HDWM-20-54-L-D-335-SM 数据手册
MICRO
BOARD STACKER
(1.27 mm) .050" PITCH • DWM/HDWM SERIES
DWM/HDWM
DWM
Mates:
SMS, SLM, RSM
NO. PINS
PER ROW
01 thru 50
SPECIFICATIONS
Insulator Material:
Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin
-55 °C to +125 °C with Gold
LEAD
STYLE
PLATING
OPTION
– L
Specify
LEAD
STYLE
from
chart
–D
(4.98)
.196
(0.00)
.000
MIN
LEAD THROUGHSTYLE
HOLE
–01
OAL
(3.05)
.120
ALSO AVAILABLE
= Polarized
Position
(Specify position
of omitted pin)
OAL
STACKER
HEIGHT
(5.08)
.200
MIN
(2.54)
.100
OTHER
OPTION
– “XXX”
= Stacker
Height
Example:
–200 =
(5.08 mm)
.200"
= Double
Row
–G
STACKER
HEIGHT
–“XXX”
= Single
Row
= 10 µ"
(0.25 µm)
Gold on
contact,
Gold flash
on tail
(2.48)
.098
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
ROW
OPTION
–S
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
(1.27) .050 x No. of Positions
PROCESSING
(11.43) .450
–51
(10.41) .410
–52
(10.80) .425
–53
(12.83) .505
–54
(14.10) .555
–55
(15.49) .610
–56
(15.88) .625
–57
(16.51) .650
–58
(17.91) .705
–59
(19.18) .755
–60
(20.96) .825
–61
(26.67) 1.050
Other Platings
(MOQ Required)
HDWM
OAL
LEAD THROUGH- SURFACE
STYLE
HOLE
MOUNT
–01
(11.43) .450
(8.38) .330
–51
(10.41) .410
–52
(10.80) .425
–53
(12.83) .505
(9.78) .385
–54
(14.10) .555
(11.05) .435
–55
(15.49) .610
(12.45) .490
–56
(15.88) .625
(12.83) .505
–57
(16.51) .650
(13.46) .530
–58
(17.91) .705
(14.86) .585
(15.62) .615
–59
(19.18) .755
–60
(20.96) .825
–61
(26.67) 1.050
Notes:
For added mechanical stability,
Samtec recommends
mechanical board spacers
be used in applications
with gold or selective gold
plated connectors. Contact
ipg@samtec.com for more
information.
NO. PINS
PER ROW
01 thru 50
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
– L
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
–G
(2.48)
.098
ROW
OPTION
–S
= Single
Row
–D
= Double
Row
= 10 µ"
(0.25 µm)
Gold on
contact,
Gold flash
on tail
(4.98)
.196
STACKER
HEIGHT
–“XXX”
= Stacker
Height
Example:
–250 =
(6.35 mm)
.250"
OTHER
OPTION
– “XXX”
= Polarized Position
(Specify position
of omitted pin)
– SM
= Surface Mount
(02 thru 40
positions only)
–A
= Alignment Pin
(6 positions
minimum –D only)
Metal or plastic at
Samtec discretion
(Not available
with –LC)
– LC
(0.00)
.000
MIN
(2.54)
.100
OAL
STACKER
HEIGHT
(5.08)
.200
MIN
(3.05)
.120
= Locking Clip
(5 positions
minimum –D only)
(Not
available
STACKER
HEIGHT
with –A)
(6.35) OAL (Manual placement
.250
required)
MIN
–P
= Pick & Place Pad
This Series is non-standard,
non-returnable.
F-224
samtec.com?DWM or samtec.com?HDWM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
HDWM-20-54-L-D-335-SM 价格&库存
很抱歉,暂时无法提供与“HDWM-20-54-L-D-335-SM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 22+67.7951222+8.74010
