FFTP-25-D-08.77-01-S-N
    SAMTEC(申泰)
    .050 X .050 C/L TWISTED PAIR FEM
FFTP-25-D-08.77-01-S-N 数据手册
F-218 TIGER ™ EYE IDC FMTP–10–D–03.85–01 (1.27 mm) .050" FFTP, FMTP SERIES FFTP–20–D–08.77–01–N TIGER EYE TWISTED PAIR IDC CABLES ™ FFTP Mates with: FTS, FTSH, EHF, SHF PINS PER ROW FFTP FMTP Mates with: FLE*, SFMC* END ASSEMBLY SPECIFICATIONS –05, –08, –10, –13, –17, –20, –25 For complete specifications see www.samtec.com?FFTP or www.samtec.com?FMTP ASSEMBLY LENGTH –D –03.85 = Double End = Notch Polarization (Standard) –08.77 = (222.76 mm) 8.77" ASSEMBLY LENGTH N –N = (97.79 mm) 3.85" (Standard sizes) Insulator Material: PBT Contact (FFTP): BeCu Terminal (FMTP): Phosphor Bronze Plating (FFTP): 10 µ" (0.25 µm) Au over 50 µ" (1.27 µm) Ni on contact area; Sn over 50 µ" (1.27 µm) Ni on balance Plating (FMTP): Sn over 50 µ" (1.27 µm) Ni Wire: 30 AWG 7/38, Tinned, Twisted Pair with PVC insulator Operating Temp Range: -40 °C to +105 °C Lead Size Accepted: (0.41 mm) .016" SQ Insertion Depth (FFTP): (2.64 mm) .104" to (3.17 mm) .125" RoHS Compliant: Yes 01 OPTION –R = Reverse Connector –18.00 = (457.20 mm) 18.00" (1.90) .075 No. of positions x (1.27) .050 + (4.19) .165 (1.02) .040 (Standard lengths) (3.05) .120 (5.08) .200 –D –R RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FMTP PINS PER ROW END ASSEMBLY ASSEMBLY LENGTH TRANSFER OPTION 01 FILE NO. E111594 –D = Double End –05, –08, –10, –13, –17, –20, –25 ALSO AVAILABLE (MOQ Required) –T = Transfer End (Standard sizes) • Other sizes • Other cable lengths Contact Samtec. –03.85 = (97.79 mm) 3.85" –08.77 = (222.76 mm) 8.77" Leave blank for –D End Assembly. For –T End Assembly Specify “–N” (Socket has notch polarization) –18.00 ASSEMBLY LENGTH No. of positions x (1.27) .050 + (4.19) .165 = (457.20 mm) 18.00" (Standard lengths) (3.05) .120 *Note: Standard FMTP callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates wth Pin 1, etc. Note: This Series is non-standard, non-returnable. (5.08) .200 –R –D (0.41) .016 SQ (1.27) .050 (3.07) .121 –T Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. OPTION –R = Reverse Connector
物料型号: - FFTP, FMTP系列
器件简介: - 该产品是TIGER EYE™品牌的扭曲对IDC电缆,具有不同的型号和规格。
引脚分配: - 当与插座配对时,线1与引脚2配对;线2与引脚1配对,依此类推。
参数特性: - 绝缘体材料:PBT - 接触(FFTP):BeCu - 端子(FMTP):磷青铜 - 镀层(FFTP):接触区域10µ" (0.25µm) Au,其余部分50µ" (1.27µm) Ni上覆Sn - 镀层(FMTP):50µ" (1.27µm) Ni上覆Sn - 线材:30 AWG 7/38,镀锡,扭曲对,PVC绝缘体 - 工作温度范围:-40°C至+105°C - 接受的引线尺寸:(0.41 mm) .016" SQ - 插入深度(FFTP):(2.64 mm) .104" 至 (3.17 mm) .125"
功能详解: - 该电缆设计用于高性能信号传输,具有RoHS合规性。
应用信息: - 适用于需要高性能信号传输的应用场合。
封装信息: - 提供不同长度和尺寸的电缆,可根据需求定制。
FFTP-25-D-08.77-01-S-N 价格&库存
很抱歉,暂时无法提供与“FFTP-25-D-08.77-01-S-N”相匹配的价格&库存,您可以联系我们找货
