CC396-3234-G-U
CC396-3234-G-U
    SAMTEC(申泰)
    0.80 MM CRIMP CONTACT, REEL PACK
CC396-3234-G-U 数据手册
(0.80 mm) .0315" PITCH • DISCRETE WIRE CABLE ASSEMBLY/COMPONENTS - SESDT - 32 - POSITIONS PER ROW PLATING OPTION –05, –10, –15, –20 = Double Row Blue *Teflon™ Fluoropolymer Cable (32 AWG) - –G (Standard sizes) - ASSEMBLED LENGTH –“XX.X” = 10 µ" (0.25 µm) Gold on contact area, 3 µ" (0.08 µm) Gold on tail OPTIONS Double Ended Assemblies –L1 = Assembled Length in Inches (76.2 mm) 03.0" min. = Pin 1 to Pin 1 –L2 SESDT = Pin 1 to Pin 2 Board Mates: TEM-L1 –L3 = Pin 1 to Pin N-1 (5.05) .199 SPECIFICATIONS Insulator Material: Natural Nylon Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Wire: Tinned Copper Wire Insulation: FEP Operating Temp Range: -55 °C to +125 °C Current Rating: 1.9 A per pin (2 pins powered) Voltage Rating: 200 VAC/280 VDC Single Ended Assembly –L B = Latching DOUBLE ENDED ASSEMBLED LENGTH ± (3.18) .125 NO. OF POSITIONS A B –05 (5.70) .224 (11.50) .453 –10 (9.70) .382 (15.50) .610 –15 (13.70) .539 (19.50) .768 –20 (27.70) .697 (23.50) .925 SINGLE ENDED Note: Teflon™ Fluoropolymer cable is intended for crimp only. Contact Samtec for solderable cable applications. - = Pin 1 to Pin N A *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. ISDE –L4 ASSEMBLED LENGTH ± (3.18) .125 View complete specifications at: samtec.com?SESDT - POSITIONS PER ROW –05, –10, –15, –20 - D –D (Standard sizes) = Dual Row POSITIONS PER ROW A L –L = Latch SERIES CC396 = Contact - WIRE GAUGE - –3234 = 32 to 34 AWG B –05 (9.50) .374 (11.50) .453 –10 (13.50) .531 (15.50) .610 –15 (17.50) .689 (19.50) .768 –20 (21.50) .846 (23.50) .925 PLATING - –G = 10 µ" (0.25 µm) Gold on contact area, 3 µ" (0.08 µm) Gold on tail REEL OPTIONS –U = Micro Reel (4K Contacts) –M = Mini Reel (15K Contacts) –R = Reel (50K Contacts) A (5.05) .199 (10.70) .421 (6.30) .248 B TOOLING Hand Tool: CAT-HT-396-3232-12 Note: Some lengths, styles and options are non-standard, non-returnable Mini Applicator: CAT-MC-396-3232-XX-03 View complete specifications at: samtec.com?ISDE & samtec.com?CC396 samtec.com/080mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
CC396-3234-G-U 价格&库存
很抱歉,暂时无法提供与“CC396-3234-G-U”相匹配的价格&库存,您可以联系我们找货
CC396-3234-G-U
  • 4000+0.754244000+0.09731
  • 8000+0.718228000+0.09266
  • 12000+0.6979712000+0.09005
  • 20000+0.6732520000+0.08686
  • 28000+0.6574628000+0.08482
  • 40000+0.6411340000+0.08271
库存:4570
CC396-3234-G-U
  • 1+1.529401+0.19731
  • 10+1.2823410+0.16544
  • 25+1.1982825+0.15459
  • 50+1.1426750+0.14742
  • 100+1.08823100+0.14039
  • 250+1.01946250+0.13152
  • 500+0.97067500+0.12523
  • 1000+0.924341000+0.11925
库存:4570
CC396-3234-G-U
  • 10+1.3016010+0.16792
  • 25+1.2252325+0.15807
  • 50+1.1657750+0.15040
  • 100+1.10919100+0.14310
  • 250+1.03978250+0.13414
  • 500+0.99018500+0.12774
  • 1000+0.942811000+0.12163
库存:4570
