FW-15-02-G-D-550-065 数据手册
F-212
FW–20–02–F–D–200–140
FW–10–04–L–D–440–150
(1,27mm) .050"
FW SERIES
FW–40–02–F–D–425–075
THROUGH-HOLE MICRO BOARD STACKER
SPECIFICATIONS
Low profile or
skyscraper styles
Mates with:
CLP, FFSD, FLE
For complete specifications
see www.samtec.com?FW-TH
Insulator Material:
Black Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over 50µ"
(1,27µm) Ni
Current Rating:
1.75A @ 80°C ambient
Operating Temp Range:
-55°C to +125°C
RoHS Compliant:
Yes
Variable
board spacing
(1,27mm)
.050" pitch
ALSO
AVAILABLE
• Smaller stack heights.
Call Samtec.
NO. PINS
PER ROW
FW
Note: This Series is
non-standard, non-returnable.
02 thru 50
Processing:
Lead-Free Solderable:
Yes
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
–F
D
STACKER
HEIGHT
POST
HEIGHT
–“XXX”
–“XXX”
= Stacker
Height
(in inches)
= Gold flash on post,
Matte Tin on tail
–L
–G
100
02
(3,42)
.135
01
(1,27)
.050
= 10µ" (0,25µm)
Gold on post,
Gold flash on tail
99
(1,27) .050
(0,41)
.016
SQ
Example:
–065
= (1,65mm)
.065"
LEAD TAIL
STYLE (B)
–01
–02
(1,91)
.075
–04
(2,29)
.090
STACKER
HEIGHT
(5,08)
.200
MIN
B
(2,51)
.099
WWW.SAMTEC.COM
–ES
= End Shroud
(–075 post
height only.
Mates only
with CLP.)
(5,46mm)
.215" to
(15,49mm)
.610"
stacker
height only,
9 pins/row
minimum
–EP
(1,14)
.045
(4,76)
.188
(4,27)
.168
–ES
POST HEIGHT
(1,65) .065 MIN
(20,32)
.800
MAX
OVERALL
LENGTH
www.samtec.com
(1,65mm)
.065"
minimum
Example:
–250
= (6,35mm)
.250"
= 10µ" (0,25µm)
Gold on post,
Matte Tin on tail
No. of positions x
(1,27) .050
= Post
Height
(in inches)
OPTION
(1,91)
.075
DIA
(3,05)
.120
–EP
= End Shroud
with Guide
Post
(–075 post
height only.
Mates only
with CLP)
(5,46mm)
.215" to
(15,49mm)
.610" stacker
height only,
9 pins/row
minimum
FW-15-02-G-D-550-065 价格&库存
很抱歉,暂时无法提供与“FW-15-02-G-D-550-065”相匹配的价格&库存,您可以联系我们找货
