FW-10-03-L-D-255-075-A 数据手册
REVISION CW
DO NOT
SCALE FROM
THIS PRINT
NOTES:
FW-XX-XX-XX-D-XXX-XXX-XX
PATENT NUMBERS
1. C REPRESENTS A CRITICAL DIMENSION.
5713755 / 5961339
2. MINIMUM PUSHOUT FORCE SHALL BE 1 LB.
3. GOLD AREA TO APPEAR ON POST.
POSITION SPEC
4. TAILS TO BE SHEARED TO DIMENSION SHOWN.
No. OF POS PER ROW
(FOR HAND TOOLING ONLY)
-02 THRU -50
5. TO BE VALID ALL PART NUMBERS MUST MEET THE
FOLLOWING PARAMETERS: THE BOARD SPACE
LEAD STYLE
RANGE, POST HEIGHT MIN. AND BOARD + POST
-03: USE T-1S15-XX-X
COMBINATION FOR EACH STYLE.
-05: USE T-1S15-XX-X
6. MAXIMUM BURR: .003[0.08] ON CUT TAIL.
(SEE TABLE 1)
7. MAXIMUM CUT FLASH TO BE .010[0.25] ON CRITICAL
AREAS AS SHOWN.
PLATING
8. AVAILABLE ONLY W/BOARD SPACE .215[5.46]
-G: 10µ" GOLD IN CONTACT AREA,
TOP .610[15.49].
3µ" GOLD ON TAIL
9. PARTS TO BE ASSEMBLED WITH ALIGNMENT HOLES
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
(IN BODY) FACING THE TAILS
MATTE TIN ON TAIL
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
10. LOWER BODY MAY BE BLACK OR WHITE.
MATTE TIN TAIL
11. FOR FTS-XX-DV, FILL BODY SO THAT THE LEAD IN OF THE CORE IS
-H: 30µ" GOLD IN CONTACT AREA,
ON THE TAIL SIDE.
3µ"
GOLD ON TAIL
12. MAXIMUM HEIGHT VARIATION BETWEEN ROWS: .005[0.13].
-LM: 10µ" SELECTIVE GOLD IN CONTACT AREA,
13. FOR ADDED MECHANICAL STABILITY, SAMTEC
MATTE TIN TAIL
RECOMMENDS MECHANICAL BOARD SPACERS
-FM: 3µ" SELECTIVE GOLD IN CONTACT AREA,
BE USED IN APPLICATIONS WITH GOLD OR SELECTIVE
MATTE TIN ON TAIL
GOLD PLATED CONNECTORS. CONTACT
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
IPG@SAMTEC.COM FOR MORE INFORMATION.
MATTE TIN ON TAIL
14. SUB-FW-50-03-XX-D-280-015 TO USE T-1S15-08,
SUB-FW-50-05-XX-D-400-065 TO USE T-1S15-03.
02
CL
OPTION
-P: PICK & PLACE PAD (USE PPP-25)
(USE PPP-25-NT WITH -TR ONLY)
(SEE FIG. 3, SHT 2)(5 POS. MIN)
-TR: TAPE & REEL
.740[18.80] MAX OVERALL HEIGHT AVAILABLE FOR
-TR. MAX OVERALL HEIGHT = POST + BOARDSPACE
+ PAD + ALIGNMENT PIN = .740[18.80]
-ES: END SHROUDS (SEE FIG. 5, SHT 2)
(9 POS PER ROW MIN)
(MAX POST: .075[1.91])
(SEE NOTE 8)
-EP: GUIDE POST (FIG. 6, SHT 3)
(9 POS PER ROW MIN)
(USE ONLY WHEN MATING WITH CLP)
(SEE NOTE 8)
-A: ALIGNMENT PIN (MOLDED OR STAKED, SAMTEC'S
DISCRETION ON WHICH)
(SEE FIG. 7 & 8 SHT 3)
(STAKED: 6 POS. MIN)(MOLDED: 3 POS. MIN)
(SEE NOTE 8)
POST HEIGHT (SEE NOTE 5)
.065[1.65] MIN
POST + BOARD SPACE = "F" =
-03: .150-.400 [3.81-10.16]
*.401-.675 [10.19-17.15]
-05: *150-.400 [3.81-10.16]
(NO OF POSITIONS X .050[1.27]) ±.010[0.25]
50
BOARD SPACE OPTION (SEE NOTE 5)
SEE TABLE 1
-03 LEAD STYLE (.085[2.16 MIN - .335[8.51] MAX)
-05 LEAD STYLE (.248[6.30] MIN - .610[15.49] MAX)
MAX = "A" - POST (SEE TABLE 1)
DOUBLE ROW
(SEE TABLE 1 FOR BODY STYLE)
CL
.135 3.43 REF
* = FOR EXISTING CUSTOMERS ONLY
.050 1.27 REF
01
.016 0.41
SQ REF (TYP)
49
SEE NOTE 7
.050 1.27 REF
2 MAX SWAY
(EITHER DIRECTION)
POST HEIGHT
(SEE NOTE 12)
.070 1.78 REF
(CONTACT AREA)
.034 0.86 REF
FTS-XX-DV
C
T-1S15-XX-X
02-30POS. = .004[.010]
31-50 POS. = .006[0.15]
C
C .229±.010 5.82±0.25
(SEE NOTE 4)
FIG 1
90°±4° C
"A" ±.005[0.13]
(BOARD SPACE)
"F"
+.005
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
ANGLES
.XX: .01[0.3]
5
.XXX: .005[0.13]
.XXXX: .0020[0.051]
MATERIAL:
+0.13
0.00
.050 - .000 1.27
SEE NOTE 7
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 4:1
DESCRIPTION:
BODY: LCP, UL 94 VO, COLOR: FTS-50-DV & FTSH-50-D: BLACK .050 x .050
FW-50-D: NATURAL
DWG. NO.
TERMINAL: PHOS BRONZE
MAX FLASH ALLOWED: .002[0.05]
MAX GATE VESTIGE: .002[0.05]
F:\DWG\MISC\MKTG\FW-XX-XX-XX-D-XXX-XXX-XX-MKT.SLDDRW
SURFACE MOUNT BOARD SPACERS
BY:
BRATCHER 11-03-1994
SHEET 1 OF 4
IN-PROCESS 3
IN-PROCESS 2
REVISION CW
IN-PROCESS 1
.248[6.30] - .610[15.49]
FTSH-XX-D
.065 1.65 MIN
(SEE NOTE 12)
.065 1.65 MIN
(SEE NOTE 12)
.099 2.51
REF (TYP)
.065 1.65 MIN
(SEE NOTE 12)
.099 2.51
REF (TYP)
BOARD SPACE - .050[1.27]
.099 2.51
REF (TYP)
"F"
"F"
+.005
+0.13
0.00
.149 - .000 3.78
.125±.010 3.18±0.25
(SEE NOTE 4)
FTSH-XX-D
+.005
+0.13
.115 - .001 2.92 - 0.03
C
.229±.010 5.82±0.25
.229±.010 5.82±0.25
T-1S15-03-X
NOTE: SHEAR TAILS TO DIM SHOWN.
FIG 4
DIFFERENT AS SHOWN, OTHERWISE THE SAME AS FIG 1
No OF POSITIONS x .050[1.27] + .101[2.57] 34.32
±.008[.20]
.188 4.78 REF
.265 6.73 REF (TYP)
ES-FTSH
.168 4.27
REF
"C"
+0.13
.115+-.005
.000 2.92 0.00
FIG 5
SCALE 2:1
-ES OPTION
9 POSITION MINIMUM (SEE NOTE 8)
((NO OF POS X .025[.635] - .100[2.54])±.010[.25]
"E" REF
.200 5.08 REF
.160 4.06 REF
.317 8.05 REF
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
FIG 3
SHOWN WITH LEAD STYLE -03
SHEET SCALE: 4:1
(PICK AND PLACE PAD)
(5 POSITION MINIMUM)
DESCRIPTION:
.050 x .050 SURFACE MOUNT BOARD SPACERS
DWG. NO.
BY:
BRATCHER 11-03-1994
SHEET 2 OF 4
REVISION CW
T-1S15-03-X
FTSH-50-D
FTS-XX-DV
FTSH-50-D-XX
(HAND TOOL)
.050 1.27
+.005
+0.13
0.00
.115 - .000 2.92
+.005
.125±.010 3.18±0.25
+0.13
0.00
C .050 - .000 1.27
IN-PROCESS 2
.050 1.27 REF
.034 0.86
FULL RADIUS
(No OF POS-2) x .050[1.27]
.035 0.89
IN-PROCESS 1
IN-PROCESS 3
(SEE NOTE 4)
IN-PROCESS FOR FIG 1
(FOR HAND FILL ONLY)
FIG 7
-A OPTION (MOLDED)
MOLD 3 POSITION MIN
DIFFERENT AS SHOWN OTHERWISE SAME AS FIG 1
(No OF POS x .050[1.27] + .156[3.96])±.008[0.20]
.188 4.78 REF
(No OF POS x .050[1.27] + .231[5.87]])±.008[0.20]
T-1S15-03-X
FTSH-50-D
.330 8.38 REF (TYP)
FTSH-50-D
(HAND TOOL)
.075 1.91
REF (TYP)
FTSH-EP
.115+-.005
.000
2.92+0.13
0.00
"D"
.120 3.05
REF (TYP)
SM-A9H
(No OF FINISHED POS
PER ROW - 2) x.050[1.27]
+0.13
.115+-.005
.000 2.92 0.00
.034 0.86 REF
.035 0.89 REF
C
FIG 6
-EP OPTION
USE ONLY WHEN MATING TO CLP
(9 POSITION MIN)
(SEE NOTE 8)
DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1
FIG 8
-A OPTION (STAKED)
6 POSITION MIN
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 4:1
DESCRIPTION:
DWG. NO.
BY:
BRATCHER 11-03-1994
SHEET 3 OF 4
REVISION CW
IN-PROCESS 1
IN-PROCESS 3
IN-PROCESS 2
.065 1.65 MIN
.065 1.65 MIN
.065 1.65 MIN
(SEE NOTE 12)
(SEE NOTE 12)
(SEE NOTE 12)
.099 2.51 REF
"F"
"F"
BOARD SPACE - .100[2.54]
.099 2.51 REF
.199±.010 5.05±0.25
C
+0.13
.115+-.005
.001 2.92 - 0.03
.175±.010 4.45±0.25
(SEE NOTE 4)
.229±.010 5.82±0.25
.229±.010 5.82±0.25
IN-PROCESS FOR -A OPTION
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 4:1
DESCRIPTION:
DWG. NO.
BY:
BRATCHER 11-03-1994
SHEET 4 OF 4
