F-218
SS–132–G–2
ESD–115–TT–05
(2.54 mm) .100"
SS, SD, ESD, ESS, HSS SERIES
PRECISION MACHINED SOCKET STRIPS
Mates with:
TS, TD, HTS, BBS,
BBD, BBL, BDL, BHS
TYPE
STRIP
NO. PINS
PER ROW
1
PLATING
OPTION
LEAD
STYLE
OTHER
OPTION
OPTION
SPECIFICATIONS
For complete specifications
see www.samtec.com?SS,
www.samtec.com?ESS,
www.samtec.com?SD,
www.samtec.com?ESD or
www.samtec.com?HSS
Insulator Material:
SS, SD, ESS, ESD=
Black G.F. Polyester
HSS=
Black Liquid Crystal Polymer
Contact:
BeCu
Shell:
Brass except Style 5A
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni or
Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
Lead Size Range:
(0.38 mm to 0.56 mm)
.015" to .022" DIA
and most IC leads
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
–S
01 thru 32
= SS, ESS Series
01 thru 36
= 30 µ" (0.76 µm) Gold contact,
Tin shell
SS
= Standard
= High Temp
Single Row Socket Single Row Socket
10 µ" (0.25 µm) Gold shell
(MOQ Required)
• Locking lead option on ESS
and ESD series
Contact Samtec.
Styles – 5A & –05 socket
heads not countersunk.
(2.54) .100 x No. of Positions
–1A, –1B or –1C
(2.54)
.100
(4.90)
.193
(1.32)
.052
DIA
(2.54)
.100
ESD
(2.54)
(2.54)
.100 TYP
= (2.54)
Standard Double
(5.08)
.100
.200
Row Socket
(2.54)
.100
(0.76)
.030
Y
= Elevated Double
(2.54)
Row Socket .100
LEAD STYLE
Y
–1A or –21A
(9.14)
.360
(12.95)
.510
(6.60)
.260
–1B or –21B
(0.64)
.025 SQ
Style –(2.54)
5A not available.
TYP& –05 socket
Styles.100
–5A
–1C or –21C
(0.76)
.030
B
A
C
(0.64)
.025
SQ
–2, –22*,–5A,
or –38*
*For LIF specify –22 or –38 (SS, HSS, SD)
(2.54)
.100
(5.08)
.200
For LIF specify –23
(ESS, ESD)
(1.83)
.072 DIA
(2.54)
.100
SD
–03, –04, –05
For LIF specify –21A, –21B or –21C
(SS, HSS, SD)
(2.54)
.100 TYP
N/A Style –5A
ALSO AVAILABLE
= Tin contact and shell
(Styles 1, 2, 4, and 05
except LIF N/A)
= Elevated Single Row Socket
(0.76)
.030
REF
Requires -T Plating Option
–TT
ESS
= Non
Flush
(7.62)
.300
(3.43)
.135
–G
HSS
–N
Locking
Socket
Add –L suffix for locking
lead socket in end positions.
Requires Style -2 or -22 and
.035" ± .003 DIA board hole.
–T
= HSS, SD & ESD Series
FILE NO. E111594
(1.83)
.072
DIA
(2.54)
.100 TYP
(0.76)
.030
(2.54)
.100
(1.32)
.052
DIA
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–L
= 10 µ" (0.25 µm) Gold contact,
Tin shell
(Styles 2 & 22 only)
X
LIF= Low Insertion Force
LEAD
STYLE
–2 or –22
Z
–38
–5A
Y
X
DIA
Y
Z
(0.51) (3.18) (7.62)
.020
.125
.300
(0.51) (4.57) (8.89)
.020
.180
.350
(0.89) (12.95) (17.86)
.035
.510
.703
LEAD
STYLE
B
C
–05
–03 or
–23
(11.51) (8.38) (3.12)
.453
.330 .123
–04
(14.05) (10.92) (3.12)
.553
.430 .123
Locking lead available. See OPTION.
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
A
(17.86) (13.46) (4.39)
.703
.530 .173
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“ESS-110-G-07”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+54.963101+7.10948
