HLE-110-02-S-DV-BE-A-TR 数据手册
COST-EFFECTIVE
RELIABLE SOCKET
(2.54 mm) .100" PITCH • HLE SERIES
HLE
Board Mates:
TSW, MTSW, DW, EW,
ZW, TLW, TSM, MTLW, HW
HLE
-1
NO. PINS
PER ROW
- 02 -
02 thru 50
- DV -
–F
TAIL
OPTION
Leave blank for
Surface Mount
(Requires –BE for
Bottom Entry)
= Gold flash on
contact,
Matte Tin on tail
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
BeCu
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (HLE/TSM):
4.1 A per pin
(2 pins powered)
Voltage Rating:
400 VAC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(1.78 mm) .070" to
(3.43 mm) .135" pass-through,
or (2.59 mm) .102" min
plus board thickness for
bottom entry
PLATING
OPTION
–TE
–L
= Through-hole
Top Entry
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–PE
= Through-hole
Pass-through
Entry
(Requires –BE for
Bottom Entry)
1RRI3RVLWLRQV[
–BE
= Bottom Entry
(Not available
with –TE)
–A
= Alignment Pin
(4 positions min.)
Metal or plastic at
Samtec discretion
(Not available with
-TE, -PE & -LC)
–LC
= Locking Clip
(2 positions min.)
(Not available with -A)
(Manual placement
required)
= (6.50 mm)
.256" DIA
Polyimide Film
Pick & Place Pad
(3 positions min.)
Not available
with –TE or
–PE tail option
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-20)
(0.15 mm) .006" max (21-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
OTHER
OPTION
–K
PROCESSING
–P
= Metal Pick
& Place Pad
(3 positions min.)
–TR
= Tape & Reel
(29 positions max.)
–FR
—PE
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
ALSO AVAILABLE
MOQ Required
Other Platings
—TE
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
—P
—LC
—A
samtec.com?HLE
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
HLE-110-02-S-DV-BE-A-TR 价格&库存
很抱歉,暂时无法提供与“HLE-110-02-S-DV-BE-A-TR”相匹配的价格&库存,您可以联系我们找货
