FOLC-120-02-SM-Q-K-TR
    SAMTEC(申泰)
    .050'' X .050 SOCKET STRIP
FOLC-120-02-SM-Q-K-TR 数据手册
QUAD ROW TERMINAL/ SOCKET 2.6 A (1.27 mm) .050" PITCH • FOLC/MOLC SERIES FOLC FOLC Board Mates: MOLC - - NO. PINS PER ROW 1 20, 25, 30, 35, 40, 45, 50 MOLC Board Mates: FOLC - Q - –L = Mixed Technology - OPTION PACKAGING –LC = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –M1 & –M2 Leave blank for tubes = Locking Clip (Manual placement required) –TR = Tape & Reel (–MX only) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–MX only) (5.59) .220 No. of positions x (1.27) .050 + (0.51) .020 (4.57) .180 LEAD STYLE C C MIXED TECHNOLOGY THROUGH-HOLE View complete specifications at: samtec.com?FOLC MOLC - 1 NO. PINS PER ROW - 20, 25, 30, 35, 40, 45, 50 (Standard sizes) - LEAD STYLE –‘X’1 = Through-hole (Specify from chart) –02 = Surface Mount PLATING OPTION - Q - –L FOLC 1RRISRVLWLRQV[     1RRISRVLWLRQV[     MATED HEIGHT LEAD STYLE MATED MOLC FOLC HEIGHT*   OPTION –P     % THROUGH-HOLE $ (1.91) .075 (3.04) .120 = Pick & Place Pad (–02 only)     MOLC –01, –M1 = Locking Clip (Manual placement required) = Mixed Technology View complete specifications at: samtec.com?MOLC - PACKAGING Leave blank for tubes –TR = Tape & Reel (–02 & –M1 only) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–02 & –M1 only) SURFACE MOUNT   MIXED TECHNOLOGY C –04, –M2 –LC = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –M1 APPLICATIONS F-224 G b p s s PLATING OPTION –L1 & –L4 PROCESSING Note: Some lengths, styles and options are non-standard, non-returnable. p = Low Insertion Force Through-hole Insulator Material: Black Liquid Crystal Polymer Contact Material (FOLC): BeCu Terminal Material (MOLC): Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.6 A per pin (4 pins powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 165 VAC/230 VDC Insertion Depth (FOLC): (3.30 mm) .130" to (4.06 mm) .160" Max Cycles (FOLC): 100 –01 (5.97) .235 –11 –01 (7.75) .305 –31 (11.43) .450 *Processing conditions will affect mated height. - LEAD STYLE –01 & –04 SPECIFICATIONS Lead-Free Solderable: Yes SMT Lead Coplanarity (MOLC): (0.10 mm) .004" max (20-25) (0.15 mm) .006" max (30-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) m = Through-hole (Standard sizes) 8 MAX LEAD STYLE –LC OPTION A B –01 (5.59) .220 (3.38) .133 –11 (7.34) .289 –31 (11.05) .435 (3.66) .144 samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
物料型号:FOLC/MOLC系列
器件简介:该系列提供了2.6A的电流承载能力,适用于高速信号传输,具有1.27mm的引脚间距。
引脚分配:提供了不同引脚数量的选项,如20、25、30、35、40和50引脚。
参数特性:绝缘体材料为黑色液晶聚合物,接触材料为BeCu,端子材料为磷青铜,镀层为Au或Sn,覆盖50µ"(1.27µm)Ni。工作温度范围为-55°C至+125°C,电压等级为165VAC/230VDC。
功能详解:提供了详细的引脚样式、混合技术、表面贴装和通孔选项。
应用信息:适用于高速信号传输和大电流应用。
封装信息:提供了多种引脚样式和包装选项,如直通孔、锁定夹、胶带和卷轴等。
FOLC-120-02-SM-Q-K-TR 价格&库存
很抱歉,暂时无法提供与“FOLC-120-02-SM-Q-K-TR”相匹配的价格&库存,您可以联系我们找货
  • 400+210.44115400+27.21296
