BKS-165-01-L-V-A
BKS-165-01-L-V-A
    SAMTEC(申泰)
    SMD,P=1mm
    排母 间距:1mm SMT
BKS-165-01-L-V-A 数据手册
F-224 WEB BKS–125–01–L–V BKS–115–01–L–V BKS–155–01–L–V–P BKT–111–01–L–V BKT–127–01–L–V–S–P BKT–133–03–L–V BKT–131–05–L–V–S (1.00 mm) .0394" BKT, BKS SERIES POLARIZED MICRO HEADER & SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?BKT or www.samtec.com?BKS BODY STYLE NO. OF POSITIONS 1 BKT Mates with: Insulator Material: BKS Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: (Odd lead counts only) Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 02 2.8 A per pin 02 (2 pins powered) BODY (5.08) Operating Temp Range: STYLE .200 (2.54) (5.59) (5.08) -55 °C to +125 °C .100 .220 .200 Insertion Depth: (2.54) (5.59) .100 .220 (1.40 mm) .055" minimum –01 Normal Force: 40 grams (0.39 N) average (1.00) 01 .03937 –02 Max Cycles: (0.50) .020 TYP (1.00) 01 100 with 10 µ" (0.25 µm) Au .03937 (0.50) .020 TYP (0.31) .012 SQ TYP RoHS Compliant: –03 Yes (0.31) .012 SQ TYP (1.65) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max .065 A A (1.19) .047 (0.89) BOARD SPACE B (Mated with BKS) OPTIONS –S = Shrouded (15 positions minimum) –A = Alignment Pin (Metal or plastic at Samtec discretion) (13 positions minimum) –P (2.29) (4.27) (4.50) .090 .168 .177 = Pick & Place Pad (13 positions minimum) (2.79) (4.78) (5.00) .110 .188 .197 (6.35) .250 (3.78) (5.77) (6.00) .149 .227 .236 –TR (6.35) .250 = Tape & Reel Packaging –FR (0.50) .0197 x (No. of positions +1) (0.50) .0197 +x(2.44) .096 = Full Reel Tape & Reel (No. of positions +1) (must order max. quantity + (2.44) .096 (4.17 x 5.71) .164 x .225 –S OPTION (0.20) .008 (0.20) .008 (0.89) .035 DIA –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (1.93) (3.91) (4.14) .076 .154 .163 (4.17 x 5.71) .164 x .225 (1.19) .047 = Gold flash on post, Matte Tin on tail (4.80) (6.78) (7.00) .189 .267 .276 –05 (0.50) .0197 x (No. of positions +1) (0.50) .0197 +x (0.25) .010 (No. of positions +1) + (0.25) .010 RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –04 A V –F Specify BODY STYLE from chart 07 thru 69 (1.65) .065 PLATING OPTION B B per reel; Contact Samtec for quantity breaks) (3.61) .142 (3.61) .142 –P OPTION DIA –A.035 OPTION FILE NO. E111594 APPLICATIONS BKT 1 BKS MATED HEIGHT BKS BKT LEAD STYLE –01 –02 –03 –04 –05 MATED HEIGHT* (4.14) .163 (4.50) .177 (5.00) .197 (6.00) .236 (7.00) .276 *Processing conditions will affect mated height. Mates with: BKT NO. OF POSITIONS PLATING OPTION 01 V –F 07 thru 69 (Odd lead counts only) (07 positions available with –TR only) –A =Pre-plated Gold flash on contact, Matte Tin on tail 02 =Alignment Pin (Metal or plastic at Samtec discretion) (11 positions minimum) –L (4.11) .162 01 –P =Pre-plated 10 µ" (0.25 µm) Gold contact, Matte Tin on tail (2.54) (5.59) .100 .220 =Pick & Place Pad (13 positions minimum) Not always necessary for auto placement. –TR (0.36) .014 (1.00) .03937 =Tape & Reel Packaging (0.50) .020 TYP (0.50) .0197 x No. of positions + (0.81) .032 Note: Some sizes, styles and options are non-standard, non-returnable. (2.12) .084 OPTIONS (5.26 x 6.07) .207 x .239 (1.07) .042 (2.21) .087 (0.89) .035 DIA (0.20) .008 –P OPTION –A OPTION –FR =Full Reel Tape & Reel (must order max. quantity per reel; Contact Samtec for quantity breaks) WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
BKS-165-01-L-V-A
物料型号: - BKS–125–01–L–V - BKS–115–01–L–V - BKS–155–01–L–V–P - BKT–111–01–L–V - BKT–127–01–L–V–S–P - BKT–133–03–L–V - BKT–131–05–L–V–S
器件简介: - 这些是极化微型连接器头和插座,具有1.00毫米间距。
引脚分配: - 引脚数量从1到69,支持奇数引脚数量。
参数特性: - 绝缘体材料:液晶聚合物 - 端子材料:磷青铜 - 镀层:金或锡,覆盖50微米(1.27微米)镍 - 电流额定值:每针2.8安培(2针供电) - 操作温度范围:-55°C至+125°C - 插入深度:最小1.40毫米 - 正常力:平均40克(0.39牛顿) - 最大周期:100次,金层厚度为10微米(0.25微米) - 符合RoHS标准
功能详解: - 提供了详细的规格说明和推荐的PCB布局,可在Samtec官网查询。
应用信息: - 适用于需要微型连接器的应用场景。
封装信息: - 提供了不同引脚数量和不同镀层选项的封装信息
BKS-165-01-L-V-A 价格&库存
很抱歉,暂时无法提供与“BKS-165-01-L-V-A”相匹配的价格&库存,您可以联系我们找货
