FW-10-03-L-D-215-075-A-TR
    SAMTEC(申泰)
    .050'' BOARD SPACERS
FW-10-03-L-D-215-075-A-TR 数据手册
F-212 FW–20–05–F–D–610–065 (1,27mm) .050" FW–12–05–G–D–530–101 FW SERIES SMT MICRO BOARD STACKER SPECIFICATIONS Low profile or skyscraper styles Mates with: CLP, FFSD, FLE For complete specifications and recommended PCB layouts see www.samtec.com?FW-SM APPLICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1,27µm) Ni Current Rating: 1.75A @ 80°C ambient Operating Temp Range: -55°C to +125°C RoHS Compliant: Yes Variable board spacing FW MATED HEIGHT CLP LEAD STYLE FW FW-XX-03-X-X-233-065 Processing: MATED CLP HEIGHT* – 02 (9,91) .390 FW-XX-03-X-X-303-065 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10mm) .004" max (02-30) (0,15mm) .006" max (31-50) (8,13) .320 *Processing conditions will affect mated height. ALSO AVAILABLE NO. PINS PER ROW FW • Smaller stack heights. Call Samtec. 02 thru 50 LEAD STACKER STYLE HEIGHT PLATING OPTION LEAD STYLE Specify LEAD STYLE from chart (5,46) (8,51) (7,11) (10,16) .215 to .335 .280 to .400 –05 (8,64) (15,49) (10,29) (17,15) .340 to .610 .405 to .675 No. of positions x (1,27) .050 D –F –“XXX” = Stacker Height (in inches) –L BILITY EL AVAILA TAPE & RE arges. No tooling chthe lesser of der is Minimum orantity or 125 pieces. a full reel quantity above minimum. Order any qudesign, manufacture. In-house turn-around. Quick (0,41) .016 SQ –“XXX” = Post Height (in inches) = 10µ" (0,25µm) Gold on post, Gold flash on tail (3,45) .136 x (5,08) .200 100 (4,76) .188 01 (1,27) .050 99 (1,19) .047 POST HEIGHT (1,65) .065 MIN (1,65mm) .065" minimum Example: –065 = (1,65mm) .065" –G (4,27) .168 (4,06) .160 (0,76) .030 –ES –P STACKER HEIGHT s ion for specificat Call Samtecring information. and orde POST HEIGHT Example: –250 = (6,35mm) .250" = 10µ" (0,25µm) Gold on post, Matte Tin on tail (3,42) .135 (1,27) .050 Surface mount STACKER HEIGHT = Gold flash on post, Matte Tin on tail STACKER + POST –03 02 (1,27mm x 1,27mm) .050" x .050" micro pitch (2,51) .099 (1,91) .075 DIA (3,05) .120 (2,92) .115 –EP Note: This Series is non-standard, non-returnable. WWW.SAMTEC.COM (0,89) .035 DIA (0,86) .034 OPTION –ES = End Shroud (–075 post height only. Mate only with CLP) (5,46mm) .215" to (15,49mm) .610" stacker height only 9 pins/row min. –EP = End Shroud with Guide Post (–075 post height only. Mate only with CLP.) (5,46mm) .215" to (15,49mm) .610" stacker height only) 9 pins/row min. –A = Alignment Pin (3 positions min.) (5,46mm) .215" to (15,75mm) .620" stacker height only –P = Pick & Place Pad (5 positions min.) –TR –A = Tape & Reel (Post+Stacker Height = (17,46mm) .687 max.)
FW-10-03-L-D-215-075-A-TR 价格&库存
很抱歉,暂时无法提供与“FW-10-03-L-D-215-075-A-TR”相匹配的价格&库存,您可以联系我们找货
