FCF8-20-01-L-08.00-S-1
    SAMTEC(申泰)
    FCF8 CABLE ASSEMBLY
FCF8-20-01-L-08.00-S-1 数据手册
F-218 (Rev 10OCT17) FCF8–20–01–L–03.00–S FCF8–10–01–L–03.00–S FCS8–10–01–L–S–A–TR FCS8–20–01–L–S–A–TR (0.80 mm) .0315" FCF8, FCS8 SERIES HIGH-SPEED COST EFFECTIVE COAX CABLE SPECIFICATIONS NO. OF POSITIONS FCF8 For complete specifications see www.samtec.com?FCF8 Cable: 38 AWG coax Overmold: Nylon Terminal Material: Phosphor Bronze Contact Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -25 °C to +105 °C Current Rating: 1.8 A per pin (1 pin powered) RoHS Compliant: Yes Mates with: FCS8 CABLE LENGTH PLATING OPTION 01 –L –10, –20, –30 –“XX.XX” = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Length in Inches 03.00" (76.2 mm) minimum CABLE LENGTH + (16.43) .647 NO. OF POSITIONS RECOGNITIONS GND GND A FILE NO. E111594 (19.85) (27.00) .781 1.063 –30 (27.85) (35.00) 1.096 1.378 (MOV Required) (12.55) .494 • Other sizes and lengths Contact Samtec. (2.42) .095 SPECIFICATIONS NO. OF POSITIONS FCS8 For complete specifications and recommended PCB layouts see www.samtec.com?FCS8 Insulator Material: Black LCP Contact Material: BeCu Contact Plating: Au or Sn over 50 µ" (1.27 µm) Ni Shield: Nickel Plated Phosphor Bronze Operating Temp Range: -55 °C to +125 °C Current Rating: 1.8 A per pin (1 pin powered) RoHS Compliant: Yes Mates with: FCF8 (0.80) .0315 PLATING OPTION 01 –L –10, –20, –30 A (7.46) .294 (0.30) .012 S = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail A TR –TR = Tape & Reel NO. OF A B C D POSITIONS (16.59) .653 (15.56) .613 (10.70) .421 (13.06) .514 –10 (24.59) .968 (23.56) .928 (18.70) .736 (21.06) .829 –20 (32.59) 1.283 (31.56) 1.243 (26.70) 1.051 (29.06) 1.144 –30 (7.48) .294 B • Weld tabs • Positive latching RECOGNITIONS FILE NO. E111594 –20 ALSO AVAILABLE Some lengths, styles and options are non-standard, non-returnable. For complete scope of recognitions see www.samtec.com/quality –10 GND Cable lengths longer than 40.00" (1 meter) are not supported with S.I. test data. PROCESSING B N 01 GND Notes: Design your High-Speed Cable with Samtec’s High-Speed Cable Solutionator® at www.samtec.com/hdr B A (11.85) (19.00) .467 .748 01 N For complete scope of recognitions see www.samtec.com/quality Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact IPG@samtec.com) S • Shielded for EMI protection C D (0.49) .019 (1.85) .073 (0.20) .008 (1.32) .052 DIA Note: Some lengths, styles and options are non-standard, non-returnable. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
FCF8-20-01-L-08.00-S-1 价格&库存
很抱歉,暂时无法提供与“FCF8-20-01-L-08.00-S-1”相匹配的价格&库存,您可以联系我们找货
