EHT-122-01-S-D-RA-20
    SAMTEC(申泰)
    CONN HEADER R/A 44POS 2MM
EHT-122-01-S-D-RA-20 数据手册
SHROUDED IDC HEADERS (2.00 mm) .0787" PITCH • ETMM/EHT/EC2 SERIES ETMM TYPE STRIP Mates: TCSD, TCMD EHT - 1 ETMM Mates: TCSD SPECIFICATIONS - 02 - 05, 08, 10, 12, 13, 15, 17, 20, 22, 25 = Mates with TCSD and TCMD with Strain Relief –TH   –SM   EHT - 1 NO. PINS PER ROW 05, 08, 10, 12, 13, 15, 17, 20, 22, 25 EJECTOR HEADER CAP (Locks TCSD cable to EHT header) (9.65) .380 (9.65) .380 - 01 - ­­– F - TAIL OPTION –L = Right-angle –RA –SM OTHER OPTION –“XX” = Polarized Position –SR = Strain Relief (Leave Blank for no strain relief) = Locking Clip (–SM only) (Manual placement required)   05, 08, 10, 12, 13, 15, 17, 20, 22, 25 = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–SM only) –LC = Surface Mount   NO. PINS PER ROW —TH Leave blank for Through-hole = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –TR –FR = Gold flash on post, Matte Tin on tail 1RRISRVLWLRQV[      No. of positions x (2.00) .0787 + (19.89) .783 -D- PLATING OPTION = (7.50 mm) .295" DIA Polyimide Film Pick & Place Pad (–SM only) = Tape & Reel (–SM only)   –SM –K   —RA 1RRISRVLWLRQV[       –LC = Locking Clip (N/A with –RA) (Manual placement required) = Surface Mount —TH —RA –“XX” = Right -angle   OTHER OPTION = Polarized Position –RA   —SM - =Throughhole –L Lead–Free Solderable: Yes SMT Lead Coplanarity: EHT = (0.10 mm) .004" max ETMM = (0.13 mm) .005" max* *(.004" stencil solution may be available; contact ipg@samtec.com) –K = (7.50 mm) .295" DIA Polyimide Film Pick & Place Pad (–SM only)   —SM –P = Pick & Place Pad (–SM only)   F-224 TAIL OPTION –F = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail PROCESSING Note: Some lengths, styles and options are non-standard, non-returnable. -D- PLATING OPTION = Gold Flash on post, Matte Tin on tail (Standard sizes) Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C EC2 NO. PINS PER ROW   –TR     –SR —RA (Latch removed for clarity)   = Tape & Reel (–SM only) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–SM only) samtec.com?ETMM or samtec.com?EHT Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
物料型号: - ETMM系列:与TCSD和TCMD兼容,具有应变消除功能 - EHT系列:与TCSD兼容 - EC2系列:未在文档中详细说明
器件简介: - 绝缘体材料:黑色液晶聚合物 - 端子材料:磷青铜 - 镀层:锡或金,底层为50微米(1.27微米)镍
引脚分配: - 提供了不同排针数量的选项,如02、05、08、10、12、13、15、17、20、22、25
参数特性: - 操作温度范围:-55°C至+125°C - 无铅可焊性:是 - SMT引脚共面性:EHT系列最大0.10毫米,ETMM系列最大0.13毫米
功能详解: - 提供了不同的选项,如直通孔(-TH)、表面贴装(-SM)、带锁扣(-LC)、右角(-RA)等
应用信息: - 适用于需要高可靠性和稳定性的应用场景
封装信息: - 提供了详细的尺寸信息和选项,如Pick & Place Pad(-K)、Tape & Reel(-TR)等
EHT-122-01-S-D-RA-20 价格&库存
很抱歉,暂时无法提供与“EHT-122-01-S-D-RA-20”相匹配的价格&库存,您可以联系我们找货
  • 9+156.910739+20.39789
