FTSH-128-01-L-D
FTSH-128-01-L-D
    SAMTEC(申泰)
    .050'' X .050 TERMINAL STRIP
FTSH-128-01-L-D 数据手册
F-217 FTSH–120–02–L–D 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT FTSH–120–01–L–D–RA FTSH–125–01–F–D HIGH MATING CYCLES (1.27 mm) .050" FTSH SERIES THROUGH-HOLE MICRO HEADER SPECIFICATIONS For complete specifications see www.samtec.com?FTSH Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (FTSH/CLP): 3.3 A per pin (1 pin powered per row) Operating Temp Range: -55 °C to +125 °C RoHS Compliant: Yes Impedance matched for high-speed applications (Mated with CLP Series) Board Mates: CLP, FLE Cable Mates: FFSD, FFTP (2.51 mm) .099" Mates with socket strips or IDC cable PROCESSING RECOGNITIONS FILE NO. E111594 1 FTSH NO. PINS PER ROW LEAD STYLE Optional end shrouds and ejector shrouds Through-hole, right-angle or surface mount Lead-Free Solderable: Yes For complete scope of recognitions see www.samtec.com/quality (1.27 mm) .050" micro pitch PLATING OPTION D TAIL OPTION OPTION OTHER OPTIONS FILE NO: 090871_0_000 LOCKING CLIP FFSD For single STRIP ASSEMBLY mating LOCKING CLIP cycle with the PC ġ FFSD. BOARD Specify -LC after tail option. Lead Style -01 and 10 pins/row minimum. 5-9 pins/row not available in combination with keying shroud (-K). Specify LEAD STYLE from chart 02 thru 50 02 (1.27) .050 01 02 No. of positions x (1.27) .050 99 (MOQ Required) • Molded Pick & Place pads • Other platings Contact Samtec. (2.29) .090 (2.51) .099 LEAD STYLE – 01 – 02 Note: See SFM/TFM for positive alignment feature. Note: Some sizes, styles and options are non-standard, non-returnable. (3.43) .135 A – 03 – 04 .120 CLP-DH (1.91) FLE .075 (1.65) CLP-D .065 (3.81) N/A .150 – EJ – EP – EL (15.77) .621 (5.87) .231 (6.53) .257 –EL –EP –RA (2.16) .085 MATES OPTION Z (5.08) WITH .200 – ES (1.55) (3.05) FFSD, .061 A –EL = Ejector Shroud (Style –01 only) 10 pins/row min. 25 pins/row max. –RA not available (11.18) .440 –K (1.27) .050 –EJ (3.20) .126 (2.29) .090 –K –EP = End Shroud with Guide Post (Style –02 & –03) 9 pins/row min. –EJ (2.29) .090 (1.27) .050 –ES = End Shroud (Style –02 & –03) 9 pins/row min. = End Shroud with Board Lock (Style –02 & –03) 9 pins/row min. (0.40) .016 SQ 99 (1.27) .050 –RA = Rightangle (1.91) .075 DIA (3.05) .120 100 (1.27)01 .050 Leave blank for straight tail –“XXX” (1.17) .046 (3.43) .135 ALSO AVAILABLE = Polarized Position (Specify position of omitted pin) (Not available with -EX options) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail 100 –EX OPTION SHOWN –L = Gold flash on post, Matte Tin on tail No. of positions x (1.27) .050 + Z (4.78) .188 –F Leave blank for RIght-angle (2.29) .090 –ES –RA –ES WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (1.27) .050 = Keying Shroud for mating with FFSD (Style –01 only, 05, 08, 10, 13, 17, 20 & 25 pins/row only and 13, 17, 20 & 25 only with –EJ option)
FTSH-128-01-L-D 价格&库存
很抱歉,暂时无法提供与“FTSH-128-01-L-D”相匹配的价格&库存,您可以联系我们找货
