FW-10-03-L-D-255-075 数据手册
F-218 (Rev 10OCT17)
FW–20–05–F–D–610–065
FW–12–05–G–D–530–101
(1.27 mm) .050"
FW-SM SERIES
SMT MICRO BOARD STACKER
SPECIFICATIONS
Board Mates:
CLP, FLE
For complete specifications and
recommended PCB layouts
see www.samtec.com?FW-SM
Cable Mates:
FFSD
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
RoHS Compliant:
Yes
Low-profile or
skyscraper styles
APPLICATIONS
Variable
board spacing
FW
MATED
HEIGHT
CLP
PROCESSING
LEAD STYLE
FW
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-30)
(0.15 mm) .006" max (31-50)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
FW-XX-03-X-X-233-065
MATED
CLP HEIGHT*
– 02
(8.13)
.320
(9.91)
.390
FW-XX-03-X-X-303-065
(1.27 mm x 1.27 mm)
.050" x .050" micro pitch
*Processing conditions will affect mated height.
Surface
mount
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
NO. PINS
PER ROW
FW
Specify
LEAD
STYLE
from
chart
FILE NO. E111594
02 thru 50
ALSO AVAILABLE
(MOQ Required)
• Smaller stack heights
Contact Samtec.
LEAD STACKER
STYLE HEIGHT
LEAD
STYLE
(5.46) (8.51) (7.11) (10.16)
.215 to .335 .280 to .400
–05
(8.64) (15.49) (10.29) (17.15)
.340 to .610 .405 to .675
No. of positions x
(1.27) .050
STACKER
HEIGHT
–“XXX”
= Stacker
Height
(in inches)
= Gold flash on post,
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
Example:
–250
= (6.35 mm)
.250"
= 10 µ" (0.25 µm)
Gold on post,
Gold flash on tail
(1.27) .050
99
POST HEIGHT
(1.65) .065
MIN
This Series is non-standard,
non-returnable.
Example:
–065
= (1.65 mm)
.065"
(3.45)
.136
x
(5.08)
.200
(4.27)
.168
(4.06)
.160
(0.76)
.030
(1.91)
.075
DIA
(3.05)
.120
(2.92)
.115
–EP
(0.89)
.035
DIA
(0.86)
.034
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
–ES
= End Shroud
(–075 post height only.
Mate only with CLP)
(5.46 mm) .215" to
(15.49 mm) .610"
stacker height only
9 pins/row min.
–EP
= End Shroud
with Guide Post
Mate only with CLP.)
(5.46 mm) .215"
to (15.49 mm) .610"
stacker height only)
9 pins/row min.
= Alignment Pin
(3 positions min.)
(5.46 mm) .215" to
(15.75 mm) .620"
stacker height only
–P
–P
–A
OPTION
–A
–ES
STACKER
HEIGHT
(2.51)
.099
(1.65 mm)
.065"
minimum
(4.76)
.188
(0.41) .016 SQ
Notes:
For added mechanical stability,
Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
–“XXX”
100
(1.19)
.047
01
POST
HEIGHT
= Post Height
(in inches)
–G
(3.42)
.135
(1.27)
.050
D
–F
STACKER
+ POST
–03
02
PLATING
OPTION
= Pick & Place Pad
(5 positions min.)
–TR
= Tape & Reel
(Max overall height =
Post+Stacker Height+
Pad+Alignment Pin =
.700 (17.78))
FW-10-03-L-D-255-075 价格&库存
很抱歉,暂时无法提供与“FW-10-03-L-D-255-075”相匹配的价格&库存,您可以联系我们找货
