HMTMS-110-25-S-D-125 数据手册
F-208
MTMS–125–60–G–D–230
MTMS–110–02–S–D–100
MTMS–130–57–G–S–390
MODIFIED HEADER MTMS SERIES
SPECIFICATIONS
Mates with:
SMS, SLM, RSM
For complete specifications
see www.samtec.com?MTMS
or www.samtec.com?HMTMS
Insulator Material:
Black Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ” (1,27µm) Ni
Current Rating:
1A
Operating Temp Range:
-55°C to + 105°C with Tin
-55°C to + 125°C with Gold
RoHS Compliant:
Yes
Position anywhere
in the body with
(3,05mm) .120"
minimum tail
Board Stacking
BO AR D
SPA CE
OV ERA LL
PIN
(O AL )
MA X
INS ERT ION
DE PTH
PO ST
Note: This Series is
non-standard, non-returnable.
Processing:
Max Processing Temp:
230°C for 60 seconds, or
260°C for 20 seconds 3x
Lead-Free Solderable:
Yes
Ideal for board
stacking
applications
BO DY
PRO FIL E
TAI L
TYPE
STRIP
SO CK ET
PRO FIL E
1
Single row
and double row
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
01
thru
50
Specify
LEAD
STYLE
from
chart
–G
= 10µ" (0,25µm)
Gold on post,
Gold flash on tail
MTMS
= Modified Standard
–S
HMTMS
= 30µ" (0,76µm)
Gold on post,
Matte Tin on tail
= Modified High Temp
ROW
OPTION
POST
HEIGHT
OPTION
–S
–“XXX”
–“XXX”
= Single
Row
–D
= Double
Row
= “B”
Dimension
(Specify
Post Height
in inches
(0,13mm)
.005"
increments)
B
(1,27) .050 x No. of Positions
LEAD
STYLE
(2,48)
.098
50
01
02
100
(2,54)
.100
(4,98)
.196
01
HMTMS –D
BODY DESIGN
99
(1,27) .050 TYP
(0,46) .018 SQ
B
(0,00) .000
MIN
(2,54)
.100
OAL
(3,05)
C .120
MIN*
(0,51)
.020
www.samtec.com
(0,51) .020 DIA
Tail DIA is .020" (0,51mm) for min .120" (3,05mm).
Balance of tail is .018" (0,46mm) SQ.
WWW.SAMTEC.COM
–01
–02
–25*
–51
–52
–53
–54
–55
–56
–57
–58
–59
–60
OAL
(Maximum
when C =
.120 (3,05) )
(11,43) .450 (5,84) .230
(8,13) .320
(2,54) .100
(8,38) .330
(3,18) .125
(10,41) .410 (4,83) .190
(10,80) .425 (5,21) .205
(12,83) .505 (7,24) .285
(14,10) .555 (8,51) .335
(15,49) .610 (9,91) .390
(15,88) .625 (10,29) .405
(16,51) .650 (10,92) .430
(17,91) .705 (12,32) .485
(19,18) .755 (13,59) .535
(20,96) .825 (15,37) .605
*Style -25 tail C=.105 (2,67) min
is available.
= Polarized
Position
(Specify
position of
omitted pin)
