FHP-06-02-TM-S-LC-TR 数据手册
MAX
13.1
POWER HEADERS,
STACKERS & SOCKETS
A
m
p
s
(3.96 mm) .156" PITCH • FWJ, HFWJ, JW, FHP SERIES
FWJ, HFWJ, JW
Board Mates:
FHP
HFWJ
S
OTHER OPTIONS
Leave blank for Through-hole
= Matte Tin
–RA
= Right-angle (Style –02 & –04 only)
–VS
= Surface Mount Requires HFWJ
(2 pins/row minimum)
Style –05 not available.
–P
= Pick & Place Pad (3 Pos. min.)
(6.98 mm) .275" min. post height
(–VS only)
(3.18)
.125
No. of Positions x (3.96) .156
A
E
C
(6.35)
.250
LEAD
STYLE
A
–01
(11.43) .450
–02
(12.70) .500
–04
(20.55) .809
–05*
(3.81) .150
F
(2.54)
.100
B
D
B
C
D
E
(10.46) .412
(11.73).462
(4.45) .175
(8.13) .320
(2.54) .100
(3.96) .156
(19.10) .752
(3.96) .156
(12.07) .475
(4.45) .175
F
(13.56) .534 (4.95) .195
*FWJ Only
JW
NO. OF
PINS
- 04 -
02 thru 24
PROCESSING
POST
HEIGHT
(0.00)
.000
MIN
FHP
NO.
OF PINS
-S-
PLATING
OPTION
–T
STACK
HEIGHT
(27.43)
1.08 MAX
(6.35)
.250 MIN
= Stacker
Height
(in inches)
(0.13 mm) .005"
increments
LEAD STYLE
–01
PLATING
OPTION
–T
= Through-hole
= Matte Tin
–02
= Surface Mount
POST
HEIGHT
–“XXX”
= Post Height
(in inches)
-S-
(8.89)
.350
–01
Leave blank for
Through-hole
–VS
–P
= Pick & Place Pad
(3 Pos. min.)
post height (–VS only)
OTHER OPTIONS
–LC
= Locking
Clip
(Manual placement
required)
(–02 lead style only)
= (6.50 mm)
.256" DIA
Polyimide film
Pick & Place Pad
(2-4 positions
require –”X”R)
(5.08)
.200
OTHER
OPTIONS
= Surface Mount
–K
Example: –250
= (6.35 mm)
.250"
(31.75)
1.25
MAX
(3.18)
.125
(2.29)
.090
STACK
HEIGHT
–“XXX”
= Matte Tin
STACK
HEIGHT
(29.21) 1.15
MAX WITH
(0.00) .000 POST
(8.89) .350
MIN
02 thru 24
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
PLATING
OPTION
–T
Specifiy
LEAD
STYLE
from
chart
below
High Temp
Header
SPECIFICATIONS
LEAD
STYLE
01 thru 24
Standard
Header
Board Mates:
FWJ, HFWJ, JW
Lead–Free Solderable:
FWJ = No, Lead Wave only
HFWJ, JW, FHP = Yes
SMT Lead Coplanarity:
HFWJ, FWJ, JW = (0.20 mm)
.008" max (02-16)*
(0.25 mm) .010" max (17-24)*
FHP = (0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
NO. OF PINS
FWJ
FHP
Insulator Material:
FWJ = Black Glass
Filled Polyester
HFWJ, JW = Natural Liquid
Crystal Polymer
FHP = Black LCP
Terminal Material
(FWJ, HFWJ, JW):
Phosphor Bronze
Contact Material (FHP):
BeCu
Plating:
Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C
Voltage Rating:
600 VAC/845 VDC
Insertion Depth (FHP):
(3.57 mm) .140" to
(8.76 mm) .345" or
pass-through from top
Wiping Distance (FHP):
(0.38 mm) .015"
SERIES
–02
samtec.com?FWJ, samtec.com?HFWJ, samtec.com?JW or samtec.com?FHP
–TR
= Tape & Reel
Packaging
(Available on
positions 2-18)
-FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(Available on
positions 2-18)
(-02 lead style only)
F-224 WEB
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FHP-06-02-TM-S-LC-TR 价格&库存
很抱歉,暂时无法提供与“FHP-06-02-TM-S-LC-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 150+33.94876150+4.39005
