HMTMS-102-54-G-D-335
    SAMTEC(申泰)
HMTMS-102-54-G-D-335 数据手册
F-224 WEB MTMS–130–02–G–D–100 MTMS–110–02–G–D–100 MTMS–125–51–G–S–200 (1.27 mm) .050" MTMS, HMTMS SERIES MODIFIED MICRO TERMINAL SPECIFICATIONS For complete specifications see www.samtec.com?MTMS or www.samtec.com?HMTMS Mates with: SMS, SLM, RSM Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin -55 °C to +125 °C with Gold RoHS Compliant: Yes Position anywhere in the body with (3.05 mm) .120" minimum tail PROCESSING Lead-Free Solderable: Yes Ideal for board stacking applications Single row and double row RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION 01 thru 50 Specify LEAD STYLE from chart –L ROW OPTION POST HEIGHT OPTION –S –“XXX” –“XXX” FILE NO. E111594 ALSO AVAILABLE (MOQ Required) • Other platings MTMS = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –G = Modified Standard = 10 µ" (0.25 µm) Gold on post, Gold flash on tail HMTMS = Modified High Temp (1.27) .050 x No. of Positions (2.48) .098 50 01 02 100 (2.54) .100 HMTMS –D BODY DESIGN 99 (1.27) .050 TYP (0.46) .018 SQ B (0.00) .000 MIN (2.54) .100 OAL (3.05) C .120 MIN* (0.51) .020 (0.51) .020 DIA SINGLE ROW Note: This Series is non-standard, non-returnable. –D = Double Row DOUBLE ROW Tail DIA is .020" (0.51 mm) for min .120" (3.05 mm). Balance of tail is .018" (0.46 mm) SQ. = “B” Dimension (Specify Post Height in inches (0.13 mm) .005" increments) LEAD STYLE OAL –01 = Polarized Position (Specify position of omitted pin) B (Maximum when C = (3.05 mm) .120") (11.43) .450 (5.84) .230 –02 (8.13) .320 (2.54) .100 (8.38) .330 (3.18) .125 –51 (10.41) .410 (4.83) .190 –52 (10.80) .425 (5.21) .205 –53 (12.83) .505 (7.24) .285 –54 (14.10) .555 (8.51) .335 –55 (15.49) .610 (9.91) .390 –56 (15.88) .625 (10.29) .405 –57 (16.51) .650 (10.92) .430 –58 (17.91) .705 (12.32) .485 –59 (19.18) .755 (13.59) .535 –60 (20.96) .825 (15.37) .605 –25* (4.98) .196 01 = Single Row *Style -25 tail C = (1.02 mm) .040" min is available. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
1. 物料型号:MTMS–130–02–G–D–100和MTMS–110–02–G–D–100,以及MTMS–125–51–G–S–200。 2. 器件简介:这些端子是修改型微型端子,适用于与SMS、SLM、RSM系列配合使用,适合于板对板堆叠应用。 3. 引脚分配:文档中提到了单排和双排配置,但没有具体说明引脚分配。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 端子材料:磷青铜 - 镀层:金或锡,厚度为50微英寸(1.27微米)的镍层 - 工作温度范围:-55°C至+105°C(锡镀层)或-55°C至+125°C(金镀层) - 符合RoHS标准 5. 功能详解:端子设计用于板对板堆叠应用,可以单排或双排配置。 6. 应用信息:适用于需要板对板堆叠的应用场景。 7. 封装信息:提供了不同引脚数量和引脚样式的选项,以及引脚样式的详细尺寸和高度。
HMTMS-102-54-G-D-335 价格&库存
很抱歉,暂时无法提供与“HMTMS-102-54-G-D-335”相匹配的价格&库存,您可以联系我们找货
  • 1+10.670401+1.35900
  • 50+7.0903050+0.90300
  • 100+6.89200100+0.87780
  • 1000+6.017401000+0.76640
  • 2000+5.749202000+0.73220
  • 5000+5.236105000+0.66690
  • 10000+5.0145010000+0.63870
库存:39
