REVISION AO
DO NOT
SCALE FROM
THIS PRINT
NOTES:
1. HIDDEN LINES ARE USED TO SHOW POLARIZATION
FFSD-XX-X-XX.XX-01-X-X-XXX
WHEN USING -N OPTION.
C
2.
REPRESENTS A CRITICAL DIMENSION.
3. FFSD CABLE ASSEMBLIES ARE LEAD FREE.
4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED
FOR SHORTS AND OPENS.
C
5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 630V.
No OF POSITIONS
6. STRAIN RELIEF TO WITHSTAND 5LB[22N] STRAIGHT PULL.
-02 THRU -25
7. NOTE DELETED.
(PER ROW)
8. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND
END ASSEMBLY
PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE
THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF CABLE THICKNESS
-S: SINGLE END
ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR.
-D: DOUBLE END
9. REFERENCE FFSD-XX-XX-X-N-XXX FOR CONNECTOR ASSEMBLY
DIMENSIONS AND ITS REQUIREMENTS.
ASSEMBLY LENGTH
10. COLORED WIRE MUST MATCH FIRST POSITION INDICATOR
-D"XX", -R, -M & -O OPTION: 2.00[50.8] MINIMUM
ON THE FIRST CONNECTOR FOR ALL OPTIONS WITH THE
ALL OTHER OPTION: 1.00[25.4] MINIMUM
EXCEPTION OF -RW.
11. FOR LENGTHS LESS THAN 12.5", TOLERANCE SHALL BE +/-.125,
LEAD STYLE
ALL OTHER LENGTHS SHALL BE +/-1%.
PLATING OPTIONS
- LEAVE BLANK FOR STANDARD, USE C-67-L
-S: USE C-67-S
-F: USE C-67-F
C
XX.XX[XX.X x 25.4]±1%
(SEE NOTE 8 & 11)
OPTION
-RW: REVERSE WIRING
(NOT AVAILABLE WITH -RN1 OR -RN2)
-D"XX": DAISY CHAIN (MINIMUM 2.00[50.8],
1.00[25.4] INCREMENTS)
-R: REVERSED
(NOT AVAILABLE WITH -M OR -O)
(MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS)
-RN1: REVERSE POLARIZATION NOTCH
(NOT AVAILABLE WITH -RW OR -RN2)
-RN2: REVERSE POLARIZATION NOTCH
(NOT AVAILABLE WITH -RW OR -RN1)
-M: MIDDLE REVERSE
(NOT AVAILABLE WITH -R OR -O)
-O: OUTSIDE REVERSE
(NOT AVAILABLE WITH -R OR -M)
-SR: STRAIN RELIEF
(NOT AVAILABLE WITH -O, -M,
-R, OR -DXX)
(SOLD AS ASSEMBLIES ONLY)
STANDARD POLARIZATION NOTCH
-N: POLARIZATION NOTCH
(NOT AVAILABLE IN -02 THRU -04)
(LEAVE BLANK FOR -02, -03, -04)
.075 1.91
REF
C .120 3.05
REF
C
(No OF POS x .050[1.27])
+ .165[4.19] REF
.006 0.15 MAX
+.006
.010 0.25 MAX
CABLE OVERHANG
(SEE NOTE 8)
2
RED WIRE TO SIDE
OF FIRST POS INDICATOR
-N OPTION
+0.15
C .200 - .003 5.08 - 0.08
-RN1 OPTION
(SEE NOTE 8 & 11)
-N OPTION
1
.040 1.02
REF
FIG 2
(FFSD-10-S-XX.XX-01-X-N SHOWN)
(SAME AS FIG 1, DIFFERENT AS SHOWN)
NOTCH DENOTES
FIRST POSITION
-RN2 OPTION
FIG 1
(FFSD-10-D-XX.XX-01-X-N SHOWN)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
RED WIRE TO OPPOSITE
SIDE OF FIRST POS. INDICATOR
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
FIG 11
(FFSD-10-X-XX.XX-01-X-N-RW SHOWN)
F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 2:1
INSULATORS: PBT UL94V-0, COLOR: BLACK
CONTACT: BeCu
WIRE: 30 AWG, 7/38, TINNED, STRANDED WITH
GRAY PVC INSULATOR
PLATING: .000010 GOLD OVER .000050 NICKEL
REMAINDER: .000200 REF TIN OVER .000050 NICKEL
DESCRIPTION:
.050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY
DWG. NO.
BY:
T NEWTON
02/15/2008 SHEET 1 OF 4
REVISION AO
FIG 3
(FFSD-10-D-XX.XX-01-X-N-RN1 SHOWN)
FIRST CONNECTOR
XX.XX[XX.X x 25.4] .13[3.2]
(MIN 2")
(MIN 2")
MIDDLE CONNECTOR REVERSED WHEN DAISY CHAINED
OUTSIDE CONNECTOR REVERSED WHEN DAISY CHAINED
FIG 5
FIG 4
SECOND CONNECTOR
(FFSD-10-D-XX.XX-01-X-N-DXX-M SHOWN)
(2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS)
(FFSD-10-D-XX.XX-01-X-N-DXX-O SHOWN)
(FFSD-10-D-XX.XX-01-X-N-RN2 SHOWN)
FIRST CONNECTOR
(MIN 2")
(MIN 2")
FIG 7
(FFSD-10-D-XX.XX-01-X-N-DXX SHOWN)
SECOND CONECTOR
NOTE:
-RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY
( NOT AVAILABLE WITH -R OPTION)
-RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY
(NOT AVAILABLE WITH -R OPTION)
(REVERSE NOTCH NOT AVAILABLE WITH -RW OR ANY
DAISY CHAIN OPTIONS)
BOTH CONNECTORS REVERSED WHEN DAISY CHAINED
PROPRIETARY NOTE
FIG 6
(FFSD-10-D-XX.XX-01-X-N-DXX-R SHOWN)
(NOT AVAILABLE WITH -RN1 OR -RN2 OPTION)
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:
T NEWTON
02/15/2008 SHEET 2 OF 4
REVISION AO
IN-PROCESS 1
(2-15 POS -SR ONLY FOR DOUBLE END)
(No OF POS x .050[1.27]) C
+ .315[8.00] REF
XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18]
4
IN-PROCESS 2
.039 0.99
.335±.010 8.51±0.25
3
C
(XX.XX[XX.XX x 25.4] .13[3.2]
FIG 9
(XX.XX[XX.XX x 25.4] ± .13[3.2])
STRAIN RELIEF OPTION (POS 2-15 ONLY)
(FFSD-10-D-XX.XX-01-X-N-SR SHOWN)
C
IN-PROCESS 1
(16-25 POS -SR ONLY FOR DOUBLE END)
XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18]
IN-PROCESS 2
XX.XX[XX.XX x 25.4]
+0.05
.0228+-.002
.000 0.58 0.00
.13[3.2]
C
DETAIL 'A'
SCALE 8 : 1
IN-PROCESS 3
6
PROPRIETARY NOTE
'A'
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
5
FIG 10
STRAIN RELIEF OPTION (POS 16-25 ONLY)
(FFSD-25-D-XX.XX-01-X-N-SR SHOWN)
(SAME AS FIG 9, DIFFERENT AS SHOWN)
SCALE 1 : 1
SHEET SCALE: 2:1
DESCRIPTION:
DWG. NO.
BY:
T NEWTON
02/15/2008 SHEET 3 OF 4
REVISION AO
IN-PROCESS 1
IN-PROCESS 1
(FFSD-XX-S-XX.XX-01-X-N-RW ONLY)
(16-25 POS -SR ONLY FOR SINGLE END)
(XX.XX[XX.XX x 25.4] ± .125[3.18])
IN-PROCESS 2
IN-PROCESS 1
(2-15 POS -SR ONLY FOR SINGLE END)
XX.XX[XX.XX x 25.4]
.125[3.18]
C
IN-PROCESS 3
IN-PROCESS 2
PROPRIETARY NOTE
C
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
SHEET SCALE: 2.5:1
DESCRIPTION:
DWG. NO.
BY:
T NEWTON 02/15/2008
SHEET 4 OF 4
