ET60S-D04-3-08-D02-S-VP-S
    SAMTEC(申泰)
    ET60S SOCKET POWER ASSEMBLY
ET60S-D04-3-08-D02-S-VP-S 数据手册
EXTREME HIGH-POWER 60 A SYSTEMS FEATURES & BENEFITS • Up to 60 A per power blade (2 blades powered) • Low 10 mm profile (right-angle) for enhanced system airflow • Power only, or power/signal combinations • 3 or 5 signal rows in the same form factor • AC power, DC power, power/signal combinations and split power options available • Coplanar and perpendicular applications • Modules can be configured to accommodate most any design MAX • Rugged guide posts are standard; top design for board space savings • Press-fit (ET60S only) and hot swap (ET60T only) options available Standard Creepage* 3.02 mm Standard Clearance* 1.87 mm 60 A m p s *Selectively loading contacts achieves customer specific creepage and clearance requrements. Contact asp@samtec.com KEY SPECIFICATIONS (ET60T/ET60S) PITCH Power (5.50 mm) .217" (7.50 mm) .295" Signal (2.00 mm) .097" (5 row) (2.54 mm) .100" (3 row) INSULATOR MATERIAL TERMINAL MATERIAL PLATING OPERATING TEMP RANGE VOLTAGE RATING MATING CYCLES LEAD-FREE SOLDERABLE Black LCP Signal: Phosphor Bronze Power: Copper Alloy Au or Sn over 50 µ" (1.27 µm) Ni -40 °C to +105 °C 280 VAC 500 Yes Notes: Some lengths, styles and options are non-standard, non-returnable. *EXTreme Ten60Power™ is a trademark of Molex Incorporated and is dual sourced by Molex® F-224 samtec.com/extreme-ten60power Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 60 A SIGNAL/POWER COMBO SYSTEM SERIES - ET60T Terminal ET60S Socket POWER OPTION (R) –AXX = AC Power Positions (02 - 06) –DXX = DC Power Positions (02 - 10) –SXX* = Split Power –000 = No Power - ROWS –0 - SIGNAL POS. PER ROW –00 = No Signal = No Signal –3 = 3 Row only –5 –08 –01, –02, –03, –04, –05, –06, –07, –08 = 5 Row only - POWER OPTION (L) - –AXX = AC Power Positions (02 - 06) –DXX = DC Power Positions (02 - 10) –SXX* = Split Power PLATING - –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Not available for 5 rows) –S = 30 µ" (0.76 µm) Gold on contact, Matte tin on tail TAIL - GUIDE POST –R1 = Right-angle Through-hole (Use with (1.60 mm) .062" thick card) –VP = Vertical Press-fit (Not available with ET60T) (Required callout) –S = Side Guide Post –T* - OPTION (Leave blank for no hot swap) –H = Hot Swap (ET60T only) = Top Guide Post –V1 = Vertical Through-hole (Use with (1.60 mm) .062" thick card) (–0 and –3 Row only) (Not available with ET60T) –000 = No Power ET60T Board Mates: ET60S (29.25) 1.152 (77.21) 3.04 (10.00) .394 (77.21) 3.04 ET60T-D04-5-03-A04-X-R1-S SHOWN View complete specifications at: samtec.com?ET60T ET60S (18.00) .709 Board Mates: ET60T (77.21) 3.04 VERTICAL ET60S-D04-5-03-A04-X-VP-S SHOWN (77.21) 3.04 (10.00) .394 (25.22) .993 RIGHT-ANGLE ET60S-D04-5-03-A04-X-R1-S SHOWN View complete specifications at: samtec.com?ET60S samtec.com/extreme-ten60power Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
物料型号:ET60T/ET60S
器件简介:该系统提供高达每电源刀片60A的电流,具有10mm的低轮廓设计,增强了系统的空气流动。它支持纯电源或电源/信号组合,具有3或5行信号行,适用于交流电源、直流电源、电源/信号组合和分体电源选项。适用于共面和垂直应用,模块可以配置以适应大多数设计。
引脚分配:文档中提到了不同的配置选项,包括电源行和信号位置,以及不同的电源和信号引脚分配
参数特性:包括标准爬电距离3.02mm和标准间隙1.87mm。可以根据客户特定的爬电和间隙要求选择性加载接触点。
功能详解:提供了关于如何通过选择性加载接触点来实现客户特定的爬电和间隙要求的说明。
应用信息:该系统适用于需要高功率和信号传输的应用,如服务器、存储系统和电信设备。
封装信息:提供了不同配置的详细规格,包括间距、绝缘材料、端子材料、镀层、工作温度范围、电压等级、配对周期和无铅焊接能力。
ET60S-D04-3-08-D02-S-VP-S 价格&库存
很抱歉,暂时无法提供与“ET60S-D04-3-08-D02-S-VP-S”相匹配的价格&库存,您可以联系我们找货
