MICRO LOW PROFILE
TERMINAL STRIPS
(1.27 mm) .050" PITCH • FTS SERIES
FTS
FTS
Board Mates:
CLP, FLE
Cable Mates:
FFSD
-1
NO. PINS
PER ROW
02 thru 50
(except –S & –SA
option = 05 thru 46)
SPECIFICATIONS
LEAD
STYE
PLATING
OPTION
–01
–F
= (3.05 mm)
.120" Post
(Mates with FFSD)
= Gold flash
on post,
Matte Tin
on tail
–02
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Operating Temp Range:
-55 °C to +125 °C
Plating:
Sn or Au over 50 µ" (1.27 µm) Ni
Current Rating:
3.4 A per pin
(2 pins powered)
= (1.91 mm)
.075" Post
(Mates with FLE)
–03
= (1.65 mm)
.065" Post
(Mates with CLP)
ROW
OPTION
–D
(–D & –DV only)
–DV
= End Shroud
with Alignment Pin
(05 thru 46 positions.
Style -02 & -03 only)
= Double
Through-hole
–SA
= Double
Vertical SMT
–L
= 10 µ"
(0.25 µm)
Gold on post,
Matte Tin
on tail
–S
–S
= End Shroud
= Single
Through-hole
–SV
–P
= Single
Vertical SMT
–04
= Pick & Place Pad
(04 positions min.)
= (3.81 mm)
.150" Post
(–D & –DV only)
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
.004" (0.10 mm) max
OTHER
OPTION
–TR
= Tape & Reel
(-DV only)
(Required callout for
positions 02 thru 04)
1RRISRVLWLRQV[
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(-DV only)
ALSO AVAILABLE
Alignment pin
(MOQ Required)
1RRISRVLWLRQV[
²6$
1RRISRVLWLRQV[
²6
OPTIONS
—TR OPTION
(Shrouded option removed for clarity)
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
A
–01
(3.05) .120
–02
(1.91) .075
–03
(1.65) .065
–04
(3.81) .150
—SA OPTION
—P OPTION
LEAD
STYLE
—S
—SV
—DV
—D
—S OPTION
—P OPTION
—S OPTION
—SA OPTION
samtec.com?FTS
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“FTS-116-01-L-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 28+31.71470
- 56+31.03761
- 112+28.88541
- 国内价格 香港价格
- 28+49.7529628+6.44893
- 56+36.6960056+4.75650
- 112+34.10379112+4.42050
