FWS-13-01-T-S
FWS-13-01-T-S
    SAMTEC(申泰)
    HEADER 13 POS HI TEMP THRU HOLE
FWS-13-01-T-S 数据手册
F-224 SUPPLEMENT HFWS–06–02–T–S–RA FWS–06–01–T–S SW–10–04–T–S–350–150 (5.08 mm) .200" FWS, HFWS, SW SERIES POWER TERMINAL STRIP FWS, HFWS Mates with: PSS, HPF SW Mates with: PSS, HPF SPECIFICATIONS For complete specifications see www.samtec.com?FWS www.samtec.com?HFWS or www.samtec.com?SW Insulator Material: Glass Filled Polyester (FWS, SW-TH) Liquid Crystal Polymer (HFWS, SW-VS) Terminal Material: Phosphor Bronze Plating: Sn over 50 µ" (1.27 µm) Ni Current Rating (FWS/PSS): 11.4 A per pin (1 pin powered) Operating Temp Range: -55 °C to +105 °C Voltage Rating: 500 VAC mated with PSS RoHS Compliant: Yes PROCESSING Lead–Free Solderable (HFWS–VS, SW-VS): Yes SMT Lead Coplanarity (FWS, HFWS): (0.20 mm) .008" max (02-15)* (0.25 mm) .010" max (16-20)* SMT Lead Coplanarity (SW): (0.25 mm) .010" max* *(.004" stencil solution may be available; contact ipg@samtec.com) TYPE STRIP NO. PINS LEAD STYLE FWS = Matte Tin HFWS = High Temp Header C A 01 thru 20 = Surface Mount with Pick & Place Pad (3 Pos. min.) (6.98 mm) .275" min. post height LEAD STYLE –01 –02 –04 (2.54) .100 –05 No. of Positions X (5.08) .200 NO. PINS SW G –RA A (4.57) .180 (4.57) .180 (4.09) .161 (4.57) .180 B –T = Matte Tin C D E F STACK HEIGHT S Note: Some lengths, styles and options are non-standard, non-returnable. –RA G = Right-angle –VS = Surface Mount (2 pins/row minimum) Requires HFWS POST HEIGHT –“XXX” = Stacker Height (in inches) (0.13 mm) .005" increments Example: –250 = (6.35 mm) .250" –“XXX” = Post Height (in inches) (5.08) .200 TYP STACK HEIGHT (22.61) .890 MAX WITH (0.00) .000 POST (7.62) .300 MIN Leave blank for Through-hole –VS 02 thru 20 POST HEIGHT (0.00) .000 MIN (2.54) .100 (11.94) — (8.64) — — (10.72) .470 .422 .340 (13.21) (2.54) (4.57) (8.08) (12.24) (8.38) .520 .100 .180 .318 .482 .330 (21.06) (4.95) (3.96) (13.82) — — .829 .195 .156 .544 (3.81) — — — — — .150 PLATING OPTION 04 F D (6.35) .250 (5.08) .200 TYP (1.14) .045 SQ = Standard Stacker FILE NO. E111594 E (0.51) .020 STACK HEIGHT (2.54) (20.83) .820 .100 MAX (5.08) .200 MIN (1.14) .045 (2.29) .090 OTHER OPTION –VS–P Specify LEAD STYLE from chart below. B TYPE STRIP TAIL OPTION S –T = Standard Header RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality PLATING OPTION (25.91) 1.02 MAX TAIL OPTION Leave blank for Through-hole –VS =Surface Mount (2 pins/row minimum) –VS–P = Surface Mount with Pick & Place Pad (3 Pos. min.) (6.98 mm) .275" max. post height WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FWS-13-01-T-S
1. 物料型号:文档中提到了SW–10–04–T–S–350–150和HFWS–06–02–T–S–RA等型号。 2. 器件简介:FWS和HFWS系列是电源端子条,与PSS和HPF系列兼容。SW系列是端子条,与PSS和HPF系列兼容。 3. 引脚分配:文档中提到了不同型号的引脚数量,例如01至20引脚。 4. 参数特性: - 绝缘体材料:FWS和SW-TH为玻璃填充聚酯,HFWS和SW-VS为液晶聚合物。 - 端子材料:磷青铜。 - 镀层:锡镀层,厚度超过50微英寸(1.27微米)的镍。 - 电流额定值:FWS/PSS每针11.4安培(单针供电)。 - 工作温度范围:-55°C至+105°C。 - 电压额定值:与PSS配合使用时为500 VAC。 - 符合RoHS标准。 5. 功能详解:文档提供了端子条的不同类型、引脚样式、引脚选项、尾选项和镀层选项的详细信息。 6. 应用信息:文档中提到了端子条的应用,例如通过孔安装和表面安装选项。 7. 封装信息:提供了端子条的尺寸和堆叠高度等封装信息
FWS-13-01-T-S 价格&库存
很抱歉,暂时无法提供与“FWS-13-01-T-S”相匹配的价格&库存,您可以联系我们找货
