FTE-113-02-G-DV-A
FTE-113-02-G-DV-A
    SAMTEC(申泰)
    .8MM MICRO TERMINAL STRIP
FTE-113-02-G-DV-A 数据手册
SMT MICRO HEADER & SOCKET (0.80 mm) .0315" PITCH • FTE/CLE SERIES FTE FTE Mates: CLE -1 CLE NO. PINS PER ROW - 05 thru 90 Mates: FTE, AW PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity (FTE): -DV: (0.10 mm) .004" max -DH: (0.10 mm) .004" max (05-25) (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact IPG@samtec.com) SMT Lead Coplanarity (CLE): (0.10 mm) .004" max (04-65) (0.15 mm) .006" max (66-90)* *(.004" stencil solution may be available; contact ipg@samtec.com) PLATING OPTION - –G Specify LEAD STYLE from chart SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Current Rating (FTE/CLE): 2.7 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth (CLE): Top Entry = (1.73 mm) .068" to (3.18 mm) .125" with (0.38 mm) .015" wipe, or pass-through Bottom Entry = (3.23 mm) .127" minimum plus board thickness Normal Force (CLE): 75 grams (0.73 N) Max Cycles (CLE): 100 with 10 µ" (0.25 µm) Au - LEAD STYLE TAIL OPTION - –DV = 10 µ" (0.25 µm) Gold on post, Gold flash on balance = Dual Vertical Style –01 –DV only (11 pins/row minimum) –DH = End Shroud –A –EC = End Shroud with Locking Clips (Manual placement required) (3.05) .120 –K = (2.50 mm) .098" DIA Polyimide Film Pick & Place Pad (–DH only) –EP = End Shroud with Guide Posts No. of positions x (0.80) .0315 + Z OPTION Z LEAD STYLE A –ES (1.57) .062 –01 (1.90) .075 –EC (4.11) .162 –02 (4.45) .175 –EP (5.51) .217 –03 (3.05) .120 –P = Plastic Pick & Place Pad (8 positions minimum) –DV only –TR –P OPTION A A (1.38) .055 (1.70) .067 (Shrouded options removed for clarity) CLE -1 NO. PINS PER ROW (4.57) .180 –DH OPTION - 01 - 04 thru 90 PLATING OPTION - –ES OPTION DV –G OTHER OPTION = Alignment Pin (5 positions minimum) Metal or plastic at Samtec discretion (–DV only) –ES = Dual Horizontal (50 positions maximum) No. of positions x (0.80) .0315 - FLEX SHROUD OPTIONS - = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) OPTIONS –A = 10 µ” (0.25 µm) Gold = Alignment Pin (4 positions minimum) Metal or plastic at Samtec discretion. No. of positions x (0.80) .0315 + (0.38) .015 –K = (3.50 mm) .138" DIA Polyimide film Pick & Place Pad (8 positions minimum) (3.18) .125 –P = Metal Pick & Place Pad (8 positions minimum) (3.12) .123 Note: Some lengths, styles and options are non-standard, non-returnable. –TR (3.30) .130 = Tape & Reel (4.83) .190 samtec.com?FTE or samtec.com?CLE –P OPTION –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) F-221 (Rev 29MAR21) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FTE-113-02-G-DV-A
1. 物料型号:FTE/CLE系列,具有不同的引脚排列和选项。 2. 器件简介:这些连接器设计用于SMT应用,具有0.80毫米(0.0315英寸)的引脚间距。 3. 引脚分配:提供不同数量的引脚每排,从01到90不等,具体取决于选择的型号。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 端子材料:磷青铜 - 接触材料:铍铜 - 电流额定值:每针2.7A(当2针供电时) - 操作温度范围:-55°C至+125°C - 插入深度:根据CLE型号,有不同选项。 5. 功能详解:包括不同的引脚样式、端子样式、尾选项、柔性护罩等。 6. 应用信息:适用于需要高电流和高温操作环境的应用。 7. 封装信息:提供了详细的引脚和端子尺寸,以及不同的端子样式和选项。
FTE-113-02-G-DV-A 价格&库存
很抱歉,暂时无法提供与“FTE-113-02-G-DV-A”相匹配的价格&库存,您可以联系我们找货
