MAX
POWER HEADERS, 16.1
STACKERS & SOCKETS
A
m
p
s
(5.08 mm) .200" PITCH • HPM, HPW, HPF SERIES
HPM, HPW
HPF
Board Mates:
HPM, HPW
HPM
Board Mates:
HPF
NO. OF PINS
01 thru 20
High Temp
High Power
Header
LEAD
STYLE
PLATING
OPTION
-S-
–T
Specifiy
LEAD
STYLE
from
chart
below
–RA
= Right-angle
(-02 & -04 lead style only)
–VS
(2.54)
.100
No. of Positions x (5.08) .200
E
B
C
A
D
(6.35)
.250
HPW
High
Temp
High
Power
NO. OF
PINS
(2.54)
.100
G
–RA
LEAD
STYLE
F
–VS
- 04 -
02 thru 20
A
B
C
D
E
F
G
–01
(4.57) .180 (11.94) .470
–02
(4.57) .180 (13.21) .520 (2.54) .100 (4.57) .180 (8.08) .318 (12.24) .482 (8.38) .330
–04
(4.09) .161 (21.06) .829 (4.95) .195
–05
(4.57) .180
(3.81) .150
-S-
PLATING
OPTION
–T
STACK
HEIGHT
–“XXX”
= Stacker
Height (in
inches)
(0.13 mm) .005"
increments
= Matte Tin
(10.72) .422 (8.64) .340
(3.96) .156 (13.82) .544
POST
HEIGHT
OTHER
OPTIONS
–“XXX”
Leave blank for
Through-hole
= Post Height
(in inches)
–VS
= Surface Mount
(2 pins/row minimum)
–P
POST
HEIGHT
(0.00)
.000
MIN
HPF
STACK
HEIGHT
(29.21) 1.15
MAX WITH
(0.00) .000
POST
(7.62) .300
MIN
NO. OF PINS
02 thru 20
(2.54)
.100
STACK
HEIGHT
(32.00) 1.26
MAX
(5.08) .200
MIN
= Pick & Place Pad
(3 Pos. min.)
(6.98 mm) .275" max.
post height
(–VS only)
(34.29)
1.35
MAX
(2.29)
.090
LEAD STYLE
–01
PLATING
OPTION
S
–T
= Through-hole
= Matte Tin
–02
= Surface Mount
OTHER OPTIONS
–LC
= Locking Clip
(Manual
placement
required)
(–02 lead
style only)
–K
= (6.50 mm)
.256" DIA
Polyimide
film Pick
& Place Pad
(5.08)
.200
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
= Pick & Place
Pad (3 Pos. min.)
(–VS only)
(Not Available
with -05
lead style)
= Surface Mount
(-01 & -02 lead style only)
PROCESSING
Lead–Free Solderable:
HPW-VS, HPM-VS, HPF = Yes
HPM -TH, HPM -RA &
HPW -TH = No, Lead Wave only
SMT Lead Coplanarity:
HPM = (0.20 mm)
.008" max (02-15)*
HPM = (0.25 mm)
.010" max (16-20)*
HPW = (0.20 mm) .008" max*
HPF = (0.15 mm) .006" max
(02-10)*
(0.20 mm) .008" max (11-20)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
OTHER
OPTION
–P
Leave blank for
Through-hole
= Matte Tin
SPECIFICATIONS
Insulator Material:
HPW/HPM = Glass Filled
Polyester (Through-hole),
Natural Liquid Crystal Polymer
(Surface Mount)
HPF = Black LCP
Terminal Material
(HPM/HPW):
Copper Alloy
Contact Material (HPF):
BeCu
Plating:
Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C
Voltage Rating:
HPM/HPF = 850 VAC/1200
VDC
Insertion Depth (HPF):
(3.68 mm) .145" to (8.26 mm)
.325" (.368" (9.35 mm) plus
board thickness minimum for
bottom entry)
Wiping Distance (HPF):
(0.38 mm) .015"
TAIL OPTION
(8.89)
.350
–02
–TR
= Tape & Reel
Packaging
(14 positions max.)
(Style –02 only)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(14 positions max.)
(Style -02 only)
–01
samtec.com?HPM, samtec.com?HPW or samtec.com?HPF
F-224 WEB
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“HPF-02-02-T-S-K-TR”相匹配的价格&库存,您可以联系我们找货
