ZW–06–13–L–D–787–118
F-217
DW–11–20–T–D–825
HW–14–08–G–S–300–100
(2.54 mm) .100"
DW, EW, ZW, HW SERIES
FLEXIBLE .025" SQ BOARD STACKERS
Mates with:
SSW, SSQ, ESW, ESQ,
CES, SLW, BSW, BCS,
SSM, HLE, PHF
TYPE
STRIP
LEAD
STYLE
NO. PINS
PER ROW
PLATING
OPTION
Cable Mates:
IDSS, IDSD, SMSD, SMSS
SPECIFICATIONS
For complete specifications
see www.samtec.com?DW,
www.samtec.com?EW,
www.samtec.com?ZW or
www.samtec.com?HW-TH
Insulator Material:
DW, EW, ZW: Black Glass
Filled Polyester
HW: Natural Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
RoHS Compliant:
Yes
Lead–Free Solderable:
DW, EW, ZW: Wave Only
HW: Yes
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
FILE NO. E111594
DW
Specify LEAD STYLE
from chart
= (2.79 mm)
.110" Tail
POST
(0.00).000
MIN
(2.79)
.110
OVERALL
LENGTH
EW
(OAL)
STACKER
HEIGHT
= (8.38 mm)
.330" Tail
TAIL
(1.40) .055
MIN
LEAD
STYLE
OAL
– 07
(10.92) .430
– 08
(13.46) .530
– 09
(18.54) .730
–10
(21.08) .830
–11
(23.62) .930
–12
(26.16) 1.030
–13
(31.24) 1.230
–14
(36.32) 1.430
–15
(16.00) .630
–16
(11.30) .445
–17
(12.19) .480
–19
(33.78) 1.330
–20
(28.70) 1.130
(8.38)
.330
01 thru 50
= Custom Tail
50
02
• Other platings
Contact Samtec.
Note: For added mechanical
stability, Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
= High Temp
Custom Tail
(2.54) .100 x
No. of Positions
–S
–“XXX”
–“XXX”
= Single
Row
= Stacker
Height
–D
–T
ZW or
HW TAIL
LENGTH
(1.40)
.055
MIN
= Triple
Row
–Q
= Double
Row .200"
(5.08 mm)
row space
–LL
–F
= Gold flash on contact,
Matte Tin on tail
(2.54)
.100
–S
= 10 µ" (0.25 µm) Gold on contact
area of longer tail,
Gold flash on balance
(2.54)
.100
–D
–T
100
01
99
03
150
(7.52)
.296
= Matte Tin
(5.08)
.200
01
–T
or –Q*
–Q*
148
(2.54)
.100
= Same as
-T except
middle
row
of pins
missing.
(2.54)
.100
TAIL
LENGTH
= ZW or HW
Tail Length
STACKER
HEIGHT
(5.08)
.200
MIN
= Double
Row
–G
01
(5.08)
.200
ALSO AVAILABLE
HW
OTHER
OPTIONS
Matte Tin on tail
FILE NO: 090871_0_000
(MOQ Required)
STACKER
HEIGHT
–L
ZW
TAIL
LENGTH
ROW
OPTION
(0.64) .025 SQ TYP
Note: This Series is
non-standard, non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
= Locking
Lead
(Shortest
dimension
between the
tail and the
post is the
end that will
be crimped.
Available
on tails from
(2.29 mm)
.090" to
(7.87 mm)
.310" only.)
Single row, 01
& 02 positions
& –Q row not
available
–“XXX”
= Polarized
Specify omitted
pin position
很抱歉,暂时无法提供与“EW-02-13-G-S-705”相匹配的价格&库存,您可以联系我们找货
