BCS-130-F-S-TE
BCS-130-F-S-TE
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 1x30P 直插
BCS-130-F-S-TE 数据手册
BCS–108–L–D–HE F-218 (Rev 10OCT17) BCS–110–L–S–DE BCS–110–L–S–HE 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES BCS–115–L–D–TE BCS–112–L–D–PE (2.54 mm) .100" BCS SERIES TIGER CLAW PASS-THROUGH SOCKET ™ Mates with: TSW, MTSW, HTSW, HMTSW, TSS, ZSS, DW, EW, ZW, HW, TSM, MTLW, PHT 1 BCS PLATING OPTION NO. PINS PER ROW SPECIFICATIONS –S = Gold flash on contact, Matte Tin on tail Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (BCS/TSW): 4.6 A per pin (2 pins powered) Voltage Rating: 475 VAC (-TE/-DE/-PE mated with TSM) 450 VAC (-HE mated with TSW) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (4.34 mm) .171" to (7.24 mm) .285" from top, (5.64 mm) .222" plus board thickness minimum from bottom. –HE is (4.34 mm) .171" to (6.35 mm) .250" RoHS Compliant: Yes Lead–Free Solderable: Yes OTHER OPTION –“XXX” = Single –F For complete specifications see www.samtec.com?BCS ENTRY OPTION ROW OPTION = Polarized Position (–BE not available) –D = Double –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail 01 thru 50 –TE 01 = Top Entry 02 (0.25) .010 (2.54) .100 (3.05) .120 (2.54) .100 (0.89) .035 SQ TYP 02 –DE (2.54) .100 (5.08) .200 01 RECOGNITIONS (3.05) .120 (2.54) .100 x No. of Positions (0.25) .010 (4.06) .160 (1.78) .070 For complete scope of recognitions see www.samtec.com/quality (7.37) .290 = Top Entry (For Bottom Entry specify –DE–BE) Cannot be used with plated through-holes –PE FILE NO. E111594 (3.25) .128 (0.48) .019 (2.54) .100 (0.51) .020 (0.25) .010 (5.08) .200 ALSO AVAILABLE (7.62) .300 = Passthrough Entry (For Bottom Entry specify –PE–BE) (MOQ Required) • Other platings Contact Samtec. APPLICATIONS BCS TSW (0.89) .035 SQ TYP (8.13) .320 (2.79) .110 (3.18) .125 (0.25) .010 HORIZONTAL Note: Some lengths, styles and options are non-standard, non-returnable. –HE = Horizontal Entry (5.72) .225 (5.33) .210 (0.51) .020 (2.54) .100 (3.18) .125 (7.87) .310 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
BCS-130-F-S-TE 价格&库存
很抱歉,暂时无法提供与“BCS-130-F-S-TE”相匹配的价格&库存,您可以联系我们找货
BCS-130-F-S-TE
  • 7+38.512887+4.97169
