BHS-118-T-A
BHS-118-T-A
    SAMTEC(申泰)
    .100" HIGH-TEMP SINGLE ROW, SCRE
BHS-118-T-A 数据手册
F-224 WEB BDL–110–G–F BBL–112–T–E BBD–130–T–B BHS–125–G–A (2.54 mm) .100" BBS, BBL, BHS, BBD, BDL SERIES BBS–116–G–C MACHINED BOARD STACKING STRIPS Mates with: SS, SD, HSS, SL, SDL, ESS, ESD TYPE STRIP 1 PLATING OPTION NO. PINS PER ROW LEAD STYLE FEATURES • Low profile design achieves (3.89 mm) .153" board spacings when mated with SL Series. • Approach the reliability of a permanent connection with the flexibility of a separable connection. SPECIFICATIONS For complete specifications see www.samtec.com?BBS, www.samtec.com?BBL, www.samtec.com?BHS www.samtec.com?BBD or www.samtec.com?BDL Insulator Material: Black Liquid Crystal Polymer (BBL, BHS) Black Glass Filled Polyester (BBS, BBD, BDL) Temperature Range: -55 °C to +125 °C Terminal Material: Phosphor Bronze or Brass Plating: Au or Sn over 50 µ" (1.27 µm) Ni Lead-Free Solderable: Yes (BBL, BDL, BHS-S) No, Lead Wave only (BBS, BBD, BHS-N) BBS –G (2.54) .100 x No. of Positions = 20 µ" (0.51 µm) Gold (2.54) .100 = Standard Single Row (2.54) .100 TYP BBL = Low Profile Single Row (1.27) .050 –T (2.54) .100 = Tin BHS BBL body available with Styles –E & –F only. BBS BHS = High Temp Single Row BBL 01 thru 32 (2.54) .100 x No. of Positions BBD = Standard Double Row = BBS & BBL (2.54) .100 (5.08) .200 (2.54) .100 TYP (1.27) .050 01 thru 36 (2.54) .100 BDL = Low Profile Double Row BDL BBD –A Z = (5.33 mm) .210" = BBD, BDL & BHS BDL body available with Styles –E & –F only. –B Z = (8.51 mm) .335" –C Z = (14.86 mm) .585" –E –F Z = (1.78 mm) .070" Z = (2.16 mm) .085" RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality (0.46) .018 DIA Style E: Style F: (2.67) (3.18) .105 .125 (3.18) .125 FILE NO. E111594 (3.18) .125 Z (1.78) .070 DIA (1.27) .050 (3.18) .125 (0.46) .018 DIA Z (1.78) .070 DIA (0.46) .018 DIA BBL Series (1.27) .050 DIA (0.46) .018 DIA BBS and BHS Series Z BBD Series BDL Series Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
BHS-118-T-A
物料型号: - BBS系列:单排板对板连接器 - BBL系列:低剖面单排板对板连接器 - BHS系列:高温单排板对板连接器 - BBD系列:标准双排板对板连接器 - BDL系列:低剖面双排板对板连接器
器件简介: - 这些连接器设计用于实现低剖面设计,具有可靠性和灵活性。
引脚分配: - 引脚数从1到32(单排)和1到36(双排)不等。
参数特性: - 绝缘体材料:黑色液晶聚合物(BBL, BHS)或黑色玻璃填充聚酯(BBS, BBD, BDL) - 温度范围:-55°C至+125°C - 端子材料:磷青铜或黄铜 - 镀层:金或锡覆盖50微米(1.27微米)镍
功能详解: - 提供了不同长度和样式的端子,以适应不同的应用需求。
应用信息: - 适用于需要低剖面和高可靠性连接的场合。
封装信息: - 详细规格和认可范围请访问Samtec官方网站。
BHS-118-T-A 价格&库存
很抱歉,暂时无法提供与“BHS-118-T-A”相匹配的价格&库存,您可以联系我们找货
BHS-118-T-A
  • 1+30.160601+3.89830
  • 60+25.5970060+3.30840
  • 108+24.11170108+3.11650
  • 1008+20.781801008+2.68610
库存:2323
