F-215
CLE–125–01–G–DV
CLE–108–01–G–DV
CLE–130–01–G–DV
(0,80 mm) .0315"
CLE SERIES
COST EFFECTIVE MICRO SOCKET
SPECIFICATIONS
Ideal for
pass-through
applications
Mates with:
FTE, AW
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLE
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
BeCu
Plating:
Au over 50µ" (1,27 µm) Ni
Current Rating (CLE/FTE):
2.7 A per pin
(1 pin powered per row)
Operating Temp Range:
-55°C to +125°C
Contact Resistance:
15 mΩ
Insertion Depth:
Top Entry = (1,73 mm) .068"
to (3,18 mm) .125" with
(0,38 mm) .015" wipe, or
pass-through
Bottom Entry = (3,23 mm) .127"
minimum plus
board thickness
Insertion Force:
(Single contact only)
2.0 oz (0,56 N)
Normal Force:
75 grams (0,73 N)
Withdrawal Force:
1.2 oz (0,33 N)
Max Cycles:
100 with 10µ" (0,25 µm) Au
RoHS Compliant:
Yes
OPTIONS
–TR OPTION
(0,80 mm) .0315"
micro pitch
–P OPTION
Surface
Mount
CLE
1
NO. PINS
PER ROW
PLATING
OPTION
01
DV
OPTIONS
–A
Processing:
–G
04 thru 90
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (04-65)
(0,15 mm) .006" max (66-90)
= 10µ" (0,25 µm) Gold
= Alignment Pin
(4 positions minimum)
Metal or plastic at
Samtec discretion.
–K
RECOGNITIONS
= (3,50 mm) .138" DIA
Polyimide film
Pick & Place Pad
(8 positions minimum)
No. of positions x (0,80) .0315
(0,80)
.0315
For complete scope of
recognitions see
www.samtec.com/quality
02
(3,18)
.125
(1,20)
.047
(0,30)
.012
(4,39)
.173
x
(6,35)
.250
–P
= Metal Pick &
Place Pad
(3,51)
.138
01
–TR
= Tape & Reel
Packaging
–P OPTION
BILITY
EL AVAILA
TAPE & RE
(3,12)
.123
(3,30)
.130
(4,83)
.190
Note: Some lengths, styles
and options are non-standard,
non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
arges.
No tooling chthe lesser of
der is
Minimum orantity or 125 pieces.
a full reel quantity above minimum.
Order any qudesign, manufacture.
In-house turn-around.
Quick
ions
for specificat
Call Samtecring information.
and orde
很抱歉,暂时无法提供与“CLE-137-01-G-DV-A”相匹配的价格&库存,您可以联系我们找货
