HTSS-136-01-G-D
HTSS-136-01-G-D
    SAMTEC(申泰)
    CONN HEADER VERT 72POS 2.54MM
HTSS-136-01-G-D 数据手册
ZSS–113–03–L–D–0735 F-215 HTSS–125–01–L–DV (2,54 mm) .100" TSS, HTSS, ZSS SERIES SHROUDED .025" SQ POST HEADERS Mates with: SSW, SSQ, ESW, ESQ, SSM, BCS TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION 03 Specify LEAD STYLE from chart. –F –D = Gold flash on post, Matte Tin on tail (Not available on -DV) = Double Row Through-hole (lead style –01, –02 & –03 only) ROW OPTION SPECIFICATIONS For complete specifications see www.samtec.com?TSS, www.samtec.com?HTSS or www.samtec.com?ZSS Insulator Material: Black Glass Filled Polyester (TSS, ZSS) Natural PCT (HTSS) Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Flammability Rating: UL 94V-O Withstanding Voltage: 1000 VRMS RoHS Compliant: Yes TSS (TSS only) = Connector Strip 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 HTSS = High Temp Connector Strip LEAD STYLE –01 –02 –03 Processing: Lead–Free Solderable: Yes (HTSS) Wave Only (TSS, ZSS) SMT Lead Coplanarity: (0,15 mm) .006" (Standard sizes.) (2,54) .100 x No. of Positions + (3,81) .150 (2,54) .100 x No. of Positions + (1,27) .050 T/H (A) (2,92) .115 (4,19) .165 (14,35) .565 02 –T –D –D–RA LEAD RIGHT STYLE ANGLE (B) –04 (3,30) .130 –05 (5,84) .230 (9,27) .365 (2,54) .100 01 –DV = Double Row Surface Mount (lead style –01 only) (HTSS only) = Matte Tin (2,54) .100 B (6,35) .250 (10,16) .400 (8,89) .350 A –L = 10µ" (0,25 µm) Gold on post, Matte Tin on tail = Double Row Right Angle (lead style –04 & –05 only) (5,08) .020 (11,18) .440 (0,38) .015 (0,64) .025 SQ TYP –DV (HTSS ONLY) –D–RA RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality ZSS 1 NO. PINS PER ROW OTHER SOLUTIONS • Shrouded IDC headers and stackers to mate with IDSD, SMSD Series. See TST, HTST and ZST Series. (Standard sizes.) (2,54) .100 x No. of Positions + (3,81) .150 (2,54) .100 x No. of Positions + (1,27) .050 (MOQ Required) • Other sizes • Other platings • Alignment Pins • Single Row • Locking Leads • Polarized Contact Samtec. 02 (2,54) .100 –T (2,54) .100 (6,35) .250 (8,89) .350 (2,29) .090 MIN (0,64) .025 SQ TYP (2,54) .100 –“XXXX” = Body Height –L = 10µ" (0,25 µm) Gold on post, Matte Tin on tail = Matte Tin (0,38) .015 Note: Some lengths, styles and options are non-standard, non-returnable. ZSS is non-standard, non-returnable. = Gold flash on post, Matte Tin on tail (9,27) .365 01 BODY HEIGHT D –F Specify LEAD STYLE from chart. 03, 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 ALSO AVAILABLE PLATING OPTION LEAD STYLE BODY HEIGHT LEAD STYLE –01 –02 –03 –04 –05 –06 –07 –08 –09 C (OAL) MAX BODY HEIGHT (16,00) .630 (13,72) .540 (18,54) .730 (16,26) .640 (21,08) .830 (18,80) .740 (23,62) .930 (21,34) .840 (26,16) 1.030 (23,88) .940 (28,70) 1.130 (26,42) 1.040 (31,24) 1.230 (28,96) 1.140 (33,78) 1.330 (31,50) 1.240 (36,32) 1.430 (34,04) 1.340 C (OAL) Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@ samtec.com for more information. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
HTSS-136-01-G-D
- 物料型号:ZSS–113–03–L–D–0735 和 F-215。 - 器件简介:文档描述了Samtec的TSS, HTSS, ZSS系列,这些是带状电缆连接器,具有不同的引脚配置和特性。 - 引脚分配:提供了不同引脚数量的配置,如03, 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36等。 - 参数特性:绝缘材料为黑色玻璃填充聚酯(TSS, ZSS)或天然PCT(HTSS),绝缘电阻至少为5000 MΩ。端子材料为磷青铜,镀层为金或锡。 - 功能详解:文档详细描述了连接器的规格,包括引脚样式、引脚长度、最大机身高度等。 - 应用信息:提供了一些应用建议,例如使用机械板间隔器增加机械稳定性。 - 封装信息:提供了不同引脚样式的详细尺寸和最大机身高度。
HTSS-136-01-G-D 价格&库存
很抱歉,暂时无法提供与“HTSS-136-01-G-D”相匹配的价格&库存,您可以联系我们找货
