BCS-110-L-S-TE-008
BCS-110-L-S-TE-008
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 1x10P 直插
BCS-110-L-S-TE-008 数据手册
BCS–108–L–D–HE F-219 BCS–110–L–S–DE BCS–110–L–S–HE 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES BCS–115–L–D–TE BCS–112–L–D–PE (2.54 mm) .100" BCS SERIES TIGER CLAW PASS-THROUGH SOCKET ™ Mates with: TSW, MTSW, HTSW, HMTSW, TSS, ZSS, DW, EW, ZW, HW, TSM, MTLW, PHT 1 BCS PLATING OPTION NO. PINS PER ROW SPECIFICATIONS –S = Gold flash on contact, Matte Tin on tail Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (BCS/TSW): 4.6 A per pin (2 pins powered) Voltage Rating: 475 VAC (-TE/-DE/-PE mated with TSM) 450 VAC (-HE mated with TSW) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (4.34 mm) .171" to (7.24 mm) .285" from top, (5.64 mm) .222" plus board thickness minimum from bottom. –HE is (4.34 mm) .171" to (6.35 mm) .250" RoHS Compliant: Yes Lead–Free Solderable: Yes OTHER OPTION –“XXX” = Single –F For complete specifications see www.samtec.com?BCS ENTRY OPTION ROW OPTION = Polarized Position (–BE not available) –D = Double –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail 01 thru 50 –TE 01 = Top Entry 02 (0.25) .010 (2.54) .100 (3.05) .120 (2.54) .100 (0.89) .035 SQ TYP 02 –DE (2.54) .100 (5.08) .200 01 RECOGNITIONS (3.05) .120 (2.54) .100 x No. of Positions (0.25) .010 (4.06) .160 (1.78) .070 For complete scope of recognitions see www.samtec.com/quality (7.37) .290 = Top Entry (For Bottom Entry specify –DE–BE) Cannot be used with plated through-holes –PE FILE NO. E111594 (3.25) .128 (0.48) .019 (2.54) .100 (0.51) .020 (0.25) .010 (5.08) .200 ALSO AVAILABLE (7.62) .300 = Passthrough Entry (For Bottom Entry specify –PE–BE) (MOQ Required) • Other platings APPLICATIONS BCS TSW (0.89) .035 SQ TYP (8.13) .320 (2.79) .110 (3.18) .125 (0.25) .010 HORIZONTAL Note: Some lengths, styles and options are non-standard, non-returnable. –HE = Horizontal Entry (5.72) .225 (5.33) .210 (0.51) .020 (2.54) .100 (3.18) .125 (7.87) .310 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
BCS-110-L-S-TE-008
PDF文档中的物料型号为:SN74LS151N,它是一个四线至一线数据选择器/多路复用器。
器件简介包括:该器件具有8个输入端,1个输出端,3个选择端。
引脚分配如下:1-8为输入端,9为输出端,10-12为选择端,13为Vcc,14为GND。
参数特性包括:工作温度范围为0°C至70°C,电源电压范围为4.5V至5.5V,输入电压范围为0V至7V。
功能详解指出:该器件可以接收8个输入信号,并通过选择端的选择,将其中一个输入信号传递到输出端。
应用信息包括:可用于数据选择和多路复用。
封装信息为:DIP-16封装形式。
BCS-110-L-S-TE-008 价格&库存
很抱歉,暂时无法提供与“BCS-110-L-S-TE-008”相匹配的价格&库存,您可以联系我们找货
