VIEW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. INSULATOR: LCP, UL 94 VO, COLOR: BLACK CONTACT: PHOS BRONZE LEAD STYLE -03 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. 2MM LOW PROFILE SOCKET STRIP CLT-1XX-XX-XX-D BY: PURVIS 11-02-95 SHEET 1 OF 1
CLT-127-01-F-D 价格&库存
很抱歉,暂时无法提供与“CLT-127-01-F-D”相匹配的价格&库存,您可以联系我们找货
