HLE-137-02-L-DV-TE
HLE-137-02-L-DV-TE
    SAMTEC(申泰)
    .100 TIGER BEAM SOCKET ASSEMBLY
HLE-137-02-L-DV-TE 数据手册
F-215 HLE–130–02–F–DV HLE–110–02–L–DV HLE–116–02–L–DV–K (2,54 mm) .100" HLE SERIES COST-EFFECTIVE RELIABLE SOCKET Mates With: TSW, MTSW, DW, EW, ZW, TLW, TSM, MTLW, HW HLE NO. PINS 1 PER ROW PLATING OPTION 02 TAIL OPTION DV OTHER OPTION SPECIFICATIONS –BE For complete specifications and recommended PCB layouts see www.samtec.com?HLE = Bottom Entry (N/A with –TE) –F = Gold flash on contact, Matte Tin on tail Insulator Material: Black Liquid Crystal Polymer Contact Material: BeCu Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating (HLE/TSM): 4.1 A per pin (1 pin powered per row) Voltage Rating: 400 VAC Operating Temp Range: -55°C to +125°C Insertion Depth: (1,78 mm) .070" to (3,43 mm) .135", pass-through, or (2,59 mm) .102" min plus board thickness for bottom entry Insertion Force: (Single contact only) 2 oz (0,56 N) avg. Withdrawal Force: (Single contact only) 1.6 oz (0,44 N) avg. RoHS Compliant: Yes Leave blank for Surface Mount –L = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail –A = Alignment Pin (4 positions min.) Metal or plastic at Samtec discretion (N/A with -TE, -PE & -LC) (3,66) .144 (6,60) .260 (1,27) .050 (Requires –BE for Bottom Entry) (1,60) .063 DIA 02 thru 50 –LC –TE = Through-Hole Top Entry = Locking Clip (2 positions min.) (N/A with -A) (Manual placement required) (1,27) .050 Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (02-20) (0,15 mm) .006" max (21-50) (3,05) .120 (2,54) .100 RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –K (2,54) .100 No. of Positions x (2,54) .100 02 (5,08) .200 (2,54) .100 –PE = Through-hole Pass-Through Entry 01 FILE NO: 090871_0_000 (1,42) .056 = (6,50 mm) .256" DIA Polyimide Film Pick & Place Pad (3 positions min.) Not available with –TE or –PE tail option –P ALSO AVAILABLE (3,51) .138 (MOQ Required) • Other platings Contact Samtec. = Metal Pick & Place Pad (3 positions min.) (0,51) .020 (2,30) .090 –PE –TE (7,11) .280 x (5,71) .225 (7,62) .300 (3,86) .152 (Requires –BE for Bottom Entry) –TR = Tape & Reel Packaging (29 positions max.) Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
HLE-137-02-L-DV-TE
1. 物料型号:文档列出了几种型号,例如HLE-130-02-F-DV、HLE-110-02-L-DV和HLE-116-02-L-DV-K。
2. 器件简介:HLE系列插座是一种成本效益高且可靠的插座,与多种Samtec产品兼容,如TSW、MTSW等。
3. 引脚分配:文档中没有明确提供引脚分配的详细信息,但提到了引脚数量范围从2到50。
4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 接触材料:铍铜 - 镀层:金或锡,覆盖在50微米(1.27微米)镍上 - 电流额定值:每排每针4.1安培(每行只供电1针) - 电压额定值:400 VAC - 操作温度范围:-55°C至+125°C - 插入深度:0.070"至0.135",穿透或至少0.102"加上板厚用于底部入口 - 插入力:单接触2盎司(0.56牛顿)平均 - 拔出力:单接触1.6盎司(0.44牛顿)平均 - 符合RoHS标准
5. 功能详解:文档提供了插座的详细规格和推荐PCB布局,可在Samtec官网上查看。
6. 应用信息:文档中没有提供具体的应用信息,但提到了插座与Samtec的其他产品兼容。
7. 封装信息:提供了不同选项,如底部入口(-BE)、对齐销(-A)、锁定夹(-LC)、顶部入口(-TE)、穿透入口(-PE)和胶带卷装(-TR)。
HLE-137-02-L-DV-TE 价格&库存
很抱歉,暂时无法提供与“HLE-137-02-L-DV-TE”相匹配的价格&库存,您可以联系我们找货
HLE-137-02-L-DV-TE
  • 6+85.597406+11.07333
