FSH–120–04–F–RA–SL
F-224 SUPPLEMENT (Rev 10JAN24)
FSH–110–04–L–DH–SL
SFMH–130–02–L–D–LC
SFMH–105–02–L–D–LC
(1.27 mm) .050"
FSH–120–04–F–DH
SFMH–120–02–L–D
FSH, SFMH SERIES
HIGH-RELIABLE HORIZONTAL
FSH Mates with:
SFMH
SFMH Mates with:
FTSH, FSH
1
FSH
SPECIFICATIONS
NO. PINS
PER ROW
04
05, 10, 15, 20, 25,
30, 35, 40, 45
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
FSH =
Sn or Au over 50 µ" (1.27 µm) Ni
SFMH =
Current Rating (FSH/SFMH):
2.6 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
SFMH =
(3.35 mm) .132" to
(4.57 mm) .180"
RoHS Compliant:
Yes
(3.68)
.145
Lead-Free Solderable:
Yes (FSH)
SMT Lead Coplanarity:
(0.10 mm) .004" max (SFMH)
(0.15 mm) .006" max (FSH)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
(1.27)
.050
(5.21)
.205
–FR
–RA
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(Not available
with -RA)
(3.94)
.155
(3.43)
.135
PROCESSING
= Tape & Reel
(Not available
with –RA)
(2.29)
.090
(3.68)
.145
2 4
(1.27)
.050
13
(1.27)
.050
(1.27) (1.27)
.050 .050
No. of positions + 2 x (1.27) .050
–DH
(0.89)
.035
(0.71)
.028
(1.27)
.050
(2.16)
.085
–RA
= (4.50 mm) .177"
DIA Polyimide
film Pick &
Place Pad
(10 positions
minimum)
not available
with –RA option
–TR
(2.51)
.099
(0.41) .016 SQ
–C
= Right-angle
(Through-hole)
(No. of positions + 4) x (1.27) .050
(6.58)
.259
= Solder Locks
–RA
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(–RA Option)
(Standard sizes)
–SL
= Double Row
Horizontal
(Surface Mount)
= Gold flash on
post, Matte Tin
on tail
(–DH Option)
OPTIONS
–DH
–F
05, 10, 15, 20, 25
For complete specifications
see www.samtec.com?FSH or
www.samtec.com?SFMH
ROW
OPTION
PLATING
OPTION
–DH
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
SFMH
1
NO. PINS
PER ROW
PLATING
OPTION
02
D
–L
FILE NO. E111594
–LC
= 10 µ" (0.25 µm)
Gold on contact,
Gold flash on tail
05, 10, 15, 20, 25, 30, 35, 40, 45, 50
= Locking Clip
(Manual placement
required)
(0.64) .025 TYP
(2.03)
.080
APPLICATIONS
SFMH FSH
HORIZONTAL
(0.41) .016
–WT
No. of Positions x (1.27) .050
+ (2.92) .115
04
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
–WT
(1.65)
.065
(4.57)
.180
(1.27)
.050
02
03 01
(1.50)
.059
= Weld Tab
(Not available with 35,
40, 45, 50 positions)
–TR
= Tape & Reel
–FR
(1.65)
(3.43) .065
.135
No. of Positions x
(1.27) .050 + (1.65) .065
OPTION
(1.41)
.056
DIA
(1.02)
.040
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
–LC
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“FSH-110-04-F-RA”相匹配的价格&库存,您可以联系我们找货
